Tactical Overview, Ops Center, Ops Screen Problems
jbennett
Post by jbennett »
I'm not exactly sure when this started, but it seems like the following screens aren't updating on my system:
Tactical Overview
Operations Center
Operations Screen
When I click directly on Tactical Overview, I get the "Whoops! Error: Could not read object configuration data!" screen. However, I have my home link set to go to the tactical over view screen and I can get to it that way successfully.
Any help would be appreciated.
Re: Tactical Overview, Ops Center, Ops Screen Problems
Have you recently added a ram disk?
Can you output
cat /usr/local/nagios/etc/nagios.cfg |grep object_cache_file
and then get permissions of the file is shows
/usr/local/nagios/var/objects.cache
also, is nagios running
service nagios status
jbennett
Post by jbennett »
scottwilkerson wrote:Have you recently added a ram disk?
Can you output
#object_cache_file=/usr/local/nagios/var/objects.cache
object_cache_file=/var/nagiosramdisk/objects.cache
# ls -lh /usr/local/nagios/var/objects.cache
-rw-r--r-- 1 nagios nagios 3.9M Jul 21  2011 /usr/local/nagios/var/objects.cache
]also, is nagios running
# service nagios status
nagios (pid 25824) is running...
jbennett
Post by jbennett »
I went back through the document for implementing a ram disk as your post gave me somewhere to look. When I check fstab, I see the following:
/dev/VolGroup00/LogVol00_ROOT /                       ext3    defaults        1 1
/dev/VolGroup00/LogVol00 /tmp                    ext3    defaults        1 2
/dev/VolGroup00/LogVol00_VAR /var                    ext3    defaults        1 2
LABEL=/boot             /boot                   ext3    defaults        1 2
tmpfs                   /dev/shm                tmpfs   defaults        0 0
tmpfs                   /var/nagiosramdisk      tmpfs   defaults,size=75m       0 0
devpts                  /dev/pts                devpts  gid=5,mode=620  0 0
sysfs                   /sys                    sysfs   defaults        0 0
proc                    /proc                   proc    defaults        0 0
/dev/VolGroup00/LogVol01_SWAP swap                    swap    defaults        0 0
10.100.3.220:/kickstart /kickstart               nfs    defaults        1 2
Would having multiple temp file systems be getting in the way?
I did find that the commands were missing, per the document. I made that change and now I can actually get to the tactical overview screen, however, it's not the right one. It's almost like it's pointing to an old version of it. If I click on the home link and it takes me to the tactical overview screen I have set for it to go to, it is updated and correct.
can you run the following
jbennett
Post by jbennett »
What does it need to be set to?
-bash: /var/nagiosramdisk/objects.cache: Permission denied
-rw-r--r-- 1 nagios nagios 6368693 Feb 26 19:25 objects.cache
mguthrie
Post by mguthrie »
How's the free space on that RAM disk?
df -h
df -i
jbennett
Post by jbennett »
mguthrie wrote:How's the free space on that RAM disk?
df -h
df -i
Filesystem            Size  Used Avail Use% Mounted on
/dev/mapper/VolGroup00-LogVol00
                      108G   47G   56G  46% /
tmpfs                 7.4G     0  7.4G   0% /dev/shm
/dev/sda1              97M   82M   11M  89% /boot
Filesystem            Inodes   IUsed   IFree IUse% Mounted on
                     7122336  203012 6919324    3% /
tmpfs                 160609       1  160608    1% /dev/shm
/dev/sda1              25688      57   25631    1% /boot
jbennett
Post by jbennett »
I came in this am to the following:
# df -h
/dev/mapper/VolGroup00-LogVol00_ROOT
                       48G   28G   18G  61% /
                      2.9G   69M  2.7G   3% /tmp
/dev/mapper/VolGroup00-LogVol00_VAR
                      4.8G  4.1G  390M  92% /var
/dev/hda1             190M   47M  134M  26% /boot
tmpfs                 2.0G     0  2.0G   0% /dev/shm
tmpfs                  75M   75M     0 100% /var/nagiosramdisk
I'm assuming I need to resize the ramdisk...
mguthrie
Post by mguthrie »
Yes, but also check why it was filled up. If you're also using it for the perfdata and checkresult spool, those files can fill up the RAM disk if either the Nagios daemon or NPCD daemon aren't running.
