Graphing results from a database
How would you use NagiosGrapher to create a graph of values collected from a database via sql select statements ran every hour?
Re: Graphing results from a database
Unfortunately we do not support NagiosGrapher, it was supported by a competitor but that has since ceased. You may want to try finding an address you can reach one of the developers at if they are still supporting it. That could be found here:
http://sourceforge.net/projects/nagiosgrapher/
You would need to create a plugin which would monitor what you laid out above, and that plugin would need to output performance data that NagiosGrapher can read.
Apologies for posting in this forum, I thought it was supported by Nagios.
Thanks for letting me know.
