Check HP P2000 API
Richard_Lian
Re: Check HP P2000 API
Post by Richard_Lian »
ok I will do that - thanks.
If anyone on here does come up with something though - please let us know.
Regards,
Richard
We'll keep the thread open in case anyone does have a fix, or if you get it working and wish to report back.
Richard_Lian
Hopefully the author will reply or if anyone on here spots anything that would be helpful.
I tried posting on the authors site but my posts haven't appeared.
Posts probably need to be moderated before they show publicly. I'd give it some time.
Richard_Lian
Not gotten a reply from the author yet but I asked a coder to take a look for me.
Basically he found that the FRU is returning some absent values which are being interpreted as "Critical". The hack or workaround is to bypass/ignore the absent values.
The actual code used for the FRU check function is below if you wish to copy it. Please note that this is not supported by the author or me, it is simply a workaround that has done the job for us. These values can't be important to us as they were not present in the firmware pre the upgrade, plus the SAN management interface does not register them which uses the same API.
//Get FRU Information
								$regXML = getRequest($sessionVariable, "{$url}show/frus", $secure);
								$regXML = new SimpleXMLElement($regXML);
								foreach($regXML->OBJECT as $obj) {
										$attr = $obj->attributes();
										if($attr['name']== "fru") {
												// RG: Temp hack to remove empty values returned by the API.
												$type = (string) getEnclosureStatus($obj->PROPERTY, array('name'=>'name', 'value'=>'fru-shortname'));
												if ( empty($type) || $type == "" )
													continue;
												else
													$statuses[$type][]= getEnclosureStatus($obj->PROPERTY, array('name'=>'name', 'value'=>'fru-status'));
abrist
Red Shirt
Post by abrist »
Nice work! Thanks for the update.
christudorache
Post by christudorache »
Sorry for the late reply, been busy here. Nice work! Thanks for the update. That worked. The problem started when I upgraded my firmware as well.
