Hello!
I've installed Nagios 3.5.1 and NRDP on Ubuntu Server.
How can I test if NRDP is working properly? Whenever I enter command(DISABLE_HOST_NOTIFICATIONS;localhost), I get response "BAD COMMAND FILE".
Has anyone ever integrated SCOM to Nagios? What is the easiest way to do it and where can i find some documentation about it?
Thanks!
NRDP and Nagios and SCOM
Re: NRDP and Nagios and SCOM
Does the command file exist?
ls -la /usr/local/nagios/var/rw/nagios.cmd
Yes it does exist, but its empty. My path is :abrist wrote:Does the command file exist?Code: Select all
/var/lib/nagios3/rw/nagios.cmd
Indeed it should be empty as it is a pipe.hents1230 wrote:Yes it does exist, but its empty.
Can you issue commands from the nagios UI?
What is the output of:
grep cmd /usr/local/nrdp/server/config.inc.php
Hey,
About Nagios and SCOM. Why not completely replace SCOM with Nagios XI? Nagios XI is cheaper, faster and better. I've worked 5 years with SCOM 2007R2 and had some really bad experiences with it. The learning curve of Nagios is a litle higher, but worth it in the end imho.
If you want integration and have SCOM 2012, you could have a look at this: http://exchange.nagios.org/directory/Ad ... or/details
For 2007 R2 I don't immediately find documentation, maybe this: http://exchange.nagios.org/directory/Ad ... rk/details
Grtz
Willem
Grtz
Willem
Nagios XI 5.8.1
https://outsideit.net
hents1230,
What's the status of this issue? Has there been any progress here regarding the troubleshooting step that abrist provided above? Thanks!
abrist wrote:Indeed it should be empty as it is a pipe.hents1230 wrote:Yes it does exist, but its empty.
What is the output of:Code: Select all
