Linux host not sending logs
Gabriel_Barba
Re: Linux host not sending logs
Post by Gabriel_Barba »
It works!
I tried to add a new filter in the 500_filter.conf file + the pattern file, but the logstash's log said something was wrong with the filter, so I only left the pattern file and now all maillog file is in NLS shown correctly, thanks a lot!
Excellent! Let us know if we can lock this topic and mark it as "resolved".
Gabriel_Barba
Yes please.
kconti
Post by kconti »
Gabriel_Barba wrote:It works!
Gabriel_Barba - do you mind clarifying the steps you took to fix this issue? I have followed the trail of this message and I seem to be having the same exact problem as you. Did you add/remove any global configuration Filters via the web interface?
If you could provide any additional detail to what you mentioned above, I'd greatly appreciate it. I'm very new to this tool.
KC
kconti
Post by kconti »
Actually mine may not be exactly the same.
tcpdump from NLS:
tcp 0 0 127.0.0.1:60313 127.0.0.1:5544 ESTABLISHED
tcp 0 0 127.0.0.1:35544 127.0.0.1:9200 TIME_WAIT
tcp 0 0 :::5544 :::* LISTEN
tcp 0 0 ::ffff:127.0.0.1:5544 ::ffff:127.0.0.1:60313 ESTABLISHED
udp 0 0 :::5544 :::*
I'm not seeing the sending server listed (192.168.2.108).
I ran the setup configuration script and rsyslog was configured successfully (gave OK's), but no logs show up on NLS interface.
I can ping both ways. I disabled iptables, still no luck. I'll check the firewall logs, but shouldn't be stopping it..
jolson
Attack Rabbit
Post by jolson »
Did you follow this step?
Please add the following to your rsyslog.conf:
echo "\$IncludeConfig /etc/rsyslog.d/*.conf" >> /etc/rsyslog.conf
And restart rsyslog:
service rsyslog restart
Let me know if that works. Thanks!
Twits Blog
kconti
Post by kconti »
Firewall was blocking UDP - heh sorry about that.
Feel free to lock down post again. - thanks
jolson
Attack Rabbit
Post by jolson »
No worries - will do. :)
Twits Blog
