error check_ifoperstatnag SnmpV3
pamuro01
Re: error check_ifoperstatnag SnmpV3
Post by pamuro01 »
I found the problem:
The command configured by the wizard was as follows:
"./check_ifoperstatnag 10116 -v3 -u NAGIOSv3 -A NagiosOperxxxx -x AES -X Operxxxx -a MD5 -l authNoPriv 192.168.x.x"
the right thing was:
"./check_ifoperstatnag 10116 -v 3 -u NAGIOSv3 -A NagiosOperxxxx -x AES -X Operxxxx -a MD5 -l authNoPriv 192.168.x.x"
it might be good to review the wizard.
Thank you for your help
Post by slansing »
Can you let us know which version of this wizard you were using? Admin > Manage Config Wizards.
pamuro01
Post by pamuro01 »
Always keep updated nagios version, the current version is 2.1.2, but this was before upgrading
sreinhardt
-fno-stack-protector
Post by sreinhardt »
This should be patched, as it seems it is, with version 2.1.2 and newer, this was an issue that was patched post 2.0. Hopefully you should no longer see this issue.
