Hi i have install nagios3.4.1 and nagios-nrpe-pluggins on my nagios server.
but when i check for correctness i get the folowing output
$ sudo /usr/lib/nagios/plugins/check_nrpe -H localhost
Connection refused by host
im not able to get the output from my client server. even though i have allowed the nagios server ipaddress on nrpe.cfg on the client server.
This is the following ouput i get when i try to check the disk space of the client server..
/usr/lib/nagios/plugins/check_nrpe -H <client-server-ip> -c check_disk
CHECK_NRPE: Socket timeout after 10 seconds.
Im sure this is a networking issue as im NOT able to telnet from the nagios-server to client-server or vice-versa
Please help me fix this issue.
Not able to get the output through NRPE
kalyan1709
Re: Not able to get the output through NRPE
Have you checked whether port 5666 is listining or not from Nagios server?
# telnet server_IP 5666
Run an nmap against the client ip:
Check the logs on the client server and the nagios server:
nmap <client-server-ip> -p 5666Code: Select all
tail -20 /var/log/messagesFormer Nagios employee
Did you add 5666 port to your /etc/services? Check it and paste output:
Are nrpe running?
Do you run nrpe via xinetd/inetd or standalone daemon? If xinetd make sure that in /etc/xinetd.d/nrpe you have sth like this:
Is xinetd running?
If not, try
less /etc/services |grep 5666Code: Select all
ps aux |grep nrpeCode: Select all
# default: on
# description: NRPE (Nagios Remote Plugin Executor)
service nrpe
flags = REUSE
socket_type = stream
port = 5666
wait = no
user = nagios
group = nagios
server = /usr/local/nagios/bin/nrpe
server_args = -c /usr/local/nagios/etc/nrpe.cfg -i
log_on_failure += USERID
disable = no
only_from = <allowed_ip, eg 127.0.0.1> // I deleted this line at my Nagios server, try it to
ps aux |grep xinetd
service xinetd start-
sreinhardt
- -fno-stack-protector
Thanks for the good advice Mkot, let us know how it goes arun.
