Nagios response time
We have been noticing that it takes a while after a server goes offline to appear red in the web console.
Not sure what controls this or if there is a way to make nagios show up red quicker after a server goes offline?
Re: Nagios response time
There are two things that will effect the web UI responsiveness to state changes:
1. Check interval and where in the scheduled check that the box fails. If the interval is 5 minutes, and the server goes down a few moments after the check, nagios will not know that the host is down until the next check, which could approach the check_interval time.
2. The web UI refresh rate. By default, the frontend should refresh every 30 seconds. This time can be reduced, but too low of settings or too many users will lead to excessive db queries.
The first issue can be mitigated by using passive checks like nsca/snmp traps as passive checks are event driven and do not update on an interval.
the excsvc.cfg file says http interval is 30. What is it safe to set it to?
Will this make the alert show up quicker if the server goes down?
excsvc.cfg? Could you post this file? I would guess that you may have the check_interval for the check set to 30 minutes. But without seeing the file, this is but conjecture.billperrotta wrote:the excsvc.cfg file says http interval is 30. What is it safe to set it to
hostgroup_name exchange-servers
service_description HTTP
check_command check_http
notification_interval 30
service_description HTTPS
check_command check_https
service_description POP
check_command check_pop
"excsvc.cfg" 44L, 879C 1,9 Top
Only thing is I don't know if this file is only to exchange servers group or all servers?
maybe it is this file the notification interval is 60 at the bottom of this file
7> use generic-service
hostgroup_name corporate-servers,hotel-servers
service_description NSClient++ Version
check_command check_nt!CLIENTVERSION
notification_interval 0
service_description Uptime
check_command check_nt!UPTIME
8> hostgroup_name corporate-servers,hotel-servers
service_description CPU Load
check_command check_nt!CPULOAD!-l 5,80,90
0>}
service_description Memory Usage
check_command check_nt!MEMUSE!-w 80 -c 90
service_description W3SVC
check_command check_nt!SERVICESTATE!-d SHOWALL -l W3SVC
define servicegroup{
servicegroup_name drivespace
alias Drive Space
(>define serviceescalation{
contact_groups admins
first_notification 1
last_notification 0
notification_interval 60
escalation_options c
4>}
"winsvc.cfg" 51L, 1189C 51,1 All
All of those are using the standard check_interval of 5 minutes. Can you post the "generic-service" template?
yes if i knew where it might be?
Do you have a templates.cfg file in the nagios objects directory?
