Nagios service latency and pending state issue
Dear All,
I am using Nagios to monitor our infrastructure and there is a huge performance issue. Service checks are not happening on time and services remains in pending state. Could you please help to fix these issues. Below are the details.
Nagios core version: 3.5
Hosts: 2301
services : 16700
Service Check Execution Time: 0.00 / 762.76 / 21.565 sec
Service Check Latency: 0.00 / 125337.24 / 7675.700 sec
Host Check Execution Time: 0.00 / 31.06 / 6.602 sec
Host Check Latency: 0.00 / 9120.72 / 7466.344 sec
# Active Host / Service Checks: 1758 / 13493
# Passive Host / Service Checks: 543 / 3263
Hosts: 2301
services : 16700
Re: Nagios service latency and pending state issue
Well, we will need some more information.
Could you start by posting (in code wraps):
1. Your nagios.cfg.
2. A tail of nagios.log:
3. Any other helpful information - Are you using any third party add-ons like mod_gearman, mklivestatus, check_mk, etc?
1. Your nagios.cfg.
tail -25 /usr/local/nagios/var/nagios.log
Thanks for your reply. Please find the details below.
1. nagios.cfg is attached
2. 3. Tail of nagios.log
4. No other 3rd party add-ons. We are planning to implement mod_gearman.
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;HQ-HYPERION1;C:\ Drive Space;1;c:\\ - total: 15.99 Gb - used: 14.89 Gb (93%) - free 1.11 Gb (7%)
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;DC2-GRCATDEV1.kemet.com;port 5666 status;0;PORT 5666 OK: 10.7.0.151/5666 is responding
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;DC2-GRCATDEV1.kemet.com;Disk_FS_Inodes;0;DISK OK
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;MONT1-MESDEV2;NSClient++ Version;0;(No output returned from plugin)
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;HQ-HQUSERX2N;CPU Load;0;CPU Load 14% (15 min average)
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;MONT1-SMS03;Memory Usage;0;Memory usage: total:4967.19 MB - used: 1243.32 MB (25%) - free: 3723.87 MB (75%)
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;HQ-HYPERION1;CPU Load;0;CPU Load 0% (15 min average)
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;DC2-GRCATDEV1.kemet.com;rman-backup-problems;0;OK - rman had 0 problems during the last 3 days
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;DC2-GRCATDEV1.kemet.com;Disk_Filesystem_Usage;0;DISK OK
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;MONT1-MESDEV2;PING;0;PING OK - Packet loss = 0%, RTA = 90.48 ms
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;HQ-HQUSERX2N;Memory Usage;0;Memory usage: total:7758.20 MB - used: 3396.79 MB (44%) - free: 4361.40 MB (56%)
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;MONT1-SMS03;NSClient++ Version;0;NSClient++ 0,4,1,101 2013-05-18
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;HQ-HYPERION1;Memory Usage;0;Memory usage: total:5200.67 MB - used: 1134.18 MB (22%) - free: 4066.48 MB (78%)
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;DC2-GRCATDEV1.kemet.com;tablespace-usage;2;CRITICAL - tbs GRCDATA usage is 99.26%
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;DC2-GRCATDEV1.kemet.com;Linux Hardware Monitoring;0;OK - no errors or warnings
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;MONT1-MESDEV2;paging status;2;CHECK_NRPE: Error - Could not complete SSL handshake.
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;HQ-HQUSERX2N;NSClient++ Version;0;NSClient++ 0,4,1,101 2013-05-18
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;MONT1-SMS03;PING;0;PING OK - Packet loss = 0%, RTA = 88.64 ms
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;HQ-HYPERION1;NSClient++ Version;0;NSClient++ 0,4,1,101 2013-05-18
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;DC2-GRCATDEV1.kemet.com;tnsping;0;OK - connection established to grcatd.
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;DC2-GRCATDEV1.kemet.com;PING;0;PING OK - Packet loss = 0%, RTA = 8.61 ms
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;MONT1-MESDEV3;C:\ Drive Space;3;Free disk space : Invalid drive
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;HQ-HQUSERX2N;PING;0;PING OK - Packet loss = 0%, RTA = 0.25 ms
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;MONT1-SMS03;paging status;0;OK: page file: 1.22G
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;HQ-HYPERION1;PING;0;PING OK - Packet loss = 0%, RTA = 1.96 ms
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;DC2-GRCCDEV1.kemet.com;Disk_FS_Inodes;0;DISK OK
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;DC2-GRCATDEV1.kemet.com;Zombie_Process;0;PROCS OK: 0 processes with STATE = Z
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;MONT1-MESDEV3;CPU Load;0;CPU Load 0% (15 min average)
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;HQ-HQUSERX2N;nadminp.exe service status;0;nadminp.exe: Running
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;MONT1-SMS03;win hardware unexpected shutdown event id 6008 status;0;Eventlog check ok
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;HQ-HYPERION1;paging status;0;OK: page file: 1.11G
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;DC2-GRCCDEV1.kemet.com;Disk_Filesystem_Usage;0;DISK OK
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;DC2-GRCATDEV1.kemet.com;blocking_locks;3;NRPE: Unable to read output
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;MONT1-MESDEV3;Memory Usage;3;could not fetch information from server
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;HQ-HQUSERX2N;namgr.exe service status;0;namgr.exe: Running
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;MONT1-SMS03.kemet.com;C:\ Drive Space;0;c:\\ - total: 30.01 Gb - used: 14.38 Gb (48%) - free 15.63 Gb (52%)
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;HQ-INFOSENG1;C:\ Drive Space;2;connect to address 10.1.40.30 and port 12489: No route to host
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;DC2-GRCCDEV1.kemet.com;Linux Hardware Monitoring;0;OK - no errors or warnings
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;DC2-GRCATDEV1.kemet.com;check_asm;0;OK: are ONLINE and STABLE
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;MONT1-MESDEV3;NSClient++ Version;0;(No output returned from plugin)
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;HQ-HQUSERX2N;nrouter.exe service status;0;nrouter.exe: Running
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;MONT1-SMS03.kemet.com;CPU Load;0;CPU Load 14% (15 min average)
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;HQ-INFOSENG1;CPU Load;2;connect to address 10.1.40.30 and port 12489: No route to host
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;DC2-GRCCDEV1.kemet.com;PING;0;PING OK - Packet loss = 0%, RTA = 9.71 ms
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;DC2-GRCATDEV1.kemet.com;check_asm_db;0;OK: are ONLINE and STABLE
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;MONT1-MESDEV3;PING;0;PING OK - Packet loss = 0%, RTA = 159.17 ms
[1428565248] EXTERNAL COMMAND: PROCESS_SERVICE_CHECK_RESULT;HQ-HQUSERX2N;nserver.exe service status;0;nserver.exe: Running
Could you tell us a little bit about your hardware.
lscpu
cat /proc/cpuinfo
df -h
uptime
top
ps -aux
Sorry for delay in response. Please find the details below.
1. lscpu
2. cat /proc/cpuinfo
3. df -h
4. uptime
5. top -
6. ps -aux
1. lscpu
Architecture: x86_64
CPU op-mode(s): 32-bit, 64-bit
Byte Order: Little Endian
CPU(s): 8
On-line CPU(s) list: 0-7
Thread(s) per core: 1
Core(s) per socket: 1
Socket(s): 8
NUMA node(s): 1
Vendor ID: GenuineIntel
CPU family: 6
Model: 13
Stepping: 3
CPU MHz: 2493.748
BogoMIPS: 4987.49
Hypervisor vendor: KVM
Virtualization type: full
L1d cache: 32K
L1i cache: 32K
L2 cache: 4096K
NUMA node0 CPU(s): 0-7
processor : 0
vendor_id : GenuineIntel
cpu family : 6
model : 13
model name : QEMU Virtual CPU version (cpu64-rhel6)
stepping : 3
microcode : 1
cpu MHz : 2493.748
cache size : 4096 KB
physical id : 0
siblings : 1
core id : 0
cpu cores : 1
apicid : 0
initial apicid : 0
fpu : yes
fpu_exception : yes
cpuid level : 4
wp : yes
flags : fpu de pse tsc msr pae mce cx8 apic mtrr pge mca cmov pse36 clflush mmx fxsr sse sse2 syscall lm unfair_spinlock pni cx16 hypervisor lahf_lm
bogomips : 4987.49
clflush size : 64
cache_alignment : 64
address sizes : 38 bits physical, 48 bits virtual
power management:
processor : 1
cpu family : 6
model : 13
stepping : 3
microcode : 1
cpu MHz : 2493.748
physical id : 1
siblings : 1
core id : 0
cpu cores : 1
apicid : 1
initial apicid : 1
fpu : yes
fpu_exception : yes
cpuid level : 4
wp : yes
bogomips : 4987.49
clflush size : 64
power management:
processor : 2
cpu family : 6
model : 13
stepping : 3
microcode : 1
cpu MHz : 2493.748
physical id : 2
siblings : 1
core id : 0
cpu cores : 1
apicid : 2
initial apicid : 2
fpu : yes
fpu_exception : yes
cpuid level : 4
wp : yes
bogomips : 4987.49
clflush size : 64
power management:
processor : 3
cpu family : 6
model : 13
stepping : 3
microcode : 1
cpu MHz : 2493.748
physical id : 3
siblings : 1
core id : 0
cpu cores : 1
apicid : 3
initial apicid : 3
fpu : yes
fpu_exception : yes
cpuid level : 4
wp : yes
bogomips : 4987.49
clflush size : 64
power management:
processor : 4
cpu family : 6
model : 13
stepping : 3
microcode : 1
cpu MHz : 2493.748
physical id : 4
siblings : 1
core id : 0
cpu cores : 1
apicid : 4
initial apicid : 4
fpu : yes
fpu_exception : yes
cpuid level : 4
wp : yes
bogomips : 4987.49
clflush size : 64
power management:
processor : 5
cpu family : 6
model : 13
stepping : 3
microcode : 1
cpu MHz : 2493.748
physical id : 5
siblings : 1
core id : 0
cpu cores : 1
apicid : 5
initial apicid : 5
fpu : yes
fpu_exception : yes
cpuid level : 4
wp : yes
bogomips : 4987.49
clflush size : 64
power management:
processor : 6
cpu family : 6
model : 13
stepping : 3
microcode : 1
cpu MHz : 2493.748
physical id : 6
siblings : 1
core id : 0
cpu cores : 1
apicid : 6
initial apicid : 6
fpu : yes
fpu_exception : yes
cpuid level : 4
wp : yes
bogomips : 4987.49
clflush size : 64
power management:
processor : 7
cpu family : 6
model : 13
stepping : 3
microcode : 1
cpu MHz : 2493.748
physical id : 7
siblings : 1
core id : 0
cpu cores : 1
apicid : 7
initial apicid : 7
fpu : yes
fpu_exception : yes
cpuid level : 4
wp : yes
bogomips : 4987.49
clflush size : 64
power management:
3. df -h
/dev/mapper/vg_us25nagios001-LogVol00
49G 16G 31G 35% /
tmpfs 25G 68K 25G 1% /dev/shm
/dev/vda1 485M 40M 420M 9% /boot
/dev/mapper/vg_us25nagios001-LogVol01
7.7G 4.8G 2.6G 66% /home
/dev/mapper/vg_us25nagios001-LogVol02
7.7G 155M 7.2G 3% /tmp
/dev/mapper/vg_us25nagios001-LogVol03
7.7G 5.0G 2.4G 68% /usr
/dev/mapper/vg_us25nagios001-LogVol05
4.9G 267M 4.4G 6% /usr/local
/dev/mapper/vg_us25nagios001-LogVol04
15G 3.8G 10G 28% /var
/dev/mapper/nagiosvg-nagioslv
286G 43G 229G 16% /nagiosfs
10.10.10.103:/repofs/rhel6_repo/
49G 16G 31G 35% /repofs/rhel6_repo
10.10.10.103:/repofs/epel_repo/
49G 16G 31G 35% /repofs/epel_repo
10.10.10.103:/repofs/atrpms_repo/
49G 16G 31G 35% /repofs/atrpms_repo
4. uptime
06:47:22 up 39 days, 18:03, 5 users, load average: 1.45, 2.05, 3.01
5. top -
06:47:49 up 39 days, 18:04, 5 users, load average: 1.59, 2.04, 2.99
Tasks: 477 total, 2 running, 475 sleeping, 0 stopped, 0 zombie
Cpu(s): 4.3%us, 3.3%sy, 0.0%ni, 91.4%id, 0.6%wa, 0.0%hi, 0.0%si, 0.4%st
Mem: 30522196k total, 26308932k used, 4213264k free, 770676k buffers
Swap: 4095996k total, 41056k used, 4054940k free, 6566640k cached
PID USER PR NI VIRT RES SHR S %CPU %MEM TIME+ COMMAND
30150 nagios 20 0 132m 38m 1268 R 3.3 0.1 6:48.52 nagios
2290 root 20 0 489m 19m 6788 S 2.0 0.1 1186:59 BESClient
1943 root 20 0 22180 984 740 S 1.0 0.0 101:07.17 xinetd
31016 nagios 20 0 50288 1388 920 S 1.0 0.0 0:15.44 ndo2db
Warning: bad syntax, perhaps a bogus '-'? See /usr/share/doc/procps-3.2.8/FAQ
USER PID %CPU %MEM VSZ RSS TTY STAT START TIME COMMAND
root 1 0.0 0.0 19360 1244 ? Ss Mar05 4:44 /sbin/init
root 2 0.0 0.0 0 0 ? S Mar05 0:02 [kthreadd]
root 3 0.0 0.0 0 0 ? S Mar05 11:13 [migration/0]
root 4 0.0 0.0 0 0 ? S Mar05 0:47 [ksoftirqd/0]
root 5 0.0 0.0 0 0 ? S Mar05 0:00 [stopper/0]
root 6 0.0 0.0 0 0 ? S Mar05 0:27 [watchdog/0]
root 7 0.0 0.0 0 0 ? S Mar05 11:24 [migration/1]
root 8 0.0 0.0 0 0 ? S Mar05 0:00 [stopper/1]
root 9 0.0 0.0 0 0 ? S Mar05 0:54 [ksoftirqd/1]
root 10 0.0 0.0 0 0 ? S Mar05 0:26 [watchdog/1]
root 11 0.0 0.0 0 0 ? S Mar05 10:23 [migration/2]
root 12 0.0 0.0 0 0 ? S Mar05 0:00 [stopper/2]
root 13 0.0 0.0 0 0 ? S Mar05 1:17 [ksoftirqd/2]
root 14 0.0 0.0 0 0 ? S Mar05 1:05 [watchdog/2]
root 15 0.0 0.0 0 0 ? S Mar05 10:33 [migration/3]
root 16 0.0 0.0 0 0 ? S Mar05 0:00 [stopper/3]
root 17 0.0 0.0 0 0 ? S Mar05 0:42 [ksoftirqd/3]
root 18 0.0 0.0 0 0 ? S Mar05 0:24 [watchdog/3]
root 19 0.0 0.0 0 0 ? S Mar05 9:16 [migration/4]
root 20 0.0 0.0 0 0 ? S Mar05 0:00 [stopper/4]
root 21 0.0 0.0 0 0 ? S Mar05 0:43 [ksoftirqd/4]
root 22 0.0 0.0 0 0 ? S Mar05 0:25 [watchdog/4]
root 23 0.0 0.0 0 0 ? S Mar05 9:19 [migration/5]
root 24 0.0 0.0 0 0 ? S Mar05 0:00 [stopper/5]
root 25 0.0 0.0 0 0 ? S Mar05 1:46 [ksoftirqd/5]
root 26 0.0 0.0 0 0 ? S Mar05 0:40 [watchdog/5]
root 27 0.0 0.0 0 0 ? S Mar05 10:52 [events/0]
root 28 0.0 0.0 0 0 ? S Mar05 11:10 [events/1]
root 29 0.0 0.0 0 0 ? S Mar05 35:23 [events/2]
root 30 0.0 0.0 0 0 ? S Mar05 11:07 [events/3]
root 31 0.0 0.0 0 0 ? S Mar05 10:40 [events/4]
root 32 0.0 0.0 0 0 ? S Mar05 11:24 [events/5]
root 33 0.0 0.0 0 0 ? S Mar05 0:00 [cgroup]
root 34 0.0 0.0 0 0 ? S Mar05 0:02 [khelper]
root 35 0.0 0.0 0 0 ? S Mar05 0:00 [netns]
root 36 0.0 0.0 0 0 ? S Mar05 0:00 [async/mgr]
root 37 0.0 0.0 0 0 ? S Mar05 0:00 [pm]
root 38 0.0 0.0 0 0 ? S Mar05 0:35 [sync_supers]
root 39 0.0 0.0 0 0 ? S Mar05 0:40 [bdi-default]
root 40 0.0 0.0 0 0 ? S Mar05 0:00 [kintegrityd/0]
root 41 0.0 0.0 0 0 ? S Mar05 0:00 [kintegrityd/1]
root 42 0.0 0.0 0 0 ? S Mar05 0:00 [kintegrityd/2]
root 43 0.0 0.0 0 0 ? S Mar05 0:00 [kintegrityd/3]
root 44 0.0 0.0 0 0 ? S Mar05 0:00 [kintegrityd/4]
root 45 0.0 0.0 0 0 ? S Mar05 0:00 [kintegrityd/5]
root 46 0.0 0.0 0 0 ? S Mar05 0:24 [kblockd/0]
root 47 0.0 0.0 0 0 ? S Mar05 15:59 [kblockd/1]
root 48 0.0 0.0 0 0 ? S Mar05 0:30 [kblockd/2]
root 49 0.0 0.0 0 0 ? S Mar05 0:20 [kblockd/3]
root 50 0.0 0.0 0 0 ? S Mar05 0:19 [kblockd/4]
root 51 0.0 0.0 0 0 ? S Mar05 1:05 [kblockd/5]
root 52 0.0 0.0 0 0 ? S Mar05 0:00 [kacpid]
root 53 0.0 0.0 0 0 ? S Mar05 0:00 [kacpi_notify]
root 54 0.0 0.0 0 0 ? S Mar05 0:00 [kacpi_hotplug]
root 55 0.0 0.0 0 0 ? S Mar05 0:00 [ata_aux]
root 56 0.0 0.0 0 0 ? S Mar05 0:00 [ata_sff/0]
root 57 0.0 0.0 0 0 ? S Mar05 0:00 [ata_sff/1]
root 58 0.0 0.0 0 0 ? S Mar05 0:00 [ata_sff/2]
root 59 0.0 0.0 0 0 ? S Mar05 0:00 [ata_sff/3]
root 60 0.0 0.0 0 0 ? S Mar05 0:00 [ata_sff/4]
root 61 0.0 0.0 0 0 ? S Mar05 0:00 [ata_sff/5]
root 62 0.0 0.0 0 0 ? S Mar05 0:00 [ksuspend_usbd]
root 63 0.0 0.0 0 0 ? S Mar05 0:00 [khubd]
root 64 0.0 0.0 0 0 ? S Mar05 0:00 [kseriod]
root 65 0.0 0.0 0 0 ? S Mar05 0:00 [md/0]
root 66 0.0 0.0 0 0 ? S Mar05 0:00 [md/1]
root 67 0.0 0.0 0 0 ? S Mar05 0:00 [md/2]
root 68 0.0 0.0 0 0 ? S Mar05 0:00 [md/3]
root 69 0.0 0.0 0 0 ? S Mar05 0:00 [md/4]
root 70 0.0 0.0 0 0 ? S Mar05 0:00 [md/5]
root 71 0.0 0.0 0 0 ? S Mar05 0:00 [md_misc/0]
root 72 0.0 0.0 0 0 ? S Mar05 0:00 [md_misc/1]
root 73 0.0 0.0 0 0 ? S Mar05 0:00 [md_misc/2]
root 74 0.0 0.0 0 0 ? S Mar05 0:00 [md_misc/3]
root 75 0.0 0.0 0 0 ? S Mar05 0:00 [md_misc/4]
root 76 0.0 0.0 0 0 ? S Mar05 0:00 [md_misc/5]
root 77 0.0 0.0 0 0 ? S Mar05 0:00 [linkwatch]
root 78 0.0 0.0 0 0 ? S Mar05 0:04 [khungtaskd]
root 79 0.0 0.0 0 0 ? S Mar05 3:25 [kswapd0]
root 80 0.0 0.0 0 0 ? SN Mar05 0:00 [ksmd]
root 81 0.0 0.0 0 0 ? SN Mar05 6:25 [khugepaged]
root 82 0.0 0.0 0 0 ? S Mar05 0:00 [aio/0]
root 83 0.0 0.0 0 0 ? S Mar05 0:00 [aio/1]
root 84 0.0 0.0 0 0 ? S Mar05 0:00 [aio/2]
root 85 0.0 0.0 0 0 ? S Mar05 0:00 [aio/3]
root 86 0.0 0.0 0 0 ? S Mar05 0:00 [aio/4]
root 87 0.0 0.0 0 0 ? S Mar05 0:00 [aio/5]
root 88 0.0 0.0 0 0 ? S Mar05 0:00 [crypto/0]
root 89 0.0 0.0 0 0 ? S Mar05 0:00 [crypto/1]
root 90 0.0 0.0 0 0 ? S Mar05 0:00 [crypto/2]
root 91 0.0 0.0 0 0 ? S Mar05 0:00 [crypto/3]
root 92 0.0 0.0 0 0 ? S Mar05 0:00 [crypto/4]
root 93 0.0 0.0 0 0 ? S Mar05 0:00 [crypto/5]
root 101 0.0 0.0 0 0 ? S Mar05 0:00 [kthrotld/0]
root 102 0.0 0.0 0 0 ? S Mar05 0:00 [kthrotld/1]
root 103 0.0 0.0 0 0 ? S Mar05 0:00 [kthrotld/2]
root 104 0.0 0.0 0 0 ? S Mar05 0:00 [kthrotld/3]
root 105 0.0 0.0 0 0 ? S Mar05 0:00 [kthrotld/4]
root 106 0.0 0.0 0 0 ? S Mar05 0:00 [kthrotld/5]
root 108 0.0 0.0 0 0 ? S Mar05 0:00 [kpsmoused]
root 109 0.0 0.0 0 0 ? S Mar05 0:00 [usbhid_resumer]
root 110 0.0 0.0 0 0 ? S Mar05 0:00 [deferwq]
root 141 0.0 0.0 0 0 ? S Mar05 0:00 [kdmremove]
root 142 0.0 0.0 0 0 ? S Mar05 0:00 [kstriped]
root 265 0.0 0.0 0 0 ? S Mar05 0:00 [scsi_eh_0]
root 267 0.0 0.0 0 0 ? S Mar05 0:00 [scsi_eh_1]
root 422 0.0 0.0 0 0 ? S Mar05 0:00 [virtio-blk]
root 449 0.0 0.0 0 0 ? S Mar05 0:00 [kdmflush]
root 451 0.0 0.0 0 0 ? S Mar05 0:01 [kdmflush]
root 468 0.0 0.0 0 0 ? S Mar05 0:15 [kjournald]
root 510 0.0 0.0 0 0 ? S Mar05 0:01 [kauditd]
root 558 0.0 0.0 11024 716 ? S<s Mar05 0:00 /sbin/udevd -d
root 750 0.0 0.0 0 0 ? S Mar05 0:00 [virtio-net]
root 803 0.0 0.0 0 0 ? S Mar05 0:00 [hd-audio0]
root 817 0.0 0.0 0 0 ? S Mar05 0:15 [vballoon]
apache 858 0.0 0.0 310720 13552 ? S Apr13 0:17 /usr/sbin/httpd
root 1202 0.0 0.0 0 0 ? S Mar05 0:00 [kdmflush]
root 1204 0.0 0.0 0 0 ? S Mar05 3:33 [kdmflush]
root 1210 0.0 0.0 0 0 ? S Mar05 0:00 [kdmflush]
root 1220 0.0 0.0 0 0 ? S Mar05 0:00 [kdmflush]
root 1229 0.0 0.0 0 0 ? S Mar05 0:20 [kdmflush]
root 1267 0.0 0.0 0 0 ? S Mar05 1:49 [flush-253:3]
root 1286 0.0 0.0 0 0 ? S Mar05 0:00 [kjournald]
root 1287 0.0 0.0 0 0 ? S Mar05 0:00 [kjournald]
root 1288 0.0 0.0 0 0 ? S Mar05 3:10 [kjournald]
root 1289 0.0 0.0 0 0 ? S Mar05 0:02 [kjournald]
root 1290 0.0 0.0 0 0 ? S Mar05 0:07 [kjournald]
root 1291 0.0 0.0 0 0 ? S Mar05 30:03 [kjournald]
root 1376 0.0 0.0 0 0 ? S Mar05 0:00 [iscsi_eh]
root 1379 0.0 0.0 0 0 ? S Mar05 0:08 [ib_addr]
root 1380 0.0 0.0 0 0 ? S Mar05 0:00 [infiniband/0]
root 1381 0.0 0.0 0 0 ? S Mar05 0:00 [infiniband/1]
root 1382 0.0 0.0 0 0 ? S Mar05 0:00 [infiniband/2]
root 1383 0.0 0.0 0 0 ? S Mar05 0:00 [infiniband/3]
root 1384 0.0 0.0 0 0 ? S Mar05 0:00 [infiniband/4]
root 1385 0.0 0.0 0 0 ? S Mar05 0:00 [infiniband/5]
root 1386 0.0 0.0 0 0 ? S Mar05 0:00 [ib_mcast]
root 1387 0.0 0.0 0 0 ? S Mar05 0:00 [iw_cm_wq]
root 1388 0.0 0.0 0 0 ? S Mar05 0:00 [ib_cm/0]
root 1389 0.0 0.0 0 0 ? S Mar05 0:00 [ib_cm/1]
root 1390 0.0 0.0 0 0 ? S Mar05 0:00 [ib_cm/2]
root 1391 0.0 0.0 0 0 ? S Mar05 0:00 [ib_cm/3]
root 1392 0.0 0.0 0 0 ? S Mar05 0:00 [ib_cm/4]
root 1393 0.0 0.0 0 0 ? S Mar05 0:00 [ib_cm/5]
root 1394 0.0 0.0 0 0 ? S Mar05 0:00 [rdma_cm]
root 1397 0.0 0.0 0 0 ? S Mar05 0:00 [cxgb4]
root 1399 0.0 0.0 0 0 ? S Mar05 0:00 [cnic_wq]
root 1400 0.0 0.0 0 0 ? S< Mar05 0:00 [bnx2i_thread/0]
root 1401 0.0 0.0 0 0 ? S< Mar05 0:00 [bnx2i_thread/1]
root 1402 0.0 0.0 0 0 ? S< Mar05 0:00 [bnx2i_thread/2]
root 1403 0.0 0.0 0 0 ? S< Mar05 0:00 [bnx2i_thread/3]
root 1404 0.0 0.0 0 0 ? S< Mar05 0:00 [bnx2i_thread/4]
root 1405 0.0 0.0 0 0 ? S< Mar05 0:00 [bnx2i_thread/5]
root 1409 0.0 0.0 28956 22804 ? S<Lsl Mar05 0:00 iscsiuio
root 1413 0.0 0.0 4880 404 ? Ss Mar05 9:50 iscsid
root 1414 0.0 0.0 8168 4088 ? S<Ls Mar05 38:46 iscsid
root 1612 0.0 0.0 6160 468 ? Ss Mar05 0:00 /sbin/portreserve
root 1619 0.4 0.0 251972 5652 ? Sl Mar05 234:05 /sbin/rsyslogd -i /var/run/syslogd.pid -c 5
root 1649 0.0 0.0 10820 536 ? Ss Mar05 9:34 irqbalance
root 1657 0.0 0.0 0 0 ? S Mar05 0:00 [scsi_eh_2]
root 1658 0.0 0.0 0 0 ? S< Mar05 2:03 [iscsi_q_2]
root 1659 0.0 0.0 0 0 ? S Mar05 0:00 [scsi_wq_2]
root 1661 0.0 0.0 0 0 ? S Mar05 0:00 [scsi_eh_3]
root 1662 0.7 0.0 0 0 ? S< Mar05 427:53 [iscsi_q_3]
root 1663 0.0 0.0 0 0 ? S Mar05 0:00 [scsi_wq_3]
rpc 1697 0.0 0.0 18976 576 ? Ss Mar05 0:19 rpcbind
root 1722 0.0 0.0 13552 444 ? Ss Mar05 12:49 lldpad -d
root 1731 0.0 0.0 0 0 ? S Mar05 0:00 [scsi_tgtd/0]
root 1732 0.0 0.0 0 0 ? S Mar05 0:00 [scsi_tgtd/1]
root 1733 0.0 0.0 0 0 ? S Mar05 0:00 [scsi_tgtd/2]
root 1734 0.0 0.0 0 0 ? S Mar05 0:00 [scsi_tgtd/3]
root 1735 0.0 0.0 0 0 ? S Mar05 0:00 [scsi_tgtd/4]
root 1736 0.0 0.0 0 0 ? S Mar05 0:00 [scsi_tgtd/5]
root 1737 0.0 0.0 0 0 ? S Mar05 0:00 [fc_exch_workque]
root 1738 0.0 0.0 0 0 ? S Mar05 0:00 [fc_rport_eq]
root 1740 0.0 0.0 0 0 ? S Mar05 0:00 [fcoe_work/0]
root 1741 0.0 0.0 0 0 ? S Mar05 0:00 [fcoe_work/1]
root 1742 0.0 0.0 0 0 ? S Mar05 0:00 [fcoe_work/2]
root 1743 0.0 0.0 0 0 ? S Mar05 0:00 [fcoe_work/3]
root 1744 0.0 0.0 0 0 ? S Mar05 0:00 [fcoe_work/4]
root 1745 0.0 0.0 0 0 ? S Mar05 0:00 [fcoe_work/5]
root 1746 0.0 0.0 0 0 ? S< Mar05 0:00 [fcoethread/0]
root 1747 0.0 0.0 0 0 ? S< Mar05 0:00 [fcoethread/1]
root 1748 0.0 0.0 0 0 ? S< Mar05 0:00 [fcoethread/2]
root 1749 0.0 0.0 0 0 ? S< Mar05 0:00 [fcoethread/3]
root 1750 0.0 0.0 0 0 ? S< Mar05 0:00 [fcoethread/4]
root 1751 0.0 0.0 0 0 ? S< Mar05 0:00 [fcoethread/5]
root 1752 0.0 0.0 0 0 ? S Mar05 0:00 [bnx2fc]
root 1753 0.0 0.0 0 0 ? S< Mar05 0:00 [bnx2fc_l2_threa]
root 1754 0.0 0.0 0 0 ? S< Mar05 0:00 [bnx2fc_thread/0]
root 1755 0.0 0.0 0 0 ? S< Mar05 0:00 [bnx2fc_thread/1]
root 1756 0.0 0.0 0 0 ? S< Mar05 0:00 [bnx2fc_thread/2]
root 1757 0.0 0.0 0 0 ? S< Mar05 0:00 [bnx2fc_thread/3]
root 1758 0.0 0.0 0 0 ? S< Mar05 0:00 [bnx2fc_thread/4]
root 1759 0.0 0.0 0 0 ? S< Mar05 0:00 [bnx2fc_thread/5]
root 1762 0.0 0.0 8356 344 ? Ss Mar05 1:32 /usr/sbin/fcoemon --syslog
root 1775 0.0 0.0 0 0 ? S Mar05 0:00 [target_completi]
root 1776 0.0 0.0 0 0 ? S Mar05 0:00 [target_completi]
root 1777 0.0 0.0 0 0 ? S Mar05 0:00 [target_completi]
root 1778 0.0 0.0 0 0 ? S Mar05 0:00 [target_completi]
root 1779 0.0 0.0 0 0 ? S Mar05 0:00 [target_completi]
root 1780 0.0 0.0 0 0 ? S Mar05 0:00 [target_completi]
root 1781 0.0 0.0 0 0 ? S Mar05 0:00 [tmr/0]
root 1782 0.0 0.0 0 0 ? S Mar05 0:00 [tmr/1]
root 1783 0.0 0.0 0 0 ? S Mar05 0:00 [tmr/2]
root 1784 0.0 0.0 0 0 ? S Mar05 0:00 [tmr/3]
root 1785 0.0 0.0 0 0 ? S Mar05 0:00 [tmr/4]
root 1786 0.0 0.0 0 0 ? S Mar05 0:00 [tmr/5]
dbus 1810 0.0 0.0 21964 1476 ? Ss Mar05 0:01 dbus-daemon --system
root 1820 0.0 0.0 85576 5088 ? Ss Mar05 0:16 NetworkManager --pid-file=/var/run/NetworkManager/NetworkManager.pid
root 1823 0.0 0.0 58136 1592 ? S Mar05 0:00 /usr/sbin/modem-manager
rpcuser 1839 0.0 0.0 23348 716 ? Ss Mar05 0:00 rpc.statd
root 1863 0.0 0.0 44988 344 ? Ss Mar05 0:00 /usr/sbin/wpa_supplicant -c /etc/wpa_supplicant/wpa_supplicant.conf -B -u -f /var/log/wpa_supplicant.log -P /var/run/wpa_supplicant.
root 1924 0.0 0.0 0 0 ? S Mar05 0:00 [rpciod/0]
root 1925 0.0 0.0 0 0 ? S Mar05 0:00 [rpciod/1]
root 1926 0.0 0.0 0 0 ? S Mar05 0:00 [rpciod/2]
root 1927 0.0 0.0 0 0 ? S Mar05 0:00 [rpciod/3]
root 1928 0.0 0.0 0 0 ? S Mar05 0:00 [rpciod/4]
root 1929 0.0 0.0 0 0 ? S Mar05 0:00 [rpciod/5]
root 1933 0.0 0.0 23092 516 ? Ss Mar05 0:00 rpc.idmapd
root 1943 1.3 0.0 22180 984 ? Ss Apr09 101:07 xinetd -stayalive -pidfile /var/run/xinetd.pid
root 1949 0.0 0.0 189360 1700 ? Ss Mar05 0:00 cupsd -C /etc/cups/cupsd.conf
root 1960 0.0 0.0 4080 496 ? Ss Mar05 0:00 /usr/sbin/acpid
68 1969 0.0 0.0 38676 2052 ? Ssl Mar05 0:36 hald
root 1970 0.0 0.0 20400 880 ? S Mar05 0:00 hald-runner
root 2011 0.0 0.0 22520 836 ? S Mar05 0:00 hald-addon-input: Listening on /dev/input/event2 /dev/input/event0
68 2016 0.0 0.0 18008 824 ? S Mar05 0:00 hald-addon-acpi: listening on acpid socket /var/run/acpid.socket
root 2038 0.0 0.0 91272 628 ? Ssl Mar05 0:00 pcscd
root 2054 0.0 0.0 452264 1028 ? Ssl Mar05 3:52 automount --pid-file /var/run/autofs.pid
root 2085 0.0 0.0 6764 140 ? Ss Mar05 0:00 /usr/sbin/mcelog --daemon
root 2099 0.0 0.0 66652 608 ? Ss Mar05 0:08 /usr/sbin/sshd
root 2187 0.0 0.0 81320 2548 ? Ss Mar05 55:09 /usr/libexec/postfix/master
postfix 2194 0.0 0.0 82532 3892 ? S Mar05 28:56 qmgr -l -t fifo -u
root 2211 0.0 0.0 114796 1068 ? Ss Mar05 0:53 /usr/sbin/abrtd
root 2227 0.0 0.0 117296 684 ? Ss Mar05 2:52 crond
root 2238 0.0 0.0 21540 312 ? Ss Mar05 0:00 /usr/sbin/atd
root 2251 0.0 0.0 108340 560 ? Ss Mar05 0:01 /usr/bin/rhsmcertd
root 2272 0.0 0.0 27304 352 ? S Mar05 37:09 /usr/sbin/cimserver
cimsrvr 2273 0.0 0.0 392240 2628 ? Sl Mar05 1:00 cimservermain --executor-socket 3
root 2290 2.0 0.0 501036 20156 ? Sl Mar05 1187:00 /opt/BESClient/bin/BESClient
root 2303 0.0 0.0 62364 296 ? Ss Mar05 0:30 /usr/sbin/certmonger -S -p /var/run/certmonger.pid
root 2322 0.0 0.0 134008 1724 ? Ssl Mar05 0:00 /usr/sbin/gdm-binary -nodaemon
root 2329 0.0 0.0 4064 456 tty2 Ss+ Mar05 0:00 /sbin/mingetty /dev/tty2
root 2331 0.0 0.0 4064 456 tty3 Ss+ Mar05 0:00 /sbin/mingetty /dev/tty3
root 2333 0.0 0.0 4064 456 tty4 Ss+ Mar05 0:00 /sbin/mingetty /dev/tty4
root 2335 0.0 0.0 4064 456 tty5 Ss+ Mar05 0:00 /sbin/mingetty /dev/tty5
root 2337 0.0 0.0 4064 456 tty6 Ss+ Mar05 0:00 /sbin/mingetty /dev/tty6
root 2367 0.0 0.0 164848 2024 ? Sl Mar05 0:00 /usr/libexec/gdm-simple-slave --display-id /org/gnome/DisplayManager/Display1
root 2370 0.0 0.0 111324 10408 tty1 Ss+ Mar05 3:38 /usr/bin/Xorg :0 -br -verbose -audit 4 -auth /var/run/gdm/auth-for-gdm-WoM6Fh/database -nolisten tcp vt1
root 2386 0.0 0.0 3133608 1796 ? Sl Mar05 0:00 /usr/sbin/console-kit-daemon --no-daemon
gdm 2456 0.0 0.0 20040 380 ? S Mar05 0:00 /usr/bin/dbus-launch --exit-with-session
gdm 2457 0.0 0.0 21536 588 ? Ss Mar05 0:00 /bin/dbus-daemon --fork --print-pid 5 --print-address 7 --session
gdm 2458 0.0 0.0 269452 3452 ? Ssl Mar05 0:00 /usr/bin/gnome-session --autostart=/usr/share/gdm/autostart/LoginWindow/
root 2461 0.0 0.0 50004 1700 ? S Mar05 0:00 /usr/libexec/devkit-power-daemon
gdm 2465 0.0 0.0 133180 1968 ? S Mar05 0:32 /usr/libexec/gconfd-2
gdm 2480 0.0 0.0 120548 2776 ? S Mar05 0:25 /usr/libexec/at-spi-registryd
gdm 2484 0.1 0.0 367780 9880 ? Ssl Mar05 101:35 /usr/libexec/gnome-settings-daemon --gconf-prefix=/apps/gdm/simple-greeter/settings-manager-plugins
gdm 2486 0.0 0.0 358492 1884 ? Ssl Mar05 0:00 /usr/libexec/bonobo-activation-server --ac-activate --ior-output-fd=12
gdm 2493 0.0 0.0 135280 1312 ? S Mar05 0:00 /usr/libexec/gvfsd
gdm 2494 0.0 0.0 302980 4172 ? S Mar05 0:40 metacity
gdm 2495 0.0 0.0 399560 7812 ? S Mar05 1:53 /usr/libexec/gdm-simple-greeter
gdm 2497 0.0 0.0 299264 4596 ? S Mar05 0:00 plymouth-log-viewer --icon
gdm 2498 0.0 0.0 297964 4356 ? S Mar05 1:57 gnome-power-manager
gdm 2499 0.0 0.0 248584 2976 ? S Mar05 0:00 /usr/libexec/polkit-gnome-authentication-agent-1
root 2507 0.0 0.0 52732 2388 ? S Mar05 0:00 /usr/libexec/polkit-1/polkitd
gdm 2510 0.0 0.0 427608 1492 ? S<sl Mar05 0:00 /usr/bin/pulseaudio --start --log-target=syslog
rtkit 2512 0.0 0.0 168456 952 ? SNl Mar05 9:01 /usr/libexec/rtkit-daemon
root 2610 0.0 0.0 0 0 ? S Mar05 1:06 [kdmflush]
root 2623 0.2 0.0 0 0 ? S Mar05 116:57 [kjournald]
root 2624 0.0 0.0 0 0 ? S Mar05 6:43 [flush-253:7]
apache 2687 0.0 0.0 322712 25308 ? S Apr13 0:14 /usr/sbin/httpd
nagios 2862 0.0 0.1 135476 38096 ? S 06:36 0:00 /nagiosfs/bin/nagios -d /nagiosfs/etc/nagios.cfg
nagios 2864 0.0 0.0 39360 2340 ? S 06:36 0:00 /nagiosfs/libexec/check_nrpe -H 10.217.27.170 -u -t 800 -c check_cpu_util -a 91 96 37
root 4158 0.0 0.0 62504 3684 pts/0 S+ 04:51 0:00 ssh nagios@10.217.41.159
apache 4330 0.0 0.0 309544 11620 ? R 06:37 0:00 /usr/sbin/httpd
apache 4360 0.0 0.0 309408 11744 ? S 06:37 0:00 /usr/sbin/httpd
nagios 4436 0.0 0.0 6248 684 ? Ss Apr10 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
nagios 4437 0.0 0.0 6248 692 ? Ss Apr10 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
nagios 4461 0.0 0.1 135476 38096 ? S 06:38 0:00 /nagiosfs/bin/nagios -d /nagiosfs/etc/nagios.cfg
nagios 4463 0.0 0.0 39360 2340 ? S 06:38 0:00 /nagiosfs/libexec/check_nrpe -H 10.217.29.107 -u -t 800 -c check_cpu_util -a 70 85 37
nagios 4566 0.0 0.1 135476 38096 ? S 06:38 0:00 /nagiosfs/bin/nagios -d /nagiosfs/etc/nagios.cfg
nagios 4568 0.0 0.0 39360 2340 ? S 06:38 0:00 /nagiosfs/libexec/check_nrpe -H 10.217.29.85 -u -t 800 -c check_cpu_util -a 70 85 37
apache 5867 0.0 0.0 309544 11936 ? S 03:21 0:05 /usr/sbin/httpd
apache 5868 0.0 0.0 310196 13116 ? S 03:21 0:04 /usr/sbin/httpd
apache 5930 0.0 0.0 324292 26964 ? S Apr13 0:16 /usr/sbin/httpd
root 6063 0.0 0.0 119536 1924 pts/4 S+ 06:11 0:00 vi IBM-PUREAPPLICATION-SYSTEM-MIB
postfix 6131 0.0 0.0 81400 3392 ? S 06:39 0:00 pickup -l -t fifo -u
nagios 8256 0.0 0.0 6248 692 ? Ss Apr09 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
nagios 8260 0.0 0.0 6248 692 ? Ss Apr09 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
nagios 8263 0.0 0.0 6248 688 ? Ss Apr09 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
root 8287 0.0 0.0 307628 15220 ? Ss Apr09 1:51 /usr/sbin/httpd
root 8304 0.0 0.0 100412 4312 ? Ss 06:13 0:00 sshd: veennaik [priv]
veennaik 8460 0.0 0.0 100592 2120 ? S 06:14 0:00 sshd: veennaik@notty
veennaik 8481 0.0 0.0 57844 2424 ? Ss 06:14 0:00 /usr/libexec/openssh/sftp-server
apache 9065 0.0 0.0 310496 13676 ? S Apr13 0:16 /usr/sbin/httpd
apache 9629 0.0 0.0 309408 11540 ? S 06:43 0:00 /usr/sbin/httpd
root 10112 0.0 0.0 181844 2316 ? S Mar08 0:00 pam: gdm-password
postfix 10122 0.0 0.0 81544 3512 ? S 06:44 0:00 cleanup -z -t unix -u
root 10154 0.0 0.0 11020 596 ? S< Apr01 0:00 /sbin/udevd -d
root 10155 0.0 0.0 0 0 ? S Apr01 0:00 [bluetooth]
postfix 10357 0.0 0.0 81700 4124 ? S 06:44 0:00 local -t unix
postfix 10365 0.0 0.0 81436 3444 ? S 06:44 0:00 bounce -z -t unix -u
postfix 10367 0.0 0.0 81436 3448 ? S 06:44 0:00 bounce -z -t unix -u
root 10693 0.0 0.0 0 0 ? S 06:44 0:00 [flush-253:5]
nagios 10714 0.0 0.0 6248 684 ? Ss Apr13 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
nagios 10716 0.0 0.0 6248 684 ? Ss Apr13 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
nagios 10717 0.0 0.0 6248 688 ? Ss Apr13 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
root 10847 0.0 0.0 0 0 ? S 06:45 0:00 [flush-253:1]
apache 10972 0.0 0.0 416968 24108 ? S Apr13 0:17 /usr/sbin/httpd
apache 11262 0.0 0.0 310216 13452 ? S Apr13 0:16 /usr/sbin/httpd
apache 11263 0.0 0.0 310128 12848 ? S Apr13 0:16 /usr/sbin/httpd
apache 12392 0.0 0.0 311292 14024 ? S Apr13 0:18 /usr/sbin/httpd
nagios 12423 0.0 0.0 6248 692 ? Ss Apr09 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
nagios 12424 0.0 0.0 6248 688 ? Ss Apr09 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
nagios 12434 0.0 0.0 6248 688 ? Ss Apr09 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
nagios 12436 0.0 0.0 6248 688 ? Ss Apr09 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
nagios 12439 0.0 0.0 6248 688 ? Ss Apr09 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
apache 12835 0.0 0.0 309408 11368 ? S 06:47 0:00 /usr/sbin/httpd
postfix 13637 0.2 0.0 81604 3596 ? S 06:48 0:00 smtp -t unix -u
postfix 13865 3.0 0.0 81408 3368 ? S 06:48 0:00 trivial-rewrite -n rewrite -t unix -u
nagios 13885 0.0 0.1 135472 38092 ? S 06:48 0:00 /nagiosfs/bin/nagios -d /nagiosfs/etc/nagios.cfg
nagios 13886 10.0 0.0 129000 4452 ? S 06:48 0:00 /usr/bin/perl -w /nagiosfs/libexec/submit_nagios_events_to_omnibus.pl mcd1-vnx-spb.kemet.com PING 2 PING CRITICAL - Packet loss = 10
nagios 13887 1.0 0.0 6248 680 ? Ss 06:48 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
nagios 13889 0.0 0.0 108200 1244 ? S 06:48 0:00 sh -c /nagiosfs/libexec/posteifmsg -f /nagiosfs/etc/omnibus-eif.cfg -t 15 -l /nagiosfs/var/posteifmsg.lock -r FATAL -m "PING CRITICA
nagios 13890 1.0 0.0 187548 1272 ? Sl 06:48 0:00 /nagiosfs/libexec/posteifmsg -f /nagiosfs/etc/omnibus-eif.cfg -t 15 -l /nagiosfs/var/posteifmsg.lock -r FATAL -m PING CRITICAL - Pac
root 13892 0.0 0.0 110240 1112 pts/2 R+ 06:48 0:00 ps -aux
root 14077 0.0 0.0 108200 1252 ? S Apr08 0:00 /bin/bash /nagiosfs/libexec/eventhandlers/submit_check_result 10.217.24.103 TRAP 1 Encapsulates a DataPower logging message in an SN
root 14079 0.0 0.0 108200 616 ? S Apr08 0:00 /bin/bash /nagiosfs/libexec/eventhandlers/submit_check_result 10.217.24.103 TRAP 1 Encapsulates a DataPower logging message in an SN
root 14080 0.0 0.0 108200 444 ? S Apr08 0:00 /bin/bash /nagiosfs/libexec/eventhandlers/submit_check_result 10.217.24.103 TRAP 1 Encapsulates a DataPower logging message in an SN
root 15709 0.0 0.0 2052 468 ? S 00:00 0:07 /var/adm/perfmgr/bin/srmLINUX <vmstat>
root 15710 0.0 0.0 9320 5048 ? S 00:00 0:11 /var/adm/perfmgr/bin/srmLINUX <procdata>
root 15761 0.0 0.0 110260 1236 ? S 00:00 0:00 sh -c /usr/bin/vmstat 60 1440 2>&1 ?
root 15763 0.0 0.0 6128 512 ? S 00:00 0:00 /usr/bin/vmstat 60 1440
root 15825 0.0 0.0 9320 468 ? S 00:00 0:05 /var/adm/perfmgr/bin/srmLINUX <netstat>
root 16337 0.0 0.0 0 0 ? S Mar10 16:51 [migration/6]
root 16338 0.0 0.0 0 0 ? S Mar10 0:00 [stopper/6]
root 16339 0.0 0.0 0 0 ? S Mar10 0:35 [ksoftirqd/6]
root 16340 0.0 0.0 0 0 ? S Mar10 0:00 [rpciod/6]
root 16341 0.0 0.0 0 0 ? S Mar10 0:00 [tmr/6]
root 16342 0.0 0.0 0 0 ? S Mar10 0:00 [target_completi]
root 16343 0.0 0.0 0 0 ? S Mar10 0:00 [fcoe_work/6]
root 16344 0.0 0.0 0 0 ? S Mar10 0:00 [scsi_tgtd/6]
root 16345 0.0 0.0 0 0 ? S Mar10 0:00 [ib_cm/6]
root 16346 0.0 0.0 0 0 ? S Mar10 0:00 [infiniband/6]
root 16347 0.0 0.0 0 0 ? S Mar10 0:00 [kthrotld/6]
root 16348 0.0 0.0 0 0 ? S Mar10 0:00 [crypto/6]
root 16349 0.0 0.0 0 0 ? S Mar10 0:00 [aio/6]
root 16350 0.0 0.0 0 0 ? S Mar10 0:00 [md_misc/6]
root 16351 0.0 0.0 0 0 ? S Mar10 0:00 [md/6]
root 16352 0.0 0.0 0 0 ? S Mar10 0:00 [ata_sff/6]
root 16353 0.0 0.0 0 0 ? S Mar10 0:17 [kblockd/6]
root 16354 0.0 0.0 0 0 ? S Mar10 0:00 [kintegrityd/6]
root 16355 0.0 0.0 0 0 ? S Mar10 9:59 [events/6]
root 16359 0.0 0.0 0 0 ? S Mar10 0:19 [watchdog/6]
root 16365 0.0 0.0 0 0 ? S< Mar10 0:00 [bnx2i_thread/6]
root 16366 0.0 0.0 0 0 ? S< Mar10 0:00 [fcoethread/6]
root 16368 0.0 0.0 0 0 ? S< Mar10 0:00 [bnx2fc_thread/6]
root 16369 0.0 0.0 0 0 ? S Mar10 10:28 [migration/7]
root 16370 0.0 0.0 0 0 ? S Mar10 0:00 [stopper/7]
root 16371 0.0 0.0 0 0 ? S Mar10 0:33 [ksoftirqd/7]
root 16372 0.0 0.0 0 0 ? S Mar10 0:00 [rpciod/7]
root 16375 0.0 0.0 0 0 ? S Mar10 0:00 [tmr/7]
root 16376 0.0 0.0 0 0 ? S Mar10 0:00 [target_completi]
root 16377 0.0 0.0 0 0 ? S Mar10 0:00 [fcoe_work/7]
root 16378 0.0 0.0 0 0 ? S Mar10 0:00 [scsi_tgtd/7]
root 16379 0.0 0.0 0 0 ? S Mar10 0:00 [ib_cm/7]
root 16380 0.0 0.0 0 0 ? S Mar10 0:00 [infiniband/7]
root 16381 0.0 0.0 0 0 ? S Mar10 0:00 [kthrotld/7]
root 16382 0.0 0.0 0 0 ? S Mar10 0:00 [crypto/7]
root 16383 0.0 0.0 0 0 ? S Mar10 0:00 [aio/7]
root 16384 0.0 0.0 0 0 ? S Mar10 0:00 [md_misc/7]
root 16385 0.0 0.0 0 0 ? S Mar10 0:00 [md/7]
root 16386 0.0 0.0 0 0 ? S Mar10 0:00 [ata_sff/7]
root 16387 0.0 0.0 0 0 ? S Mar10 0:17 [kblockd/7]
root 16388 0.0 0.0 0 0 ? S Mar10 0:00 [kintegrityd/7]
root 16389 0.0 0.0 0 0 ? S Mar10 11:29 [events/7]
root 16395 0.0 0.0 0 0 ? S Mar10 0:26 [watchdog/7]
root 16408 0.0 0.0 11020 640 ? S< Mar10 0:00 /sbin/udevd -d
root 16409 0.0 0.0 0 0 ? S< Mar10 0:00 [bnx2i_thread/7]
root 16411 0.0 0.0 0 0 ? S< Mar10 0:00 [fcoethread/7]
root 16412 0.0 0.0 0 0 ? S< Mar10 0:00 [bnx2fc_thread/7]
nagios 16452 0.0 0.0 6248 688 ? Ss Apr13 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
nagios 16455 0.0 0.0 6248 688 ? Ss Apr13 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
nagios 16456 0.0 0.0 6248 688 ? Ss Apr13 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
nagios 16483 0.0 0.0 6248 688 ? Ss Apr09 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
root 17312 0.0 0.0 100412 4068 ? Ss 03:59 0:00 sshd: cborah [priv]
cborah 17396 0.0 0.0 100572 1908 ? S 03:59 0:00 sshd: cborah@pts/0
cborah 17404 0.0 0.0 108580 2020 pts/0 Ss 03:59 0:00 -bash
root 17466 0.0 0.0 191728 2932 pts/0 S 03:59 0:00 sudo su
root 17467 0.0 0.0 165880 1932 pts/0 S 03:59 0:00 su
root 17468 0.0 0.0 108744 2104 pts/0 S 03:59 0:00 bash
apache 17508 0.0 0.0 309540 11896 ? S 03:01 0:06 /usr/sbin/httpd
apache 17534 0.0 0.0 309676 12076 ? S 03:01 0:06 /usr/sbin/httpd
nagios 18638 0.0 0.0 6248 688 ? Ss Apr10 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
root 19176 0.0 0.0 166072 12868 ? Ss Apr10 0:25 /usr/bin/perl /usr/sbin/snmptt --daemon
snmptt 19177 0.9 0.0 170892 14708 ? Ss Apr10 57:51 /usr/bin/perl /usr/sbin/snmptt --daemon
root 19588 0.0 0.0 100412 4040 ? Ss 04:01 0:00 sshd: deepshet [priv]
deepshet 19709 0.0 0.0 100412 1872 ? S 04:02 0:01 sshd: deepshet@pts/1
deepshet 19721 0.0 0.0 108340 1760 pts/1 Ss 04:02 0:00 -bash
nagios 19747 0.0 0.0 6248 692 ? Ss Apr10 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
nagios 19754 0.0 0.0 6248 684 ? Ss Apr10 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
root 19826 0.0 0.0 191728 2924 pts/1 S 04:02 0:00 sudo su
root 19829 0.0 0.0 165880 1932 pts/1 S 04:02 0:00 su
root 19830 0.0 0.0 108744 2108 pts/1 S+ 04:02 0:00 bash
nagios 20536 0.0 0.0 6248 688 ? Ss Apr13 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
root 21330 0.0 0.0 108200 1252 ? S Apr02 0:00 /bin/bash /nagiosfs/libexec/eventhandlers/submit_check_result 10.217.24.103 TRAP 1 Encapsulates a DataPower logging message in an SN
root 21332 0.0 0.0 108200 644 ? S Apr02 0:01 /bin/bash /nagiosfs/libexec/eventhandlers/submit_check_result 10.217.24.103 TRAP 1 Encapsulates a DataPower logging message in an SN
root 21364 0.0 0.0 108200 472 ? S Apr02 0:00 /bin/bash /nagiosfs/libexec/eventhandlers/submit_check_result 10.217.24.103 TRAP 1 Encapsulates a DataPower logging message in an SN
root 21384 0.0 0.0 0 0 ? S< Apr06 0:00 [kslowd000]
root 21385 0.0 0.0 0 0 ? S< Apr06 0:00 [kslowd001]
root 21388 0.0 0.0 0 0 ? S Apr06 0:00 [nfsiod]
nagios 21718 0.0 0.0 6248 688 ? Ss Apr09 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
nagios 21723 0.0 0.0 6248 684 ? Ss Apr09 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
nagios 21725 0.0 0.0 6248 688 ? Ss Apr09 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
root 22125 0.0 0.0 0 0 ? S Apr01 0:16 [flush-253:6]
root 22728 0.3 0.1 235020 43288 ? Ss Apr09 20:23 /usr/sbin/snmptrapd -On -Lsd -p /var/run/snmptrapd.pid
root 22985 0.0 0.0 197568 4528 ? S Apr09 2:45 /usr/sbin/snmpd -LS0-6d -Lf /dev/null -p /var/run/snmpd.pid
root 23091 0.0 0.0 100412 4324 ? Ss 06:01 0:00 sshd: veennaik [priv]
veennaik 23353 0.0 0.0 100412 1852 ? S 06:02 0:00 sshd: veennaik@pts/3
veennaik 23385 0.0 0.0 108572 1940 pts/3 Ss 06:02 0:00 -bash
root 23492 0.0 0.0 191728 2932 pts/3 S 06:02 0:00 sudo su
root 23494 0.0 0.0 165880 1932 pts/3 S 06:02 0:00 su
root 23495 0.0 0.0 108744 2104 pts/3 S 06:02 0:00 bash
root 24198 0.0 0.0 108200 1256 ? S Mar18 0:00 /bin/bash /nagiosfs/libexec/eventhandlers/submit_check_result 10.217.24.102 TRAP 1 Encapsulates a DataPower logging message in an SN
root 24200 0.0 0.0 108200 636 ? S Mar18 0:01 /bin/bash /nagiosfs/libexec/eventhandlers/submit_check_result 10.217.24.102 TRAP 1 Encapsulates a DataPower logging message in an SN
root 24204 0.0 0.0 108200 476 ? S Mar18 0:00 /bin/bash /nagiosfs/libexec/eventhandlers/submit_check_result 10.217.24.102 TRAP 1 Encapsulates a DataPower logging message in an SN
root 24300 0.0 0.0 62356 3648 pts/3 S+ 06:02 0:00 ssh nagios@10.217.29.85
nagios 24305 0.0 0.0 6248 688 ? Ss Apr13 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
nagios 24306 0.0 0.0 6248 684 ? Ss Apr13 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
nagios 24308 0.0 0.0 6248 688 ? Ss Apr13 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
nagios 25448 0.0 0.0 6248 692 ? Ss Apr09 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
nagios 25459 0.0 0.0 6248 688 ? Ss Apr09 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
root 25805 0.0 0.0 100412 4064 ? Ss 04:40 0:00 sshd: cborah [priv]
nagios 25843 0.0 0.0 6248 684 ? Ss Apr13 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
nagios 25844 0.0 0.0 6248 684 ? Ss Apr13 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
nagios 25847 0.0 0.0 6248 692 ? Ss Apr13 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
cborah 25951 0.0 0.0 100412 1928 ? S 04:40 0:00 sshd: cborah@pts/2
cborah 25963 0.0 0.0 108580 2016 pts/2 Ss 04:40 0:00 -bash
root 26029 0.0 0.0 191728 2924 pts/2 S 04:40 0:00 sudo su
root 26030 0.0 0.0 165880 1932 pts/2 S 04:40 0:00 su
root 26032 0.0 0.0 108744 2128 pts/2 S 04:40 0:00 bash
root 26440 0.0 0.0 143032 2148 ? S Apr09 0:00 CROND
nagios 26444 0.0 0.0 9232 1032 ? Ss Apr09 0:00 /bin/sh -c /usr/bin/rsync -avz --delete --exclude 'checkresults' --exclude '/nagiosfs/spool' --exclude '/nagiosfs/var/snmptt' /nagio
nagios 26445 0.0 0.1 58928 46744 ? S Apr09 0:08 /usr/bin/rsync -avz --delete --exclude checkresults --exclude /nagiosfs/spool --exclude /nagiosfs/var/snmptt /nagiosfs/ nagios@10.10
nagios 26454 0.0 0.0 62640 6104 ? S Apr09 0:00 ssh -l nagios 10.10.10.102 rsync --server -vlogDtprze.iLs --delete . /nagiosfs/
nagios 26465 0.0 0.0 81380 3352 ? S Apr09 0:00 /usr/sbin/sendmail -FCronDaemon -i -odi -oem -oi -t -f root
nagios 26466 0.0 0.0 81344 3308 ? S Apr09 0:00 /usr/sbin/postdrop -r
apache 26529 0.0 0.0 422440 29952 ? S Apr13 0:21 /usr/sbin/httpd
nagios 26606 0.0 0.0 6248 688 ? Ss Apr13 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
nagios 26613 0.0 0.0 6248 684 ? Ss Apr13 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
nagios 26614 0.0 0.0 6248 684 ? Ss Apr13 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
nagios 26615 0.0 0.0 6248 684 ? Ss Apr13 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
nagios 26616 0.0 0.0 6248 688 ? Ss Apr13 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
nagios 26617 0.0 0.0 6248 688 ? Ss Apr13 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
nagios 27762 0.0 0.0 6248 688 ? Ss Apr13 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
apache 28308 0.0 0.0 309552 12832 ? S Apr13 0:15 /usr/sbin/httpd
root 29145 0.0 0.0 108200 1256 ? S Apr06 0:00 /bin/bash /nagiosfs/libexec/eventhandlers/submit_check_result 10.217.24.103 TRAP 1 Encapsulates a DataPower logging message in an SN
root 29147 0.0 0.0 108200 648 ? S Apr06 0:02 /bin/bash /nagiosfs/libexec/eventhandlers/submit_check_result 10.217.24.103 TRAP 1 Encapsulates a DataPower logging message in an SN
root 29179 0.0 0.0 108200 476 ? S Apr06 0:00 /bin/bash /nagiosfs/libexec/eventhandlers/submit_check_result 10.217.24.103 TRAP 1 Encapsulates a DataPower logging message in an SN
root 29598 0.0 0.0 100412 4332 ? Ss 06:07 0:00 sshd: veennaik [priv]
nagios 29670 0.0 0.0 6248 684 ? Ss Apr13 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
nagios 29671 0.0 0.0 6248 688 ? Ss Apr13 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
veennaik 29708 0.0 0.0 100884 2372 ? S 06:07 0:00 sshd: veennaik@pts/4
veennaik 29727 0.0 0.0 108572 1940 pts/4 Ss 06:07 0:00 -bash
root 29789 0.0 0.0 191728 2928 pts/4 S 06:07 0:00 sudo su
root 29792 0.0 0.0 165880 1932 pts/4 S 06:07 0:00 su
root 29793 0.0 0.0 108744 2152 pts/4 S 06:07 0:00 bash
nagios 30010 0.0 0.0 6248 688 ? Ss 06:07 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
nagios 30011 0.0 0.0 6248 688 ? Ss 06:07 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
nagios 30015 0.0 0.0 6248 688 ? Ss 06:07 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
nagios 30024 0.0 0.0 6248 688 ? Ss 06:07 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
nagios 30150 16.7 0.1 135472 39136 ? Ssl 06:07 6:52 /nagiosfs/bin/nagios -d /nagiosfs/etc/nagios.cfg
nagios 30478 0.0 0.0 50288 620 ? Ss 06:07 0:00 /nagiosfs/bin/ndo2db -c /nagiosfs/etc/ndo2db.cfg
nagios 31016 0.6 0.0 50288 1388 ? S 06:08 0:15 /nagiosfs/bin/ndo2db -c /nagiosfs/etc/ndo2db.cfg
nagios 31020 1.3 0.0 57684 8804 ? S 06:08 0:32 /nagiosfs/bin/ndo2db -c /nagiosfs/etc/ndo2db.cfg
apache 31063 0.0 0.0 307628 7492 ? S Apr12 0:00 /usr/sbin/httpd
nagios 32028 0.0 0.0 6248 688 ? Ss Apr10 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
nagios 32029 0.0 0.0 6248 684 ? Ss Apr10 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
nagios 32030 0.0 0.0 6248 688 ? Ss Apr10 0:00 nsca -c /nagiosfs/etc/nsca.cfg --inetd
apache 32127 0.0 0.0 309680 12848 ? S Apr13 0:12 /usr/sbin/httpd
root 32347 0.0 0.0 108200 1256 ? S Apr01 0:00 /bin/bash /nagiosfs/libexec/eventhandlers/submit_check_result 10.217.24.103 TRAP 1 Encapsulates a DataPower logging message in an SN
root 32349 0.0 0.0 108200 648 ? S Apr01 0:02 /bin/bash /nagiosfs/libexec/eventhandlers/submit_check_result 10.217.24.103 TRAP 1 Encapsulates a DataPower logging message in an SN
root 32359 0.0 0.0 108200 476 ? S Apr01 0:00 /bin/bash /nagiosfs/libexec/eventhandlers/submit_check_result 10.217.24.103 TRAP 1 Encapsulates a DataPower logging message in an SN
apache 32434 0.0 0.0 309408 11752 ? S 06:34 0:00 /usr/sbin/httpd
Reason: Please make sure to used code tags to clean up your posts
- Skynet Drone
Is this a recent issue where performance deteriorated rapidly or has the performance just changed a lot over time? You're definitely approaching the limits of what Nagios 3.X could handle on a single machine.
Is your NDO db located on the same server? What kind of disk connectivity do you have for your VM? Are you using virtio hardware (particularly the disk BUS but also the NIC)?
Also, is the machine contending for CPU or memory resources on the KVM host? I notice you have given it 8 vCPUs, often times over allocating CPUs (especially when you do it for all the machines on the host) can cause major resource contention.
Suggestions - verify that you're using virtio hardware first
offload your mysql db if you haven't already second
see where that gets you.
hello,
performance deteriorated rapidly. If we upgrade to Nagios 4.x. will it be fine?
NDO db in a remote vm server. we are using iscis disk. No virtio h/w
No.
No.
Nagios 4.x greatly improves the speed of Nagios overall - if that is a valid option, I recommend upgrading as soon as is reasonable.If we upgrade to Nagios 4.x. will it be fine?
http://nagios.sourceforge.net/docs/nagi ... tsnew.html
We will upgrade and let you know the permormance status.
thanks for your support.
Sounds good - let us know. Thanks!
