Unable to get check_nrpe to find process on Linux server
I had posted the same issue yesterday and thought we had corrected the problem. I am attempting to add a process to monitoring on a Linux server in Nagios Xi. On the server when I run the following command I receive the expected results:
# /usr/local/nagios/libexec/check_procs -a 'Route /opt/nyfix/abim/current/config/appia FMPQA2-10011 DEBUG'
PROCS OK: 1 process with args 'Route /opt/nyfix/abim/current/config/appia FMPQA2-10011 DEBUG' | procs=1;;;0;
There is one process running, so the output is correct. When I test the same command from the Nagios console I receive the following:
COMMAND: /usr/local/nagios/libexec/check_nrpe -H csappia21.qa.nyfix.net -t 30 -c check_procs -a 'Route /opt/nyfix/abim/current/config/appia FMPQA2-10011 DEBUG'
OUTPUT: PROCS OK: 0 processes with STATE = FMPQA2-10011 | procs=0;Route;/opt/nyfix/abim/current/config/appia;0;
This is happening with every process I am trying to add if it has / or - in the process descriptor. How can we correct this? To me it looks like from the console it is trying to find multiple processes instead of a single process. How can we correct this?
Re: Unable to get check_nrpe to find process on Linux server
This is a shot in the dark - but have you tried escaping the '/' characters?
/usr/local/nagios/libexec/check_nrpe -H csappia21.qa.nyfix.net -t 30 -c check_procs -a "Route \/opt\/nyfix\/abim\/current\/config\/appia FMPQA2-10011 DEBUG"
Let me know if that helps - I'm glad this is almost working for you.
Thanks for getting back to me. Unfortunately I did try that and it still does not find the process:
COMMAND: /usr/local/nagios/libexec/check_nrpe -H csappia21.qa.nyfix.net -t 30 -c check_services -a 'Route \\/opt\\/nyfix\\/abim\\/current\\/config\\/appia FMPQA2-10011 DEBUG'
OUTPUT: CHECK_NRPE: Received 0 bytes from daemon. Check the remote server logs for error messages.
Even if I try the following it still fails:
-a 'FMPQA2-10011 DEBUG'
COMMAND: /usr/local/nagios/libexec/check_nrpe -H csappia21.qa.nyfix.net -t 30 -c check_services -a 'FMPQA2-10011 DEBUG'
OUTPUT: Unknown argument: DEBUG
check_services -
Usage: check_services -p egrep_patern_to_find_in_procs[,...]
Usage: check_services -h (help)
Usage: check_services -V (version)
If I try the following it works:
-a 'FMPQA2-10011'
COMMAND: /usr/local/nagios/libexec/check_nrpe -H csappia21.qa.nyfix.net -t 30 -c check_services -a 'FMPQA2-10011'
OUTPUT: FMPQA2-10011: 1
There is current 1 process running that matches that criteria. It definitely looks like there is an issue with spaces in the $ARG2$.
I just tested the following and it also worked:
-a '/opt/nyfix/abim/current'
COMMAND: /usr/local/nagios/libexec/check_nrpe -H csappia21.qa.nyfix.net -t 30 -c check_services -a '/opt/nyfix/abim/current'
OUTPUT: /opt/nyfix/abim/current: 5
There are 5 processes running matching that criteria.
check_services -
-a 'FMPQA2-10011'
I meant to add... It looks like the spaces are actually the issue. I even tried to escaping the spaces which did not work either...
Let's bust out some regex:check_services -p egrep
/usr/local/nagios/libexec/check_nrpe -H csappia21.qa.nyfix.net -t 30 -c check_procs -a 'Route\s/opt/nyfix/abim/current/config/appia\sFMPQA2-10011\sDEBUG'
Unfortunately it is also not working:
COMMAND: /usr/local/nagios/libexec/check_nrpe -H csappia21.qa.nyfix.net -t 30 -c check_procs -a 'Route\\s/opt/nyfix/abim/current/config/appia\\sFMPQA2-10011\\sDEBUG'
From the command line that also does not work:
# /usr/local/nagios/libexec/check_procs -a 'Route\s/opt/nyfix/abim/current/config/appia\sFMPQA2-10011\sDEBUG'
PROCS OK: 0 processes with args 'Route\s/opt/nyfix/abim/current/config/appia\sFMPQA2-10011\sDEBUG' | procs=0;;;0;
It is also not a user issue. I am running the commands as the nagios user on the actual server:
[nagios@csappia21.qa ~]$ /usr/local/nagios/libexec/check_procs -a 'Route /opt/nyfix/abim/current/config/appia FMPQA2-10011 DEBUG'
Can you please show me your remote machines nrpe.cfg?
If you define a command in nrpe.cfg as follows:
Then, from your nagios machine:
This worked like a charm for me - I had forgotten that arguments cannot be passed through NRPE unless you have the "dont_blame_nrpe=" argument set to 1. Try the above method and let me know if it works.
cat /usr/local/nagios/etc/nrpe.cfg
command[check_for_space_thing]=/usr/local/nagios/libexec/check_services -p 'Route\s/opt/nyfix/abim/current/config/appia\sFMPQA2-10011\sDEBUG'
service xinetd restart
./check_nrpe -H client.nrpe.machine.ip -c check_for_space_thing
On the machine I am trying to monitor this is what is present in the nrpe.cfg (I removed all the items that were commented out):
log_facility=daemon
pid_file=/var/run/nrpe.pid
server_port=5666
nrpe_user=nagios
nrpe_group=nagios
allowed_hosts=127.0.0.1
dont_blame_nrpe=1
debug=0
command_timeout=60
connection_timeout=300
include_dir=/usr/local/nagios/etc/nrpe
I then added the 2 lines you suggested:
command[check_for_logstash]=/usr/local/nagios/libexec/check_procs -a logstash -w 2:2 -c 2:2
command[check_for_space_thing]=/usr/local/nagios/libexec/check_services -p 'exec\s/usr/local'
I restarted the xinetd service as requested.
I went to the Nagios server and ran the command you requested and this was the output:
# ./check_nrpe -H 10.10.205.69 -c check_for_space_thing
*** exec\s/usr/local: Nok ***
I went back into the Nagios console and all processes are still showing up with the following:
Unknown argument: /opt/nyfix/abim/current/config/appia
So the problem has not been fixed. Let me know what to check next. Thanks. Steve.
log_facility=daemon
server_port=5666
nrpe_user=nagios
nrpe_group=nagios
dont_blame_nrpe=1
debug=0
command_timeout=60
My apologies - I did not mean my commands exactly. I have edited my original post for clarity. Please remove the two previous entries that you had added, and add the following:
Then restart xinetd:
Try checking once more from Nagios:
What we are trying to do here is define a command in nrpe.cfg that functions properly when run on the remote machine. The 'check_services' command above is an example, but you are free to use any command.
Then you call this command - [check_for_space_thing] - using NRPE.
Ok. I removed the 2 lines I originally added and added the one line you indicated on the server I am trying to monitor:
I then restarted the xinetd process on the server I am trying to monitor.
I then ran the command you indicated, from the Nagios server and this was the output:
*** Route\s/opt/nyfix/abim/current/config/appia\sFMPQA2-10011\sDEBUG: Nok ***
I then tried to run the command from the console using the Service Management view:
COMMAND: /usr/local/nagios/libexec/check_nrpe -H csappia21.qa.nyfix.net -t 30 -c check_services -a 'Route\\s/opt/nyfix/abim/current/config/appia\\sFMPQA2-10011\\sDEBUG'
Looking at the information you provided I was under the impression I needed to add check_for_space_thing as a command in the Nagios console. I added the command with the following:
Command Name - check_for_space_thing
Command Line - $USER1$/check_nrpe -H $HOSTADDRESS$ -t 30 -c $ARG1$ $ARG2$
I then updated the service to the following:
Check Command - check_for_space_thing
$ARG1$ - check_services
$ARG2$ - -a 'Route\s/opt/nyfix/abim/current/config/appia\sFMPQA2-10011\sDEBUG'
I ran the test from the console:
The process is still not being found.
