tezarin
Posts: 32 Joined: Tue Apr 07, 2015 8:03 am
Post
by tezarin » Fri Apr 24, 2015 9:00 am
Hi all,
I have seen this Nagios's behavior a couple of times when my server is actually down and I can't even ping it but Nagios reports that the host is UP. Although it shows all the services are in the critical mode which is correct but what I can't understand is why it report the server as being UP when it's really down.
This is the host alive command:
command_name check-host-alive
command_line sudo $USER1$/check_ping -H $HOSTADDRESS$ -w 3000.0,80% -c 5000.0,100% -p 5
This is the host definition:
use linux-server
host_name server-mysql-backup02
alias server-mysql-backup02
address 192.125.12.14
max_check_attempts 5
check_period 24x7
notification_interval 30
notification_period 24x7
I even tried adding the command below to the host definition but that didn't make a difference:
check_command my-check-host-alive
And also defined a new command in commands.cfg file:
command_name my-check-host-alive
command_line sudo $USER1$/check_tcp -H $HOSTADDRESS$ -p 22
Can someone please shed some lights on this?
Thanks in advance
jasgot
Posts: 19 Joined: Sat Feb 14, 2015 7:52 pm
Post
by jasgot » Fri Apr 24, 2015 10:38 am
I see this all the time. In my case, the service, that does the check and creates the HTML UI I see, has stopped. I perform a "service nagios restart" and all is well.
tezarin
Post
by tezarin » Fri Apr 24, 2015 10:57 am
jasgot wrote: I see this all the time. In my case, the service, that does the check and creates the HTML UI I see, has stopped. I perform a "service nagios restart" and all is well.
Thanks but I've already tried it, it still shows the host being UP.
jolson
Attack Rabbit
Posts: 2560 Joined: Thu Feb 12, 2015 12:40 pm
Post
by jolson » Fri Apr 24, 2015 11:59 am
Is there any reason why 'sudo' is in from of your command definition? Any chance you could try taking it off and getting the results back to us?
command_line $USER1$/check_ping -H $HOSTADDRESS$ -w 3000.0,80% -c 5000.0,100% -p 5
Twits Blog
tezarin
Post
by tezarin » Fri Apr 24, 2015 12:07 pm
jolson wrote: Code: Select all
If I didn't have the sudo in there, the ping would fail for all the hosts, even for the ones that were up. I just removed it and now the GUI shows the status for all the hosts is down.
jolson
Attack Rabbit
Post
by jolson » Fri Apr 24, 2015 12:24 pm
Could you please cat your sudoers file? Sudo should not be necessary for the nagios user to submit commands.
Let's try manually submitting the ping command from the Nagios user:
/usr/local/nagios/libexec/check_ping -H x.x.x.x -w 3000.0,80% -c 5000.0,100% -p 5
Does the 'nagios' user have issues submitting the above command?
Twits Blog
tezarin
Post
by tezarin » Fri Apr 24, 2015 12:58 pm
[root@nagios nagios]# su - nagios
could not open session
I've installed nagios via puppet maybe that's why. The ping command wouldn't run if I don't type the word sudo first.
I've actually got it to work five minutes ago, replaced the ping command with a check_tcp on port 22 and that command works, don't even have to sudo but the fact that the ping command doesn't work and I should be root to run that makes me feel there is something wrong here!
command_line /usr/lib64/nagios/plugins/check_tcp -H $HOSTADDRESS$ -p 22
jolson
Attack Rabbit
Post
by jolson » Fri Apr 24, 2015 1:15 pm
Interesting. Let's check /etc/passwd and /etc/group:
I have a hunch that the nagios user either isn't in the proper groups or doesn't have an appropriate shell. Let me know what you find out!
Twits Blog
tezarin
Post
by tezarin » Fri Apr 24, 2015 1:24 pm
jolson wrote: Interesting. Let's check /etc/passwd and /etc/group:
You're probably right, here's the output of your command:
[root@nagios ~]# cat /etc/passwd ; cat /etc/group
root:x:0:0:root:/root:/bin/bash
bin:x:1:1:bin:/bin:/sbin/nologin
daemon:x:2:2:daemon:/sbin:/sbin/nologin
adm:x:3:4:adm:/var/adm:/sbin/nologin
lp:x:4:7:lp:/var/spool/lpd:/sbin/nologin
sync:x:5:0:sync:/sbin:/bin/sync
shutdown:x:6:0:shutdown:/sbin:/sbin/shutdown
halt:x:7:0:halt:/sbin:/sbin/halt
mail:x:8:12:mail:/var/spool/mail:/sbin/nologin
operator:x:11:0:operator:/root:/sbin/nologin
nobody:x:99:99:Nobody:/:/sbin/nologin
dbus:x:81:81:System message bus:/:/sbin/nologin
vcsa:x:69:69:Virtual console memory owner:/dev:/sbin/nologin
haldaemon:x:68:68:HAL Daemon:/:/sbin/nologin
ntp:x:38:38::/etc/ntp:/sbin/nologin
saslauth:x:499:76:"Saslauthd user":/var/empty/saslauth:/sbin/nologin
postfix:x:89:89::/var/spool/postfix:/sbin/nologin
sshd:x:74:74:Privilege-separated SSH:/var/empty/sshd:/sbin/nologin
puppet:x:52:52:Puppet User:/var/lib/puppet:/sbin/nologin
stunnel:x:600:600::/var/run/stunnel:/sbin/nologin
nscd:x:28:28:Name Service Cache Daemon:/:/sbin/nologin
clam:x:409:409:Clam Anti Virus Checker:/var/lib/clamav:/sbin/nologin
clamav:x:410:410:Clamav database update user:/var/lib/clamav:/sbin/nologin
rpcuser:x:29:29:RPC Service User:/var/lib/nfs:/sbin/nologin
rpc:x:32:32:Portmapper RPC User:/var/cache/rpcbind:/sbin/nologin
nagios:x:408:408::/var/spool/nagios:/sbin/nologin
nrpe:x:407:407:NRPE user for the NRPE service:/var/run/nrpe:/sbin/nologin
nfsnobody:x:65534:65534:Anonymous NFS User:/var/lib/nfs:/sbin/nologin
rpm:x:37:37::/var/lib/rpm:/sbin/nologin
nslcd:x:65:55:LDAP Client User:/:/sbin/nologin
capadmin:x:8001:800::/srv/home/capadmin:/bin/bash
hdfs:x:4005:405::/srv/home/hdfs:/bin/bash
contentzone:x:7201:744::/srv/home/contentzone:/bin/bash
sstore:x:7001:724::/srv/home/sstore:/bin/bash
webadmin:x:7101:734::/srv/home/webadmin:/bin/bash
apache:x:48:48:Apache:/var/www:/sbin/nologin
root:x:0:sstore
bin:x:1:daemon,root
daemon:x:2:bin,root
sys:x:3:bin,adm,root
adm:x:4:daemon,root
tty:x:5:
disk:x:6:root
lp:x:7:daemon
mem:x:8:
kmem:x:9:
wheel:x:10:root
mail:x:12:mail,postfix
man:x:15:
video:x:39:
dip:x:40:
lock:x:54:
audio:x:63:
nobody:x:99:
users:x:100:
dbus:x:81:
utmp:x:22:
utempter:x:35:
floppy:x:19:
vcsa:x:69:
cdrom:x:11:
tape:x:33:
dialout:x:18:
haldaemon:x:68:haldaemon
ntp:x:38:
saslauth:x:76:
postdrop:x:90:
postfix:x:89:
sshd:x:74:
puppet:x:52:
stunnel:x:600:
nscd:x:28:
screen:x:84:
clam:x:409:
clamav:x:410:
rpcuser:x:29:
rpc:x:32:
wbpriv:x:88:
nagios:x:408:apache
nrpe:x:407:
slocate:x:21:
nfsnobody:x:65534:
rpm:x:37:
ldap:x:55:
netdump:x:34:
contentzone:x:744:
capadmin:x:800:
webadmin:x:734:
sitestore:x:724:webadmin
hadoop:x:405:contentzone,sstore,webadmin
apache:x:48:
[root@nagios ~]# clear
root:x:0:sstore
bin:x:1:daemon,root
daemon:x:2:bin,root
adm:x:4:daemon,root
tty:x:5:
disk:x:6:root
lp:x:7:daemon
mem:x:8:
kmem:x:9:
wheel:x:10:root
man:x:15:
video:x:39:
dip:x:40:
lock:x:54:
audio:x:63:
nobody:x:99:
users:x:100:
dbus:x:81:
utmp:x:22:
utempter:x:35:
floppy:x:19:
vcsa:x:69:
cdrom:x:11:
tape:x:33:
dialout:x:18:
ntp:x:38:
saslauth:x:76:
postdrop:x:90:
postfix:x:89:
sshd:x:74:
puppet:x:52:
stunnel:x:600:
nscd:x:28:
screen:x:84:
clam:x:409:
clamav:x:410:
rpcuser:x:29:
rpc:x:32:
wbpriv:x:88:
nagios:x:408:apache
nrpe:x:407:
slocate:x:21:
nfsnobody:x:65534:
rpm:x:37:
ldap:x:55:
netdump:x:34:
contentzone:x:744:
capadmin:x:800:
webadmin:x:734:
apache:x:48:
jolson
Attack Rabbit
Post
by jolson » Fri Apr 24, 2015 2:07 pm
nagios
Would you mind changing the nagios users shell to /bin/bash?
nagios
408:408::/var/spool/nagios:/bin/bash
It's somewhat interesting that you don't have a 'nagcmd' group - but that shouldn't be a problem if nagios without that setting.
Let's check permissions on a few files:
Do any of the files in that directory have 'nagcmd' as the group? If so, we should create that group and add nagios+apache to it.
After these changes, can you switch user to nagios and run the ping command as described?
Best,
Jesse
Twits Blog
