Hello
Can i make shedule downtime by command?
this is yes, how i make?
I found this page:
https://exchange.nagios.org/directory/A ... ty/details
but i sure this run
thanks
Schedule downtime command
- Box293
- Too Basu
Re: Schedule downtime command
We can use curl to do this.
This is for the host object:
Command:
This is for the host's services:
Command:
The output you receive for the commands is a http page, but most importantly you are after this message:
Output:
I have some other examples here:
http://sites.box293.com/nagios/guides/t ... e-and-cgis
Command:
curl -d "cmd_typ=55&cmd_mod=2&host=centos03&com_data=TestingDowntime&trigger=0&start_time=03-13-2015 11:30:00&end_time=03-13-2015 11:40:00&fixed=1&childoptions=0&btnSubmit=Commit" "http://xitest/nagios/cgi-bin/cmd.cgi" -u "troylea:password"
Command:
curl -d "cmd_typ=86&cmd_mod=2&host=centos03&com_data=TestingDowntime&trigger=0&start_time=03-13-2015 11:30:00&end_time=03-13-2015 11:40:00&fixed=1&childoptions=0&btnSubmit=Commit" "http://xitest/nagios/cgi-bin/cmd.cgi" -u "troylea:password"
Output:
<P><DIV CLASS='infoMessage'>Your command request was successfully submitted to Nagios for processing.<BR><BR>
Note: It may take a while before the command is actually processed.<BR><BR>
Thank but i have got problems with permisions and i use this script:
#!/bin/sh
# Write a command to the Nagios command file to cause
# it to schedule service downtime.
# Author: Sam Tilders sam@jovianprojects.com.au
# Based on the example event handler scripts and cmd.c/.cgi
# Requires:
# GNU Date (for date formatting options)
# Bash > 2.x (for inline variable regex substitution on the comment_data)
# Notes:
# 1) In order for Nagios to process any commands that
# are written to the command file, you must enable
# the check_external_commands option in the main
# configuration file.
# Caveats:
# Using "date" to validate the command line date format doesn't always pick
# up all mistakes in the date format. Sometimes "date" seems to invent something
# that might have been what you intented.
# Makes no attempt to verify the hostname or service desc before passing them to
# the command pipe. Nagios seems to ignore the command if it doesn't match.
# it to schedule host downtime
# Example:
# A cron entry to schedule downtime for the nntp service every day at 0400 while
# other cron jobs (locate database update) slow the machine down.
# 30 0 * * * schedule_svc_downtime news NNTP "`date --iso-8601` 04:00:00" "`date --iso-8601` 05:00:00" 1 3600 auto "while cron does things"
# There are utilities such as "shellsupport" that will do date manipulation allowing shell scripts
# to wrap around this command to schedule for days in advance instead of same date.
usage()
echo "Usage: $0 <hostname> <service desc> <start time> <end time> <fixed> <duration> <user> <comment>"
echo " Times must be in the form \"CCYY-MM-DD HH:mm:ss\" and will probably need to be quoted."
echo " fixed is either 1 or 0 and indicates that the time period is fixed and duration should be ignored"
echo " length of the downtime in seconds, only used if not fixed downtime"
echo " user who is requesting the downtime"
echo " comment to place on the downtime, probably will need to be quoted."
if [ $# -lt 5 ]; then
echo "$0: Too few parameters"
usage
exit 1
fi
if [ $# -gt 5 ]; then
echo "$0: Too many parameters"
usage
exit 1
fi
hostname=$1
raw_start=$2
raw_end=$3
fixed=1
duration=""
comment_author=$4
# command is comment with ; replaced for space
comment_data=$5
#comment_data=${8/;/ }
trigger_id=0
echocmd="/bin/echo"
CommandFile="/usr/local/nagios/var/rw/nagios.cmd"
# get the current date/time in seconds since UNIX epoch
datetime=`date +%s`
start_time=`date -d "$raw_start" +%s`
if [ $? != 0 ]; then
echo "Bad format for start time."
usage
exit 1
fi
end_time=`date -d "$raw_end" +%s`
echo "Bad format for end time."
usage
exit 1
fi
if [ $fixed != 1 -a $fixed != 0 ]; then
echo "Fixed must be 1 or 0"
usage
exit 1
fi
# create the command line to add to the command file
cmdline="[$datetime] SCHEDULE_HOST_DOWNTIME;$hostname;$start_time;$end_time;$fixed;$trigger_id;$duration;$comment_author;$comment_data"
# append the command to the end of the command file
`$echocmd $cmdline >> $CommandFile`
What problems with permissions are you seeing? Can you post specific errors?
I make thw shedule downtime with that code, and this run correctly
thanks for you help
thanks for you help
If everything is working, can we close this post?
Locking.
