Hi
hav e anyone got this to work?
I'ved install NasgiosPI on a raspberry PI. Nasgaios is working with standard plugs. But, can not get it to work with Perl Plugin.
Any ideas?
Nagios Core, Raspberry PI, Perls Plugins
Re: Nagios Core, Raspberry PI, Perls Plugins
I assume you are talking about the NagiosPi distro?
http://piimagehub.com/project/nagiospi/
Just for your information, that project is not one that we control. It still runs Core so we can help somewhat in that regard, but it wouldn't hurt to post on their forums in case they made any nonstandard modifications.
What errors are you receiving when trying to run perl plugins?
Thanks for your reply.
The distrib is using Nagios3.
I'm gettting syntax error from the perl script. But, when I checked the perl script it did not contain any perl code.
I think I may have got wget command wrong.
I'll re-download the script & try again.
Great, let us know if that solves your issue.
Hi
Thanks for you help.
Yes, the problems was with downloading the perl script.
Re-download it. Checkked the file, ran simeple script.pl -h and it worked.
Next step is to add it to Nagios.
Now I know that Raspberry pi & Nagios is setup fpr perl scripts.
Thanks Again.
Thanks Again.
I'll be closing this thread now, but feel free to open another if you need anything in the future!
