I am trying to installed Nagvis at Nagios Core. But when i use username & password it shows "You are not authenticated".
I already tried automatic installation via apt-get install nagvis & also manual method but no luck. please help me.
Nagvis " You are not authenticated"
Re: Nagvis " You are not authenticated"
What version of core and nagvis are you running?
Can you post the apache vhost config for nagvis?
here is the apache2 virtual host config file
# NagVis Apache2 sample configuration file
Alias /nagvis "/usr/share/nagvis/share/"
<Directory "/usr/share/nagvis/share/">
Options FollowSymLinks
AllowOverride None
Order allow,deny
Allow from all
# To enable Nagios basic auth on NagVis use the following options
# Just uncomment it. Maybe you need to adjust the path to the
# Auth user file.
# If you use the NagVis internal auth mechanism based on the web
# for you won't need this.
#AuthName "NagVis Access"
#AuthType Basic
#AuthUserFile /usr/local/nagios/etc/htpasswd.users
#Require valid-user
# With installed and enabled mod_rewrite there are several redirections
# available to fix deprecated and/or wrong urls. None of those rules is
# mandatory to get NagVis working.
<IfModule mod_rewrite.c>
RewriteEngine On
RewriteBase /nagvis
# Use mod_rewrite for old url redirection even if there are php files which
# redirect the queries itselfs. In some cases the mod_rewrite redirect
# is better than the php redirect.
# Using the php redirect seems to be better in some cases where https/http servers
# are mixed. For example in OMD setups where using apache own mode and https in the
# frontend and http in the backend apache servers.
# Disabling this redirect by default in the hope that the php direct works better.
#RewriteCond %{REQUEST_URI} ^/nagvis(/config\.php|/index\.php|/|)(\?.*|)$
#RewriteRule ^(.*)$ /nagvis/frontend/nagvis-js/%1%2 [R=301,L]
# Redirect old regular map links
RewriteCond %{REQUEST_URI} ^/nagvis/frontend/(wui|nagvis-js)
RewriteCond %{QUERY_STRING} map=(.*)
RewriteRule ^(.*)$ /nagvis/frontend/nagvis-js/index.php?mod=Map&act=view&show=%1 [R=301,L]
# Without map= param
RewriteCond %{REQUEST_URI} ^/nagvis/frontend(/wui)?/?(index.php)?$
RewriteRule ^(.*)$ /nagvis/frontend/nagvis-js/index.php [R=301,L]
# Redirect old rotation calls
RewriteCond %{REQUEST_URI} ^/nagvis/frontend/nagvis-js
RewriteCond %{QUERY_STRING} !mod
RewriteCond %{QUERY_STRING} rotation=(.*)
RewriteRule ^(.*)$ /nagvis/frontend/nagvis-js/index.php?mod=Rotation&act=view&show=%1 [R=301,L]
</IfModule>
</Directory>
AllowOverride None
Order allow,deny
Allow from all
# Auth user file.
#AuthType Basic
#Require valid-user
RewriteEngine On
RewriteBase /nagvis
</IfModule>
</Directory>
Why did you comment out the lines below?
restart apache and try logging in NagVis again.
Change them to:#AuthName "NagVis Access"
#AuthType Basic
#Require valid-user
AuthType Basic
Require valid-user
Thanks it works
I'll be closing this thread now, but feel free to open another if you need anything in the future!
