Good morning,
I installed nagiosxi on a linux machine I wanted to know if you leave in some directory script full stop of all components(postgresql, httpd, nagios, mysql ..)
If not, I have to stop the process in some order.
Thanks for your time.
regards
Nagios complete stop
Re: Nagios complete stop
We do not have such a script, it shouldn't matter a ton, but if anything I would stop in the following order
then anything else.
Starting would be the reverse, bring all up, then
nagios
ndo2db
ndo2db
nagios
Thanks for your reply.
In the scripts /usr/local/nagiosxi/scripts/restore_xi.sh the script have the stop and start complete.
Thanks.
Thanks.
That script is used for restoring Nagios to an earlier state. I would not recommend using it to stop services.
Good morning,
I completely agree.
I wanted to indicate that in the script are the components of a complete stop.
I completely agree.
