I can't seem to find any document that discusses moving an existing installation of Nagios over to the new XI.
We would also want to move our rrd data in order to preserve historical reporting / trending.
Is there such a document?
Stuart
Upgrade from 3.x.x
Re: Upgrade from 3.x.x
We'll have a migration/upgrade document out by the end of the week for moving from a standalone Nagios Core setup to Nagios XI.
What have you used to produce your existing RRD files? XI uses PNP, so if you've been using that it shouldn't be too difficult.
Thanks Ethan.
We are indeed using PNP.
Look forward to reading up and moving over.
Cheers
Stuart
Cheers
Stuart
