Good afternoon
In that file is checked the historical alerts?
I want two things:
I want to know from the day I have alerts.
And I want to know since that day I have of monitoring data.
Thanks for your time
Regards
History
Re: History
You need to elaborate, not sure what you are talking about precisely. Are you looking for a report that shows you when alerts were triggered? I'd take a look at the Notifications list. You could also take a look at the Nagios log, you'd be able to get both of the metrics you are looking for, unless you deleted the archived logs that is.
Re: History
Thanks for your reply slansing.
What is the history of nagios.log?.
Since when is there a monitoring information?
That value is modifiable, so I just paint the last 30 days.
Regards
Regards
Re: History
Generally, they are rotated daily to archives directory and renamed to something likeRDMaroto wrote:What is the history of nagios.log?.
nagios-06-02-2014-00.log
