CHECK_NRPE: Socket timeout after 20 seconds.
Re: CHECK_NRPE: Socket timeout after 20 seconds.
Hi srein find below out put
[root@BUGZILLABCK ~]# iptables -L -n
Chain INPUT (policy ACCEPT)
target prot opt source destination
ACCEPT tcp -- 0.0.0.0/0 0.0.0.0/0 tcp dpt:5666
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
Everything is fine but i don't know the reasons to get CHECK_NRPE: Socket timeout after 20 seconds error
Whether this is any
1. Nagios server issue
2. Nagios client issue
3. Network issue
4. Other issue
Whether this is any
3. Network issue
4. Other issue
Did you run the following command on the Nagios server or on the client?
Can you temporarily disable the iptables on both boxes for testing purposes and try your check again?
Also, did you add the "[NagiosServer]" to the "only_from" line for the "clarity" sake or you actually have this line in the "/etc/xinetd.d/nrpe"?
What is the output from running the following command on the nagios server?
iptables -L -n
only_from = 127.0.0.1 192.168.30.38[NagiosServer]
./check_nrpe -H <client ip>
We have multiple client servers. So, We specified in client as
only_form=127.0.0.1 192.168.30.38.....Is there any mistake ????
Below is the client status on nagios server.
[root@nagiosserver]# nmap -p 5666 10.174.16.11(client ip)
Starting Nmap 5.51 ( http://nmap.org ) at 2014-10-01 09:30 IST
mass_dns: warning: Unable to determine any DNS servers. Reverse DNS is disabled. Try using --system-dns or specify valid servers with --dns-servers
Nmap scan report for BUGZILLABCK (10.174.16.11)
Host is up (0.039s latency).
PORT STATE SERVICE
5666/tcp filtered nrpe
Nmap done: 1 IP address (1 host up) scanned in 0.54 seconds
PORT STATE SERVICE
Did you restart xinetd after specifying:
Additionally, there is a typo in that line:
Should be:
only_from=127.0.0.1 192.168.30.38
only_form its my mistake while typing but its perfect in conf file.
Can any one help to resolve my issue ????
Yes, we have been trying to assist you.
Looks like 5666 may not be open, nmap shows it as filtered rather than open. I'd check that as it could be the culprit.5666/tcp filtered nrpe
Thanks slan
Let me know the necessary action to show the status as open for 5666/tcp
That would be a configuration that needs to be made on the remote machine. Could the admin of the remote machine be contacted about opening port 5666 for connections?
Kindly check earlier posts
1. No. 9 for nrpe status for 5666/tcp on remote machine .
2. No. 10 for iptables status for 5666/tcp on remote machine.
Let me know any modifications on nrpe conf file.
Can you run the following commands on the client (remote box) and show us the output?
ps axuw | grep nrpe
netstat -at | grep nrpe
sestatus
