dwhitfield wrote:getnameinfo is simply stating that it could not resolve a dns name to an IP. Is your dns server accessible? As for the 5666...just try running the command without the 5666.
When you say you are running npre, is /usr/local/nagios/libexec/check_nrpe -H localhost the command you are using? If not, could you post the command?
dwhitfield wrote:can you post the output of history? Either scrub as needed, or PM it to me. If you choose to PM, please update this thread after you have sent the PM.
I doubt this is the issue, but going through your history I notice you don't have the very first line, yum install -y gcc glibc glibc-common openssl-devel perl wget
Could you please work through https://support.nagios.com/kb/article.php?id=520 and then send the history again? It looks like you could post the history here if you just replace one useradd that has a -p. If you post it in the thread that means community members will also be able to help out.
dwhitfield wrote:I doubt this is the issue, but going through your history I notice you don't have the very first line, yum install -y gcc glibc glibc-common openssl-devel perl wget
This is still version 2.15. I thought you were going to install NRPE 3.0.1?
Please do this so the NRPE binary can be linked against the appropriate SSL libraries. You also have the ability to use -n = Do no use SSL in the call to check_nrpe if you want to remain with the current binary.
no i did not install nrpe 3 now you say what do i have to do ? realy confused what command do i have to tupe?
i used these commands for install nrpe on all of my linux servers but on this but last line get error
cd nrpe-2.15
./configure
make all
make install-plugin
make install-daemon
make install-daemon-config
make install-xinetd
When you run the netstat command, are you still getting this message?
getnameinfo failed
It looks like a dns problem on the server.
Make sure the server is setup in your DNS servers or that the /etc/hosts file is setup correctly for that server.
