Nagios suddenly refuses to start
Re: Nagios suddenly refuses to start
/etc/rc.d/init.d/nagios start provides the same output that I linked earlier. The systemctl command isn't found.
And The scite was set up to allow me to edit the config and save it directly to the server.
- Former Nagios Staff
Can you post your /etc/rc.d/init.d/nagios? Also, can you post the output of ls -la /etc/rc.d/init.d/nagios?
[root@devnagios ~]# /etc/rc.d/init.d/nagios
Usage: nagios {start|stop|restart|reload|force-reload|status|checkconfig}
[root@devnagios ~]# ls -la /etc/rc.d/init.d/nagios
-rwxr-xr-x 1 root root 5373 Jun 19 2014 /etc/rc.d/init.d/nagios
[root@devnagios ~]#
[root@devnagios ~]#
I wanted to see the actual script /etc/rc.d/init.d/nagios...although that modification date suggests that won't be useful.
If the output of echo $0 is bash, please run the following and then give the output
Probably, we're going to want to look at /etc/bashrc as well, although the output of .bashrc should tell you if that's the file we want.
If echo $0 is not bash, then we'll need to look in different locations for scripts, but bash is the default.
Basically, I'm trying to figure out what is calling scite.
cd /root
cat .bashrc
# .bashrc
# User specific aliases and functions
alias rm='rm -i'
alias cp='cp -i'
alias mv='mv -i'
alias preflight='/usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg'
alias diskspace="du -h / | grep -P '^[0-9\.]+G'"
alias clearmailqueues='for f in /var/spool/mqueue/* ; do rm -f "$f"; done && for f in /var/spool/clientmqueue/* ; do rm -f "$f"; done'
# Source global definitions
if [ -f /etc/bashrc ]; then
. /etc/bashrc
fi
# /etc/bashrc
# System wide functions and aliases
# Environment stuff goes in /etc/profile
# are we an interactive shell?
if [ "$PS1" ]; then
if [ -z "$PROMPT_COMMAND" ]; then
case $TERM in
xterm*)
if [ -e /etc/sysconfig/bash-prompt-xterm ]; then
PROMPT_COMMAND=/etc/sysconfig/bash-prompt-xterm
else
PROMPT_COMMAND='printf "\033]0;%s@%s:%s\007" "${USER}" "${HOSTNAME%%.*}" "${PWD/#$HOME/~}"'
fi
screen)
if [ -e /etc/sysconfig/bash-prompt-screen ]; then
PROMPT_COMMAND=/etc/sysconfig/bash-prompt-screen
else
PROMPT_COMMAND='printf "\033]0;%s@%s:%s\033\\" "${USER}" "${HOSTNAME%%.*}" "${PWD/#$HOME/~}"'
fi
[ -e /etc/sysconfig/bash-prompt-default ] && PROMPT_COMMAND=/etc/sysconfig/bash-prompt-default
esac
fi
# Turn on checkwinsize
shopt -s checkwinsize
[ "$PS1" = "\\s-\\v\\\$ " ] && PS1="[\u@\h \W]\\$ "
fi
if ! shopt -q login_shell ; then # We're not a login shell
# Need to redefine pathmunge, it get's undefined at the end of /etc/profile
pathmunge () {
if ! echo $PATH | /bin/egrep -q "(^|:)$1($|:)" ; then
if [ "$2" = "after" ] ; then
PATH=$PATH:$1
else
PATH=$1:$PATH
fi
fi
# By default, we want umask to get set. This sets it for non-login shell.
# You could check uidgid reservation validity in
# /usr/share/doc/setup-*/uidgid file
if [ $UID -gt 99 ] && [ "`id -gn`" = "`id -un`" ]; then
umask 002
else
umask 022
fi
# Only display echos from profile.d scripts if we are no login shell
# and interactive - otherwise just process them to set envvars
for i in /etc/profile.d/*.sh; do
if [ -r "$i" ]; then
if [ "$PS1" ]; then
. $i
else
. $i >/dev/null 2>&1
fi
fi
done
unset i
unset pathmunge
fi
# vim:ts=4:sw=4
If it's helpful, here's the nagios script:
#!/bin/sh
# chkconfig: 345 99 01
# description: Nagios network monitor
# File : nagios
# Author : Jorge Sanchez Aymar (jsanchez@lanchile.cl)
# Changelog :
# 1999-07-09 Karl DeBisschop <kdebisschop@infoplease.com>
# - setup for autoconf
# - add reload function
# 1999-08-06 Ethan Galstad <egalstad@nagios.org>
# - Added configuration info for use with RedHat's chkconfig tool
# per Fran Boon's suggestion
# 1999-08-13 Jim Popovitch <jimpop@rocketship.com>
# - added variable for nagios/var directory
# - cd into nagios/var directory before creating tmp files on startup
# 1999-08-16 Ethan Galstad <egalstad@nagios.org>
# - Added test for rc.d directory as suggested by Karl DeBisschop
# 2000-07-23 Karl DeBisschop <kdebisschop@users.sourceforge.net>
# - Clean out redhat macros and other dependencies
# 2003-01-11 Ethan Galstad <egalstad@nagios.org>
# - Updated su syntax (Gary Miller)
# Description: Starts and stops the Nagios monitor
# used to provide network services status.
mkdir -p -m 775 /dev/shm/nagios
mkdir -p -m 775 /dev/shm/nagios/tmp
mkdir -p -m 775 /dev/shm/nagios/spool
mkdir -p -m 775 /dev/shm/nagios/spool/checkresults
chown -R nagios.nagios /dev/shm/nagios
status_nagios ()
if test -x $NagiosCGI/daemonchk.cgi; then
if $NagiosCGI/daemonchk.cgi -l $NagiosRunFile; then
return 0
else
return 1
fi
else
if ps -p $NagiosPID > /dev/null 2>&1; then
return 0
else
return 1
fi
fi
return 1
printstatus_nagios()
if status_nagios $1 $2; then
echo "nagios (pid $NagiosPID) is running..."
else
echo "nagios is not running"
fi
killproc_nagios ()
kill $2 $NagiosPID
pid_nagios ()
if test ! -f $NagiosRunFile; then
echo "No lock file found in $NagiosRunFile"
exit 1
fi
NagiosPID=`head -n 1 $NagiosRunFile`
# Source function library
# Solaris doesn't have an rc.d directory, so do a test first
if [ -f /etc/rc.d/init.d/functions ]; then
. /etc/rc.d/init.d/functions
elif [ -f /etc/init.d/functions ]; then
. /etc/init.d/functions
fi
prefix=/usr/local/nagios
exec_prefix=${prefix}
NagiosBin=${exec_prefix}/bin/nagios
NagiosCfgFile=${prefix}/etc/nagios.cfg
NagiosStatusFile=${prefix}/var/status.dat
NagiosRetentionFile=${prefix}/var/retention.dat
NagiosCommandFile=${prefix}/var/rw/nagios.cmd
NagiosVarDir=${prefix}/var
NagiosRunFile=${prefix}/var/nagios.lock
NagiosLockDir=/var/lock/subsys
NagiosLockFile=nagios
NagiosCGIDir=${exec_prefix}/sbin
NagiosUser=nagios
NagiosGroup=nagios
# Check that nagios exists.
if [ ! -f $NagiosBin ]; then
echo "Executable file $NagiosBin not found. Exiting."
exit 1
fi
# Check that nagios.cfg exists.
if [ ! -f $NagiosCfgFile ]; then
echo "Configuration file $NagiosCfgFile not found. Exiting."
exit 1
fi
# See how we were called.
case "$1" in
start)
echo -n "Starting nagios:"
$NagiosBin -v $NagiosCfgFile > /dev/null 2>&1;
if [ $? -eq 0 ]; then
su - $NagiosUser -c "touch $NagiosVarDir/nagios.log $NagiosRetentionFile"
rm -f $NagiosCommandFile
touch $NagiosRunFile
chown $NagiosUser:$NagiosGroup $NagiosRunFile
$NagiosBin -d $NagiosCfgFile
if [ -d $NagiosLockDir ]; then touch $NagiosLockDir/$NagiosLockFile; fi
echo " done."
exit 0
else
echo "CONFIG ERROR! Start aborted. Check your Nagios configuration."
exit 1
fi
stop)
echo -n "Stopping nagios: "
pid_nagios
killproc_nagios nagios
# now we have to wait for nagios to exit and remove its
# own NagiosRunFile, otherwise a following "start" could
# happen, and then the exiting nagios will remove the
# new NagiosRunFile, allowing multiple nagios daemons
# to (sooner or later) run - John Sellens
#echo -n 'Waiting for nagios to exit .'
for i in 1 2 3 4 5 6 7 8 9 10 ; do
if status_nagios > /dev/null; then
echo -n '.'
sleep 1
else
break
fi
done
echo ''
echo 'Warning - nagios did not exit in a timely manner'
else
echo 'done.'
fi
rm -f $NagiosStatusFile $NagiosRunFile $NagiosLockDir/$NagiosLockFile $NagiosCommandFile
status)
pid_nagios
printstatus_nagios nagios
checkconfig)
printf "Running configuration check..."
echo " OK."
else
echo " CONFIG ERROR! Check your Nagios configuration."
exit 1
fi
restart)
echo "done."
$0 stop
$0 start
else
echo " CONFIG ERROR! Restart aborted. Check your Nagios configuration."
exit 1
fi
reload|force-reload)
echo "done."
$0 start
else
pid_nagios
printf "Reloading nagios configuration..."
killproc_nagios nagios -HUP
echo "done"
else
$0 stop
$0 start
fi
fi
else
echo " CONFIG ERROR! Reload aborted. Check your Nagios configuration."
exit 1
fi
echo "Usage: nagios {start|stop|restart|reload|force-reload|status|checkconfig}"
exit 1
esac
# End of this script
I'm still digging. Can you post the output of sh -x /etc/init.d/nagios start?
[root@devnagios etc]# sh -x /etc/init.d/nagios start
+ mkdir -p -m 775 /dev/shm/nagios
+ mkdir -p -m 775 /dev/shm/nagios/tmp
+ mkdir -p -m 775 /dev/shm/nagios/spool
+ mkdir -p -m 775 /dev/shm/nagios/spool/checkresults
+ chown -R nagios.nagios /dev/shm/nagios
+ '[' -f /etc/rc.d/init.d/functions ']'
+ . /etc/rc.d/init.d/functions
++ TEXTDOMAIN=initscripts
++ umask 022
++ PATH=/sbin:/usr/sbin:/bin:/usr/bin
++ export PATH
++ '[' -z '' ']'
++ COLUMNS=80
++ '[' -z '' ']'
+++ /sbin/consoletype
++ CONSOLETYPE=pty
++ '[' -f /etc/sysconfig/i18n -a -z '' ']'
++ . /etc/profile.d/lang.sh
+++ sourced=0
+++ '[' -z '' -a -n en_US.UTF-8 ']'
+++ sourced=1
+++ '[' -n '' ']'
+++ '[' 1 = 1 ']'
+++ '[' -n en_US.UTF-8 ']'
+++ export LANG
+++ '[' -n '' ']'
+++ unset LC_ADDRESS
+++ '[' -n '' ']'
+++ unset LC_CTYPE
+++ '[' -n '' ']'
+++ unset LC_COLLATE
+++ '[' -n '' ']'
+++ unset LC_IDENTIFICATION
+++ '[' -n '' ']'
+++ unset LC_MEASUREMENT
+++ '[' -n '' ']'
+++ unset LC_MESSAGES
+++ '[' -n '' ']'
+++ unset LC_MONETARY
+++ '[' -n '' ']'
+++ unset LC_NAME
+++ '[' -n '' ']'
+++ unset LC_NUMERIC
+++ '[' -n '' ']'
+++ unset LC_PAPER
+++ '[' -n '' ']'
+++ unset LC_TELEPHONE
+++ '[' -n '' ']'
+++ unset LC_TIME
+++ '[' -n '' ']'
+++ unset LC_ALL
+++ '[' -n '' ']'
+++ unset LANGUAGE
+++ '[' -n '' ']'
+++ unset LINGUAS
+++ '[' -n '' ']'
+++ unset _XKB_CHARSET
+++ consoletype=pty
+++ '[' -z pty ']'
+++ '[' -n '' ']'
+++ '[' -n '' ']'
+++ case $LANG in
+++ '[' xterm = linux ']'
+++ unset SYSFONTACM SYSFONT
+++ unset sourced
+++ unset langfile
++ '[' -z '' ']'
++ '[' -f /etc/sysconfig/init ']'
++ . /etc/sysconfig/init
+++ BOOTUP=color
+++ GRAPHICAL=yes
+++ RES_COL=60
+++ MOVE_TO_COL='echo -en \033[60G'
+++ SETCOLOR_SUCCESS='echo -en \033[0;32m'
+++ SETCOLOR_FAILURE='echo -en \033[0;31m'
+++ SETCOLOR_WARNING='echo -en \033[0;33m'
+++ SETCOLOR_NORMAL='echo -en \033[0;39m'
+++ LOGLEVEL=3
+++ PROMPT=yes
+++ AUTOSWAP=no
++ '[' pty = serial ']'
++ '[' color '!=' verbose ']'
++ INITLOG_ARGS=-q
++ __sed_discard_ignored_files='/\(~\|\.bak\|\.orig\|\.rpmnew\|\.rpmorig\|\.rpmsave\)$/d'
+ prefix=/usr/local/nagios
+ exec_prefix=/usr/local/nagios
+ NagiosBin=/usr/local/nagios/bin/nagios
+ NagiosCfgFile=/usr/local/nagios/etc/nagios.cfg
+ NagiosStatusFile=/usr/local/nagios/var/status.dat
+ NagiosRetentionFile=/usr/local/nagios/var/retention.dat
+ NagiosCommandFile=/usr/local/nagios/var/rw/nagios.cmd
+ NagiosVarDir=/usr/local/nagios/var
+ NagiosRunFile=/usr/local/nagios/var/nagios.lock
+ NagiosLockDir=/var/lock/subsys
+ NagiosLockFile=nagios
+ NagiosCGIDir=/usr/local/nagios/sbin
+ NagiosUser=nagios
+ NagiosGroup=nagios
+ '[' '!' -f /usr/local/nagios/bin/nagios ']'
+ '[' '!' -f /usr/local/nagios/etc/nagios.cfg ']'
+ case "$1" in
+ echo -n 'Starting nagios:'
Starting nagios:+ /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
+ '[' 0 -eq 0 ']'
+ su - nagios -c 'touch /usr/local/nagios/var/nagios.log /usr/local/nagios/var/retention.dat'
+ rm -f /usr/local/nagios/var/rw/nagios.cmd
+ touch /usr/local/nagios/var/nagios.lock
+ chown nagios:nagios /usr/local/nagios/var/nagios.lock
+ /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
+ '[' -d /var/lock/subsys ']'
+ touch /var/lock/subsys/nagios
+ echo ' done.'
done.
+ exit 0
What's the output of ls -la /etc/sysconfig/init?
Also, in that /etc/sysconfig/init file, if you have a line that says GRAPHICAL=yes, change it to GRAPHICAL=no.
Whether this exists or not is going to depend on a number of things. It shows up as yes on my CentOS 5 install without issue, but it should help us bypass the gtk issue.
-rw-r--r-- 1 root root 1068 Mar 19 2014 /etc/sysconfig/init
And I've made the change to no on graphical.
On both the dev and the prod can you run rpm -qa nagios and give the output? Also, can you check and make sure all the files we've asked for so far are the same on dev and prod?
We might getting to the point where you just clone the prod to make a new dev. How far you want to go before that is up to you though.
