On some busy MSSQL Servers we often have a high CPU load which is displayed with values over 100%, as you see in the example here with
18,446,744,073,660,160,000% (wow ).
Why does this happen and is it possible to correct this display error so that only 100% is displayed at full load?
CPU-Load > 100%
CPU-Load > 100%
- cpu-load.png (5.28 KiB) Viewed 21192 times
Re: CPU-Load > 100%
Hi @sandro.isoletta, thanks for reaching out.
Which plugin/check command is giving you the crazy CPU load values?
-Laura
-Laura
Re: CPU-Load > 100%
Hi and thank you for your answer.
I've just took a look (nagios was not configured by me, I am new in this company). The command is:
/usr/lib/nagios/plugins/check_nt -H $HOSTADDRESS$ -s $USER6$ -v CPULOAD -l 15,90,99,60,70,85
Re: CPU-Load > 100%
The check_nt plugin used the NSClient++ agent that is running on the Windows system and it may be a bug wit the version that you are using and you should upgrade it.
You can find it here
https://nsclient.org/
Another cause is the counters need to be rebuilt on the Windows server.
https://learn.microsoft.com/en-US/troub ... ary-values
Thank you.
Thank you.
