CHECK_NRPE: Receive header underflow - only 0 bytes received (4 expected)
Post Reply
pnikhade
Post by pnikhade »
Hi All,
I had installed Nagios core on EC2 instance and when trying to check load on the remote server, I am getting the below response by executing the command,
./check_nrpe -H 13.201.39.252 -c check_load -a -w .15,.10,.05 -c .30,.25,.20
CHECK_NRPE: Receive header underflow - only 0 bytes received (4 expected).
I read somewhere to run --enable-command-args with ./configure but still not working. Any ideas so as to resolve this ?
Piyush Nikhade
danderson
Re: CHECK_NRPE: Receive header underflow - only 0 bytes received (4 expected)
Post by danderson »
Thanks for reaching out @pnikhade,
I found this article especially helpful
https://assets.nagios.com/downloads/nag ... e/NRPE.pdf
I was able to replicate your issue and resolve it. You have two options.
Enable Command Line Arguments
Open up /usr/local/nagios/etc/nrpe.cfg or wherever the nrpe configuration is on the remote server you are trying to check
Go to the commands section. You'll see a line like so
command[check_load]=/usr/local/nagios/libexec/check_load -r -w .15,.10,.05 -c .30,.25,.20
Change this to
command[check_load]=/usr/local/nagios/libexec/check_load $ARG1$
Then, go to a line that looks like so
dont_blame_nrpe=0
Change it to
dont_blame_nrpe=1
Restart the nrpe service and try again.
The main issue with this is that it is inherintely insecure because any plugin can effectively control the shell. This is why it's recommended to
Alter the Command In the Configuration File
Instead of changing the check_load command to include $ARG1$, simply update the command line arguments in the config file to be what you want
command[check_load]=/usr/local/nagios/libexec/check_load -w .15,.10,.05 -c .30,.25,.20
In this case you won't have to edit anything, and the check command would now be
Let me know if you need any more help
jehofem507
Post by jehofem507 »
danderson wrote: Mon Apr 15, 2024 2:23 pm Thanks for reaching out @pnikhade,
Change this to
dont_blame_nrpe=0
Change it to
dont_blame_nrpe=1
The main issue with this is that it is inherintely insecure because any plugin can effectively control the shell uno online. This is why it's recommended to
Thanks, it helps.
Post Reply
