check_service: UNKNOWN: No handler for that command
Post Reply
Lebenshilfe
Post by Lebenshilfe »
I try the following command:
./check_nrpe -H X.X.X.X -c check_service -a service=spooler
but I get a wrong result:
I don`t understand why, because check_service is includet at check_nrpe
Can someone help me?
Thank you.
danderson
Re: check_service: UNKNOWN: No handler for that command
Post by danderson »
Thanks for reaching out @Lebenshilfe,
What version of NRPE are you using and what does the check_service plugin look like?
kg2857
Post by kg2857 »
It looks like you can get that response from a host running nsclient and check_service isn't in the nsclient config...
Lebenshilfe
Yes, I get this response from a host, how can I include the check_service at the nsclient?
I use the version 0.3.9 of the nsclient and I use the version 2.13 of nrpe
kg2857
Post by kg2857 »
You can add it to the nsclient.ini and/or see if nsclient has an internal service check.
Post Reply
