Livestatus support for Nagios 4.5.1
Post Reply
kaushalshriyan
Post by kaushalshriyan »
# rpm -qa | grep thruk
libthruk-3.00-0.x86_64
thruk-base-3.14.2-12970.1.x86_64
thruk-3.14.2-12970.1.x86_64
thruk-plugin-reporting-3.14.2-12970.1.x86_64
# cat /etc/redhat-release
Red Hat Enterprise Linux release 8.9 (Ootpa)
# pwd
/usr/local/nagios/var/rw
# ls -l
total 0
srw-rw---- 1 nagios nagios 0 Apr 16 08:30 livestatus
prw-rw---- 1 nagios nagios 0 Apr 16 08:30 nagios.cmd
srw-rw---- 1 nagios nagios 0 Apr 16 08:30 nagios.qh
# echo "GET status" | /usr/local/bin/unixcat /usr/local/nagios/var/rw/livestatus
accept_passive_host_checks;accept_passive_service_checks;cached_log_messages;check_external_commands;check_host_freshness;check_service_freshness;connections;connections_rate;enable_event_handlers;enable_flap_detection;enable_notifications;execute_host_checks;execute_service_checks;external_command_buffer_max;external_command_buffer_slots;external_command_buffer_usage;external_commands;external_commands_rate;forks;forks_rate;host_checks;host_checks_rate;interval_length;last_command_check;last_log_rotation;livecheck_overflows;livecheck_overflows_rate;livechecks;livechecks_rate;livestatus_active_connections;livestatus_queued_connections;livestatus_threads;livestatus_version;log_messages;log_messages_rate;mk_inventory_last;nagios_pid;neb_callbacks;neb_callbacks_rate;num_hosts;num_services;obsess_over_hosts;obsess_over_services;process_performance_data;program_start;program_version;requests;requests_rate;service_checks;service_checks_rate
1;1;0;1;0;1;4;0.0321792;1;1;1;1;1;0;0;0;0;0;0;0;1;0.0107264;60;0;0;0;0;0;0;1;0;10;1.5.0p23;12;0.128717;0;10926;52;0.914182;1;1;0;0;0;1713236448;4.5.1;4;0.0321792;1;0.084375
# /usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg
Nagios Core 4.5.1
Last Modified: 2024-02-28
License: GPL
Reading configuration data...
   Read main config file okay...
Checking objects...
	Checked 8 services.
	Checked 1 hosts.
	Checked 1 host groups.
	Checked 0 service groups.
	Checked 1 contacts.
	Checked 1 contact groups.
	Checked 24 commands.
	Checked 5 time periods.
	Checked 0 host escalations.
	Checked 1 hosts
	Checked 0 host dependencies
	Checked 5 timeperiods
Checking misc settings...
Total Warnings: 0
Total Errors:   0
# systemctl status nagios.service
● nagios.service - Nagios Core 4.5.1
   Loaded: loaded (/usr/lib/systemd/system/nagios.service; enabled; vendor preset: disabled)
   Active: active (running) since Tue 2024-04-16 08:30:48 IST; 2min 40s ago
     Docs: https://www.nagios.org/documentation
  Process: 10791 ExecStopPost=/usr/bin/rm -f /usr/local/nagios/var/rw/nagios.cmd (code=exited, status=0/SUCCESS)
  Process: 10924 ExecStart=/usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg (code=exited, status=0/SUCCESS)
  Process: 10923 ExecStartPre=/usr/local/nagios/bin/nagios -v /usr/local/nagios/etc/nagios.cfg (code=exited, status=0/SUCCESS)
 Main PID: 10926 (nagios)
    Tasks: 17 (limit: 48838)
   Memory: 7.0M
   CGroup: /system.slice/nagios.service
           ├─10926 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
           ├─10927 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
           ├─10928 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
           ├─10929 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
           ├─10930 /usr/local/nagios/bin/nagios --worker /usr/local/nagios/var/rw/nagios.qh
           └─10935 /usr/local/nagios/bin/nagios -d /usr/local/nagios/etc/nagios.cfg
Apr 16 08:30:49 niranjan nagios[10926]: livestatus: TIMEPERIOD TRANSITION: 24x7_sans_holidays;-1;1
Apr 16 08:30:49 niranjan nagios[10926]: livestatus: TIMEPERIOD TRANSITION: none;-1;0
Apr 16 08:30:49 niranjan nagios[10926]: livestatus: TIMEPERIOD TRANSITION: us-holidays;-1;0
Apr 16 08:30:49 niranjan nagios[10926]: livestatus: TIMEPERIOD TRANSITION: workhours;-1;0
Apr 16 08:30:49 niranjan nagios[10926]: livestatus: Timeperiod cache not updated, there are no timeperiods (yet)
Apr 16 08:30:49 niranjan nagios[10926]: livestatus: starting main thread and 10 client threads
Apr 16 08:30:49 niranjan nagios[10926]: livestatus: default stack size is 8388608
Apr 16 08:30:49 niranjan nagios[10926]: livestatus: setting thread stack size to 1048576
Apr 16 08:31:58 niranjan nagios[10926]: livestatus: Timeperiod cache not updated, there are no timeperiods (yet)
Apr 16 08:32:58 niranjan nagios[10926]: livestatus: Timeperiod cache not updated, there are no timeperiods (yet)
I am encountering the below issue whenever I restart
`491: failed to connect - failed to connect to /usr/local/nagios/var/rw/livestatus: Connection refused at /usr/share/thruk/lib/Monitoring/Livestatus/UNIX.pm line 72.
	eval {...} called at /usr/share/thruk/lib/Monitoring/Livestatus/UNIX.pm line 64
	Monitoring::Livestatus::UNIX::_open(Monitoring::Livestatus::UNIX=HASH(0x55c2a9d93f70)) called at /usr/share/thruk/lib/Monitoring/Livestatus.pm line 971
	Monitoring::Livestatus::_open(Monitoring::Livestatus=HASH(0x55c2a92c7618)) called at /usr/share/thruk/lib/Monitoring/Livestatus.pm line 1143
	Monitoring::Livestatus::_send_socket_do(Monitoring::Livestatus=HASH(0x55c2a92c7618), "GET status\x{a}Columns: accept_passive_host_checks accept_passive_service_checks check_external_commands check_host_freshness check_service_freshness enable_event_handlers enable_flap_detection enable_notifications execute_host_checks execute_service_checks last_command_check last_log_rotation livestatus_version nagios_pid obsess_over_hosts obsess_over_services process_performance_data program_start program_version interval_length\x{a}OutputFormat: json\x{a}ResponseHeader: fixed16\x{a}") called at /usr/share/thruk/lib/Monitoring/Livestatus.pm line 1111
	eval {...} called at /usr/share/thruk/lib/Monitoring/Livestatus.pm line 1101
	Monitoring::Livestatus::_send_socket(Monitoring::Livestatus=HASH(0x55c2a92c7618), "GET status\x{a}Columns: accept_passive_host_checks accept_passive_service_checks check_external_commands check_host_freshness check_service_freshness enable_event_handlers enable_flap_detection enable_notifications execute_host_checks execute_service_checks last_command_check last_log_rotation livestatus_version nagios_pid obsess_over_hosts obsess_over_services process_performance_data program_start program_version interval_length\x{a}OutputFormat: json\x{a}ResponseHeader: fixed16\x{a}") called at /usr/share/thruk/lib/Monitoring/Livestatus.pm line 823
	Monitoring::Livestatus::_send(Monitoring::Livestatus=HASH(0x55c2a92c7618), "GET status\x{a}Columns: accept_passive_host_checks accept_passive_service_checks check_external_commands check_host_freshness check_service_freshness enable_event_handlers enable_flap_detection enable_notifications execute_host_checks execute_service_checks last_command_check last_log_rotation livestatus_version nagios_pid obsess_over_hosts obsess_over_services process_performance_data program_start program_version interval_length", HASH(0x55c2a9d70fb8)) called at /usr/share/thruk/lib/Monitoring/Livestatus.pm line 302
	Monitoring::Livestatus::selectall_arrayref(Monitoring::Livestatus=HASH(0x55c2a92c7618), "GET status\x{a}Columns: accept_passive_host_checks accept_passive_service_checks check_external_commands check_host_freshness check_service_freshness enable_event_handlers enable_flap_detection enable_notifications execute_host_checks execute_service_checks last_command_check last_log_rotation livestatus_version nagios_pid obsess_over_hosts obsess_over_services process_performance_data program_start program_version interval_length", HASH(0x55c2a8d08788)) called at /usr/share/thruk/lib/Monitoring/Livestatus/Class/Lite.pm line 420
	Monitoring::Livestatus::Class::Lite::_execute(Monitoring::Livestatus::Class::Lite=HASH(0x55c2a8f6ddc0)) called at /usr/share/thruk/lib/Monitoring/Livestatus/Class/Lite.pm line 278
	Monitoring::Livestatus::Class::Lite::hashref_array(Monitoring::Livestatus::Class::Lite=HASH(0x55c2a8f6ddc0)) called at /usr/share/thruk/lib/Monitoring/Livestatus/Class/Lite.pm line 259
	Monitoring::Livestatus::Class::Lite::hashref_pk(Monitoring::Livestatus::Class::Lite=HASH(0x55c2a8f6ddc0), "peer_key") called at /usr/share/thruk/lib/Thruk/Backend/Provider/Livestatus.pm line 304
	Thruk::Backend::Provider::Livestatus::get_processinfo(Thruk::Backend::Provider::Livestatus=HASH(0x55c2a8e717a0)) called at /etc/thruk/plugins//plugins-enabled/conf/lib/Thruk/Controller/conf.pm line 903
	eval {...} called at /etc/thruk/plugins//plugins-enabled/conf/lib/Thruk/Controller/conf.pm line 896`
# cat nagios.log
[1713237093] Nagios 4.5.1 starting... (PID=12405)
[1713237093] Local time is Tue Apr 16 08:41:33 IST 2024
[1713237093] LOG VERSION: 2.0
[1713237093] qh: Socket '/usr/local/nagios/var/rw/nagios.qh' successfully initialized
[1713237093] qh: core query handler registered
[1713237093] qh: echo service query handler registered
[1713237093] qh: help for the query handler registered
[1713237093] wproc: Successfully registered manager as @wproc with query handler
[1713237093] wproc: Registry request: name=Core Worker 12408;pid=12408
[1713237093] wproc: Registry request: name=Core Worker 12409;pid=12409
[1713237093] wproc: Registry request: name=Core Worker 12410;pid=12410
[1713237093] wproc: Registry request: name=Core Worker 12411;pid=12411
[1713237093] livestatus: fl_socket_path=[/usr/local/nagios/var/rw/livestatus], fl_mkeventd_socket_path=[/usr/local/nagios/var/rw/mkeventd/status]
[1713237093] livestatus: Livestatus by Mathias Kettner started with PID 12405
[1713237093] livestatus: version 1.5.0p23 compiled Tue, 09 Apr 2024 21:24:02 +0530 on niranjan
[1713237093] livestatus: built with g++ (GCC) 8.5.0 20210514 (Red Hat 8.5.0-20), using C++11 regex engine
[1713237093] livestatus: Using socket at '/usr/local/nagios/var/rw/livestatus'
[1713237093] livestatus: Please visit us at http://mathias-kettner.de/
[1713237093] livestatus: Hint: Please try out OMD - the Open Monitoring Distribution
[1713237093] livestatus: Please visit OMD at http://omdistro.org
[1713237093] livestatus: removed old socket file /usr/local/nagios/var/rw/livestatus
[1713237093] livestatus: opened UNIX socket at /usr/local/nagios/var/rw/livestatus
[1713237093] livestatus: your event_broker_options are sufficient for livestatus..
[1713237093] livestatus: finished initialization, further log messages go to /usr/local/nagios/var/livestatus.log
[1713237093] Event broker module '/opt/local/livestatus/livestatus.o' initialized successfully.
[1713237094] Successfully launched command file worker with pid 12417
[1713237094] livestatus: TIMEPERIOD TRANSITION: 24x7;-1;1
[1713237094] livestatus: TIMEPERIOD TRANSITION: 24x7_sans_holidays;-1;1
[1713237094] livestatus: TIMEPERIOD TRANSITION: none;-1;0
[1713237094] livestatus: TIMEPERIOD TRANSITION: us-holidays;-1;0
[1713237094] livestatus: TIMEPERIOD TRANSITION: workhours;-1;0
[1713237094] livestatus: Timeperiod cache not updated, there are no timeperiods (yet)
[1713237094] livestatus: starting main thread and 10 client threads
[1713237094] livestatus: default stack size is 8388608
[1713237094] livestatus: setting thread stack size to 1048576
[1713237097] Caught SIGSEGV, shutting down...
[1713237097] Caught SIGTERM, shutting down...
Please guide me. Thanks in advance.
Best Regards,
Kaushal
kaushalshriyan
Re: Livestatus support for Nagios 4.5.1
I'm checking in again to see if someone can pitch in regarding my earlier post to this forum. Thanks in advance, and I look forward to hearing from you.
Best Regards,
Kaushal
kaushalshriyan
Best Regards,
Kaushal
kg2857
Post by kg2857 »
What does the livestatus log say?
kaushalshriyan
I have used https://github.com/Checkmk/checkmk/tree/1.2.8 to configure livestatus using Nagios core 4.5.2. Initially it works while configuring livestatus. Next when i click on hosts link or any other link in thruk webinterface, it crashes.
1;1;0;1;0;1;5;1.6875000000e-01;1;1;1;1;1;-674217344;-674217344;-674217344;0;0.0000000000e+00;0;0.0000000000e+00;1;8.4375000000e-02;60;-674217344;0;0;0.0000000000e+00;0;0.0000000000e+00;1;0;10;1.2.8p28;0;0.0000000000e+00;0;378497;17;8.9062500000e-01;1;1;0;0;0;1714880853;4.5.2;4;4.5000000000e-01;0;0.0000000000e+00
Nagios Core 4.5.2
Last Modified: 2024-04-30
License: GPL
Checking objects...
	Checked 8 services.
	Checked 1 hosts.
	Checked 1 contacts.
	Checked 1 hosts
Total Warnings: 0
Total Errors:   0
[1714880853] Nagios 4.5.2 starting... (PID=378497)
[1714880853] Local time is Sun May 05 09:17:33 IST 2024
[1714880853] LOG VERSION: 2.0
[1714880853] qh: Socket '/usr/local/nagios/var/rw/nagios.qh' successfully initialized
[1714880853] qh: core query handler registered
[1714880853] qh: echo service query handler registered
[1714880853] qh: help for the query handler registered
[1714880853] wproc: Successfully registered manager as @wproc with query handler
[1714880853] wproc: Registry request: name=Core Worker 378498;pid=378498
[1714880853] wproc: Registry request: name=Core Worker 378500;pid=378500
[1714880853] wproc: Registry request: name=Core Worker 378499;pid=378499
[1714880853] wproc: Registry request: name=Core Worker 378501;pid=378501
[1714880853] livestatus: Livestatus 1.2.8p28 by Mathias Kettner. Socket: '/usr/local/nagios/var/rw/livestatus'
[1714880853] livestatus: Please visit us at http://mathias-kettner.de/
[1714880853] livestatus: Hint: please try out OMD - the Open Monitoring Distribution
[1714880853] livestatus: Please visit OMD at http://omdistro.org
[1714880853] livestatus: Removed old left over socket file /usr/local/nagios/var/rw/livestatus
[1714880853] livestatus: Finished initialization. Further log messages go to /usr/local/nagios/var/livestatus.log
[1714880853] Event broker module '/opt/local/livestatus/livestatus.o' initialized successfully.
[1714880853] Successfully launched command file worker with pid 378502
[1714880853] TIMEPERIOD TRANSITION: 24x7;-1;1
[1714880853] TIMEPERIOD TRANSITION: 24x7_sans_holidays;-1;1
[1714880853] TIMEPERIOD TRANSITION: none;-1;0
[1714880853] TIMEPERIOD TRANSITION: us-holidays;-1;0
[1714880853] TIMEPERIOD TRANSITION: workhours;-1;0
[1714880891] SERVICE ALERT: localhost;HTTP;WARNING;HARD;4;HTTP WARNING: HTTP/1.1 403 Forbidden - 5233 bytes in 0.001 second response time
[1714880934] Caught SIGSEGV, shutting down...
[1714880934] Caught SIGTERM, shutting down...
Couldn't connect to UNIX-socket at /usr/local/nagios/var/rw/livestatus: Connection refused.
kg2857
Post by kg2857 »
There's no livestatus log?
kaushalshriyan
I do not have anything written in /usr/local/nagios/var/livestatus.log file
# pwd
# ls -l
total 60
drwxrwxr-x 2 nagios nagios     6 May  4 07:12 archives
-rw-r--r-- 1 nagios nagios     0 May  5 08:51 livestatus.log
-rw-r--r-- 1 nagios nagios  8574 May  5 09:18 nagios.log
-rw-r--r-- 1 nagios nagios 12755 May  5 09:17 objects.cache
-rw------- 1 nagios nagios 13119 May  4 07:21 retention.dat
drwxrwsr-x 2 nagios nagcmd    41 May  5 09:18 rw
drwxr-xr-x 3 nagios nagios    26 May  4 07:12 spool
-rw-rw-r-- 1 nagios nagios 13634 May  5 09:18 status.dat
Post Reply
