time definitions can't be deleted in timeperiod (missing button)
Post Reply
CBoekhuis
Post by CBoekhuis »
I need to change / delete a time definition in a timeperiod, but now I noticed that the delete buttons are gone.
I checked this by using other users (including nagiosadmin), different themes and different browsers, no difference.
Is this a bug, or a problem in our installation? We are running Nagios XI 2024R1.1.1 on RHEL 8.9.
Since I haven't edited a timeperiod for quite a while, I dont know when this occured.
Greetings......Hans
sgardil
Re: time definitions can't be deleted in timeperiod (missing button)
Post by sgardil »
CBoekhuis wrote: Wed Apr 24, 2024 3:57 am Hello,
Greetings......Hans
Hey Hans,
Thats right that there should be an x to delete the time periods. Do you see any errors in the /var/log/php-fpm or possibly in the console log?
swolf
Developer
Post by swolf »
Greetings......Hans
Hello Hans,
This is a known issue, and will be fixed in Nagios XI 2024R1.1.3. We apologize for any inconvenience in the meantime.
-Sebastian
As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new Privacy Policy
CBoekhuis
Post by CBoekhuis »
Ok, thanks for the heads-up. I'll wait for the new release.
voltogyre
Post by voltogyre »
as a work around I used the "import config files" to import the same timeperiod with new information, then went back to view if the modification took place... saved... applied and it seems to be working
Post Reply
