upgrading nagios-fusion with .OVA vmware image
I am currently running Nagios-Fusion 4.0.0 on a .ova image via VMWare workstation player. I can see 4.0.1 is available now. Since this is an image, I assume I just need to download the latest .OVA image and run it. I assume I wouldn't upgrade the existing image. Has anyone tried it though?
https://www.nagios.com/downloads/nagios-fusion/vmware/
- Support Tech
Re: upgrading nagios-fusion with .OVA vmware image
Hello, @dxk9_dtman. OVA is basically an image of the whole computer. You can't install one OVA on top of the other. You can run a new OVA instead of the old one but you'll lose all your configurations.
To update an existing fusion please connect to the Virtual Machine using ssh and type the following command:
curl https://assets.nagios.com/downloads/nagiosfusion/upgrade.sh | sh
Thanks, so it looks like you are saying its FINE to upgrade nagios-fusion running and installed from the OVF/OVA file. At least a minor version upgrade. Good to know. Still I wanted to back it up first, back up my configs.
[root@nagios-fusion scripts]# ./backup_fusion.sh
Backing up Nagios Fusion directory...
tar: Removing leading `/' from member names
Backing up MySQL databases...
mysqldump: Couldn't execute 'SHOW TRIGGERS LIKE 'polled\_extras'': Got error 28 from storage engine (1030)
Error backing up MySQL database 'fusion' - check the password in this script!
- Support Tech
@dxk9_dtman, Hmm, looks like there's a password issue. Have you changed any MySQL passwords recently? What version of Fusion are you running right now? And were you running the script as a sudo?
Let's see if you can authenticate to MySQL with standard credentials:
Finally, please upload the contents of the backup_fusion.sh script here.
mysql -u root -pfusion
Nagios Fusion 4.0.0
full=4.0.0
major=4
minor=0.0
releasedate=2017-07-17
release=4000
[root@nagios-fusion scripts]# df -h
/dev/mapper/VolGroup-lv_root
37G 24G 12G 66% /
tmpfs 931M 0 931M 0% /dev/shm
/dev/sda1 477M 95M 357M 22% /boot
I was able to take a backup a few months ago. ls -la 1502307633.tar.gz
7804057 Aug 9 15:41 1502307633.tar.gz
Have I changed any passwords?
nope, never touched mysql
RE: mysql -u root -pfusion
Yes, I could get in that way, I connected in fine.
So, the test shows the password has not changed, yet I get this. Same result if its prefixed with 'sudo'
[root@nagios-fusion ~]# /usr/local/nagiosfusion/scripts/backup_fusion.sh
mysqldump: Got errno 28 on write
One strange thing is that fusion-sys.cfg does show the correct password for the db, however when you run it by hand you have no space between the -p and password and it works. If you add the space manually, it does not work.
Another thing I noticed is that cfg_database_fusion_user is fusion not root. Manually (just running the mysql command I can connect with both root and the fusion user, using the default password.
Why is there an import script, but no output script?
Breaking down the above backup script manually and running each piece works. For example I just ran the mysqldump command to /store/backups/fusion_dump.sql and it seems to be running fine. Actually, I had to kill it. It was 99% full disk space up to 17 GB on the dump. So, I need to figure out how the db got this big and how to get rid or archive some .
full=4.0.0
major=4
minor=0.0
release=4000
37G 24G 12G 66% /
[root@nagios-fusion scripts]# cat backup_fusion.sh
#!/bin/bash
BASEDIR=$(dirname $(readlink -f $0))
# Import all CFG variables
. $BASEDIR/../var/fusion-sys.cfg
php $BASEDIR/import_fusionconfig.php > $BASEDIR/config.dat
. $BASEDIR/config.dat
rm $BASEDIR/config.dat
BACKUPLOG="$proddir/var/log/backup.log"
ts=`date +%s`
# USAGE / HELP
usage () {
echo ""
echo "Use this script to backup Nagios Fusion."
echo ""
echo " -n | --name Set the full name of the backup minus the .tar.gz"
echo " -p | --prepend Prepend a string to the .tar.gz name (ignored when using -n)"
echo " -a | --append Append a string to the .tar.gz name (ignored when using -n)"
echo " -d | --directory Change the directory to store the compressed backup"
echo ""
# ADDING LOGIC FOR NEW BACKUPS
while [ -n "$1" ]; do
case "$1" in
-h | --help)
usage
exit 0
-n | --name)
fullname=$2
-p | --prepen)dm
prepend=$2"."
-a | --append)
append="."$2
-d | --directory)
rootdir=$2
esac
shift
done
if [ -z $rootdir ]; then
rootdir="/store/backups/nagiosfusion"
fi
# Move to root dir to store backups
cd $rootdir
# SET THE NAME & TIME
name=$fullname
if [ -z $fullname ]; then
name=$prepend$ts$append
fi
# Get current Unix timestamp as name
if [ -z $name ]; then
name=$ts
fi
# My working directory
mydir=$rootdir/$name
# Make directory for this specific backup
mkdir -p $mydir
# BACKUP DIRS
echo "Backing up Nagios Fusion directory..."
tar czfp $mydir/nagiosfusion.tar.gz /usr/local/nagiosfusion
# BACKUP DATABASES
mkdir -p $mydir/mysql
echo "Backing up MySQL databases..."
mysqldump -h $cfg__database__fusion__host -u $cfg__database__fusion__user --password="$cfg__database__fusion__pass" --add-drop-database -B $cfg__database__fusion__dbname > $mydir/mysql/fusion.sql
res=$?
if [ $res != 0 ]; then
echo "Error backing up MySQL database 'fusion' - check the password in this script!" | tee -a $BACKUPLOG
rm -r $mydir
exit $res;
fi
# BACKUP CRONJOB ENTRIES
mkdir -p $mydir/cron
echo "Backing up nagiosfusion cronjob..."
cp /etc/cron.d/nagiosfusion $mydir/cron/nagiosfusion
echo "Backing up cronjobs for Apache..."
cp /var/spool/cron/apache $mydir/cron/apache
# BACKUP SUDOERS
sudoers=/etc/sudoers.d/nagiosfusion
if [ -f "$sudoers" ]; then
mkdir -p $mydir/sudoers
echo "Backing up nagiosfusion sudoers.d file..."
cp $sudoers $mydir/sudoers
fi
# BACKUP LOGROTATE
echo "Backing up logrotate config files..."
mkdir -p $mydir/logrotate
cp -rp /etc/logrotate.d/nagiosfusion $mydir/logrotate
# BACKUP APACHE CONFIG FILES
echo "Backing up Apache config files..."
mkdir -p $mydir/httpd
cp -rp $httpdconfdir/nagiosfusion.conf $mydir/httpd
# COMPRESS BACKUP
echo "Compressing backup..."
tar czfp $name.tar.gz $name
rm -rf $name
# Change ownership
chown $nagiosuser:$nagiosgroup $name.tar.gz
if [ -s $name.tar.gz ];then
echo " "
echo "==============="
echo "BACKUP COMPLETE"
echo "Backup stored in $rootdir/$name.tar.gz"
exit 0;
else
echo " "
echo "BACKUP FAILED"
echo "File was not created at $rootdir/$name.tar.gz"
rm -r $mydir
exit 1;
fi
[root@nagios-fusion scripts]# ./import_fusionconfig.php --help
cfg__root_dir='/usr/local/nagiosfusion'
cfg__base_url='/nagiosfusion'
cfg__database__connection_timeout=10
cfg__database__fusion__type='mysql'
cfg__database__fusion__user='fusion'
cfg__database__fusion__pass='fusion'
cfg__database__fusion__host='localhost'
cfg__database__fusion__port=''
cfg__database__fusion__dbname='fusion'
cfg__database__fusion__persist=1
- Former Nagios Staff
This article says it is for XI, but it should work for fusion as well: https://assets.nagios.com/downloads/nag ... M-Disk.pdf
It's not able to complete because you are running out of disk space.
Thanks, for this article on the re-sizing.
My first thought was to figure out why or how/where/why its storing so much data, and get rid of some. We certainly don't need to keep four months of data around. How do I trim the fat?
It's hard to believe that with just retaining data for 5 days (the default), I'm using 24 GB of storage. I knocked it down to 3 days, but I'm still showing 24 GB used.
[root@nagios-fusion cron]# df -h
37G 24G 12G 66% /
Here is the culprit. How can I reduce the size? Do I need to restart something to switch from 5 to 3 days retention/purge?
-rw-rw---- 1 mysql mysql 22936551424 Nov 30 11:10 ibdata1
Why is the polled extras table so big? 21 GB?? how do we contain it ?
polling has now stopped on this server. I just ran the truncate_polled script as advised on another post. However, I'm still seeing the same size.
37G 24G 12G 66% /
- Support Tech
@dxk9_dtman
The polled_extras data table contains only the data that is used and rendered by fusion at the present moment. The way Fusion works is it downloads a lot of data from the XI servers, including checks, all possible parameters, and many other data. So if the XI servers have thousands of checks, i'd say 22gb is not an unordinary size for this table.
You may check the box that says "Ignore XI host/service meta data" in the Fused server settings. That should reduce the data consumption if that is your main concern.
When you changed the retention period Fusion was supposed to automatically cut off the outdated data.My first thought was to figure out why or how/where/why its storing so much data, and get rid of some. We certainly don't need to keep four months of data around. How do I trim the fat?
At this point all our Nagios servers are Core, so its not an option.
I went ahead and upgraded to 4.0.1. Since this is nagios fusion not nagios xi the auto script for making the file size bigger didn't work. No harm was done it just rebooted and kept my same file size.
So my only issue is that I can't do a backup because my table is too big. The truncate_poller.php script must not look at the polled_extras table, and switching from 5 to 3 days retention has NO effect on the polled_extras table.
Does anyone know how to purge the polled_extras table?
- Support Tech
@dxk9_dtman , You can truncate that data table with the following command:
echo "truncate table polled_extras;" | mysql -u fusion -pfusion fusion
I'm sorry I didn't specify. That option can actually be enabled in Fusion. So if you click on Servers menu, and click on settings next to the individual fused server, you'll see it. You can check that box to potentially lower the disk consumption.At this point all our Nagios servers are Core, so it's not an option.
