This support forum board is for questions relating to
Nagios Fusion.
dxk9_dtman
Post
by dxk9_dtman »
I ran the truncate and optimize commands earlier today, neither one purged the 22GB talble size of polled_extras.
echo "truncate polled_extras" | mysql -ufusion -pfusion -Dfusion
echo "optimize table polled_extras" | mysql -ufusion -pfusion -Dfusion
Attached a screen shot so you can see I don't have that option for the metadata.
Unmanaged growth of that table isn't sustainable. This article mentions Nagios has a developer looking into it, as recently as August of this year
https://webcache.googleusercontent.com/ ... clnk&gl=us
- Former Nagios Staff
Post
by dwhitfield »
I spoke to the developer mentioned in your link. That will be added in Fusion 4.1.
Unfortunately, since those are InnoDB, there's no good way to reclaim the space. If you really don't want to increase your disk space, take a look at
https://dba.stackexchange.com/questions ... -databases
dxk9_dtman
Post
by dxk9_dtman »
Ok, thanks.
So, for 4.1, we'll plan to go to a new VM image and add that setting.
npolovenko
- Support Tech
Post
by npolovenko »
@dxk9_dtman, Sounds good. Or you may ssh to the existing VM when the update comes out and run the following command:
curl https://assets.nagios.com/downloads/nagiosfusion/upgrade.sh | sh
This will upgrade Nagios Fusion without a need to import all settings to the new VM.
As of May 25th, 2018, all communications with Nagios Enterprises and its employees are covered under our new
Privacy Policy.
