Upgraded Nagios XI to R1.5 today and I'm experiencing an issue with my home dashboard now. I'm unable to click on the pin / float icon (blue arrow) so I'm unable to move the dashlets on top of the dashboard. Ok, I hear you think, just delete and recreate the dashboard, but this is not possible as it is the home dashboard..
Please advice what to do about this small issue.
Grtz
Willem
Unable to access Pin / Float dashlet icon
Nagios XI 5.8.1
https://outsideit.net
Re: Unable to access Pin / Float dashlet icon
Does if help if you click on the blue arrow in the upper-left corner first?
Ludmill, yes that worked fine.
I've got another issue with arranging dashlets on dashboards. When a dashboards has several dashlets arranged vertically and the dashlets surpass the first page, meaning you have to scroll down to see the dashlets in the bottom. It is almost impossible to rearrange dashboards in the top half of the page because the page keeps scrolling down to the bottom while dragging a dashlet.
Any advice to handle this?
Tx
Grtz
Willem
Tx
Grtz
Willem
Nagios XI 5.8.1
Odd. This was a bug that was fixed quite a while ago. Do you see this behavior in multiple browsers?
I was using Firefox at work when I had the issue. I did found a workaround. When I Control-Scrolled Down and made everything very small, I could rearrange the dashlets.
Grtz
Willem
Grtz
Willem
Nagios XI 5.8.1
I guess we will need to revisit this bug and discuss it with our developers. Thanks for the feedback!
You are welcome. Thread can be closed. Grtz
Nagios XI 5.8.1
Closing it.
