Database Backend Is Not Running
mcwhorts
Post by mcwhorts »
So I just upgraded Nagios XI to 2014R2.7 and now it says that the database backend isn't running. The VM was rebooted. I've tried manually starting the database and it still says the database backend isn't running. Any ideas?
jolson
Attack Rabbit
Re: Database Backend Is Not Running
Post by jolson »
It looks like mysql is running fine, but ndo2db might be stopped. Please try the following:
service ndomod start
What is the output of that command?
Which database backend is not running, and how did you try to start it?
Twits Blog
mcwhorts
Post by mcwhorts »
ndomod: unrecognized service
To restart the database I tried running
service mysqld restart
and
service ndo2db restart
returned
Stopping mysqld: [ OK ]
Starting mysqld: [ OK ]
and
ndo2db was not running... could not stop
Starting ndo2db: done.
is the correct command.
Does the system recognize that the Database Backend is now running?
mcwhorts
Post by mcwhorts »
No it still shows that it's not running from the GUI.
mcwhorts
Post by mcwhorts »
I am seeing this in the system profile
"ndo2db is not running but subsystem locked"
Try this to clear the lock file that could be left over during the upgrade.
service ndo2db stop
rm /usr/local/nagios/var/ndo2db.lock
service ndo2db start
service nagios restart
mcwhorts
Post by mcwhorts »
It is still showing that the database backend isn't running :(
jolson
Attack Rabbit
Post by jolson »
Sorry, I posted the incorrect command.
It's also worth noting that there could be a hanging .sock file - check the following location for it:
ls /usr/local/nagios/var/ndo.sock
If the socket remains and the program is not running, feel free to delete the socket and restart:
rm /usr/local/nagios/var/ndo.sock
Twits Blog
mcwhorts
Post by mcwhorts »
Unfortunately, nothing has changed. It still says DB backend isn't running.
