Hi, thanks for your help guys. Good now.
To fix the last thing that was wrong these yum modules needed to be installed (thx mweber!) and plugin versions updated.
# yum install -y perl-Mail-IMAPClient perl-Email-Simple perl-IO-Socket-SSL perl-Text-Template perl- Date-Manip
Plugin versions tested:
1. check_smtp_send = 0.7.2
2. check_imap_receive = 0.7.5
3. check_email_delivery = 0.7.1
# ./check_email_delivery --plugin "/usr/local/nagios/libexec/check_smtp_send -H smpthost --mailto [email protected] --mailfrom noreply-ngs.com --header 'Subject: Nagios Test %TOKEN12345%.'" --plugin "/usr/local/nagios/libexec/check_imap_receive -H imaphost -p 143 -U Ngs -P 'pmon' --nodelete -s SUBJECT -s 'Nagios Test %TOKEN12345%.'"
EMAIL DELIVERY OK - 6 seconds, 0 delay | delay=0s;95;300;0 elapsed=6s
check_email_delivery plugin issue probably syntax
Re: check_email_delivery plugin issue probably syntax
