I am trying to install Nagios Network Analyzer on CentOS 7.
I used the "manual download" method as described in the installation guide:
cd /tmp
wget https://assets.nagios.com/downloads/nagios-network-analyzer/nagiosna-latest.tar.gz
tar xzf nagiosna-latest.tar.gz
cd nagiosna
./fullinstall
Now I get much farther into the install and it fails with this:
[snip]
build_nfdump step completed OK
Running 'library_path'...
library_path step completed OK
Running 'nagiosna'...
nagiosna step completed OK
Running 'backend'...
backend step completed OK
Running 'db'...
Redirecting to /bin/systemctl restart mariadb.service
Failed to restart mariadb.service: Unit not found.
INSTALLATION ERROR!
in your communications with Nagios Enterprises technical support.
The step that failed was: 'db'
[root@cj9rcl002 nagiosna]#
TIA
-russ
