troubleshooting sources
Greetings,
it might seem an odd question but is there a troubleshooting guide for sources?
I have several sources showing "no data" as the traffic in the last 30 minutes.
But if I take a look in /usr/local/nagiosna/var/source_name/flows ,I can find files written recently.
Kindest regards
Kindest regards
Re: troubleshooting sources
Hi @Hoygen
The knowledgebase article below covers some reasons why data may not be showing up. Let me know if this helps resolves your issue.
Nagios Network Analyzer - Graph Says "No Data Available"
https://support.nagios.com/kb/article/n ... le-32.html
Another cause could be the time is not set correctly on the NNA server or the devices that are sending the flow data.
Make sure that the time did not change on the server.
I've read it.
I've read also here https://assets.nagios.com/downloads/nag ... ackend.pdf
it's strange because:
a) netstat -nl | grep 1060
udp 0 0 0.0.0.0:1060 0.0.0.0:*
shows the port as listening.
b) tcpdump dst port 1060 -vv
shows packets
c) ps aux | grep nfcapd | grep 1060
shows the process
d) iptables -nL | grep 1060
ACCEPT udp -- 0.0.0.0/0 0.0.0.0/0 udp dpt:1060
iptables is open
but the graph shows no data available.
is there anywhere else I should look or do to make it work?
shows packets
shows the process
iptables is open
Can you run the following command on the NNA server
let it run for a while (e.g. a few minutes), exit by running ctrl +c, and upload the 1060.cap file that was generated from running the above command?
Also, run:
and show the output in code wraps. Please, substitute '<source_name>' with the actual name of your source.
tcpdump -i any -s 65535 -w 1060.cap port 1060
Also, run:
rrdtool dump /usr/local/nagiosna/var/<source_name>/bandwidth.rrd
grep -2 '<source_name>' /usr/local/nagiosna/var/backend.log | tail
at the time I can't upload the rrdtool dump or the tcpdump.
should I look for something peculiar inside them?
grep -2 'STAB1CS01' /usr/local/nagiosna/var/backend.log | tail
2018-10-24 15:40:00 INFO : Parsing data for the source id: 88
2018-10-24 15:40:00 DEBUG : Arguments: /usr/local/nagiosna/var/STAB1CS01/flows, nfcapd.201810241535, 88
2018-10-24 15:40:00 DEBUG : Running checks...
2018-10-24 15:40:00 DEBUG : Getting relevant checks for source id: 88
2018-10-24 15:45:00 DEBUG : Arguments: /usr/local/nagiosna/var/MPLS_pri_Castenaso/flows, nfcapd.201810241540, 25
2018-10-24 15:45:00 INFO : Parsing data for the source id: 88
2018-10-24 15:45:00 DEBUG : Arguments: /usr/local/nagiosna/var/STAB1CS01/flows, nfcapd.201810241540, 88
2018-10-24 15:45:00 DEBUG : Running checks...
the rrddump shows, cleaning the output
<?xml version="1.0" encoding="utf-8"?>
<!DOCTYPE rrd SYSTEM "http://oss.oetiker.ch/rrdtool/rrdtool.dtd">
<!-- Round Robin Database Dump -->
<rrd>
<version>0003</version>
<step>300</step> <!-- Seconds -->
<lastupdate>1540294056</lastupdate> <!-- 2018-10-23 13:27:36 CEST -->
<ds>
<name> flows </name>
<type> GAUGE </type>
<minimal_heartbeat>600</minimal_heartbeat>
<min>0.0000000000e+00</min>
<max>NaN</max>
<!-- PDP Status -->
<last_ds>U</last_ds>
<value>NaN</value>
<unknown_sec> 156 </unknown_sec>
</ds>
<ds>
<name> bytes </name>
<max>NaN</max>
<!-- PDP Status -->
<value>NaN</value>
</ds>
<ds>
<name> packets </name>
<max>NaN</max>
<!-- PDP Status -->
<value>NaN</value>
</ds>
<ds>
<name> bps </name>
<max>NaN</max>
<!-- PDP Status -->
<value>NaN</value>
</ds>
<ds>
<name> pps </name>
<max>NaN</max>
<!-- PDP Status -->
<value>NaN</value>
</ds>
<ds>
<name> bpp </name>
<max>NaN</max>
<!-- PDP Status -->
<value>NaN</value>
</ds>
<!-- Round Robin Archives -->
<rra>
<cf>AVERAGE</cf>
<pdp_per_row>1</pdp_per_row> <!-- 300 seconds -->
<params>
<xff>5.0000000000e-01</xff>
</params>
<cdp_prep>
<ds>
<primary_value>0.0000000000e+00</primary_value>
<secondary_value>0.0000000000e+00</secondary_value>
<value>NaN</value>
<unknown_datapoints>0</unknown_datapoints>
</ds>
<ds>
<value>NaN</value>
</ds>
<ds>
<value>NaN</value>
</ds>
<ds>
<value>NaN</value>
</ds>
<ds>
<value>NaN</value>
</ds>
<ds>
<value>NaN</value>
</ds>
</cdp_prep>
<database>
<!-- 2018-08-23 16:35:00 CEST / 1535034900 --> <row><v>NaN</v><v>NaN</v><v>NaN</v><v>NaN</v><v>NaN</v><v>NaN</v></row>
<!-- 2018-10-23 13:00:00 CEST / 1540292400 --> <row><v>NaN</v><v>NaN</v><v>NaN</v><v>NaN</v><v>NaN</v><v>NaN</v></row>
</database>
</rra>
<rra>
<cf>AVERAGE</cf>
<pdp_per_row>288</pdp_per_row> <!-- 86400 seconds -->
<params>
</params>
<cdp_prep>
<ds>
<value>NaN</value>
<unknown_datapoints>137</unknown_datapoints>
</ds>
<ds>
<value>NaN</value>
</ds>
<ds>
<value>NaN</value>
</ds>
<ds>
<value>NaN</value>
</ds>
<ds>
<value>NaN</value>
</ds>
<ds>
<value>NaN</value>
</ds>
</cdp_prep>
<database>
<!-- 2017-10-24 02:00:00 CEST / 1508803200 --> <row><v>NaN</v><v>NaN</v><v>NaN</v><v>NaN</v><v>NaN</v><v>NaN</v></row>
<!-- 2018-10-23 02:00:00 CEST / 1540252800 --> <row><v>NaN</v><v>NaN</v><v>NaN</v><v>NaN</v><v>NaN</v><v>NaN</v></row>
</database>
</rra>
<rra>
<cf>HWPREDICT</cf>
<params>
<hw_alpha>1.0000000000e-01</hw_alpha>
<hw_beta>3.5000000000e-03</hw_beta>
<dependent_rra_idx>4</dependent_rra_idx>
</params>
<cdp_prep>
<ds>
<intercept>NaN</intercept>
<last_intercept>NaN</last_intercept>
<slope>NaN</slope>
<last_slope>NaN</last_slope>
<nan_count>1</nan_count>
<last_nan_count>1</last_nan_count>
</ds>
<ds>
<slope>NaN</slope>
</ds>
<ds>
<slope>NaN</slope>
</ds>
<ds>
<slope>NaN</slope>
</ds>
<ds>
<slope>NaN</slope>
</ds>
<ds>
<slope>NaN</slope>
</ds>
</cdp_prep>
<database>
<!-- 2018-10-18 13:30:00 CEST / 1539862200 --> <row><v>NaN</v><v>NaN</v><v>NaN</v><v>NaN</v><v>NaN</v><v>NaN</v></row>
<!-- 2018-10-23 13:25:00 CEST / 1540293900 --> <row><v>NaN</v><v>NaN</v><v>NaN</v><v>NaN</v><v>NaN</v><v>NaN</v></row>
</database>
</rra>
<rra>
<cf>SEASONAL</cf>
<params>
<seasonal_gamma>1.0000000000e-01</seasonal_gamma>
<seasonal_smooth_idx>214</seasonal_smooth_idx>
<dependent_rra_idx>3</dependent_rra_idx>
</params>
<cdp_prep>
<ds>
<seasonal>NaN</seasonal>
<last_seasonal>NaN</last_seasonal>
<init_flag>1</init_flag>
</ds>
<ds>
</ds>
<ds>
</ds>
<ds>
</ds>
<ds>
</ds>
<ds>
</ds>
</cdp_prep>
<database>
<!-- 2018-10-22 13:30:00 CEST / 1540207800 --> <row><v>NaN</v><v>NaN</v><v>NaN</v><v>NaN</v><v>NaN</v><v>NaN</v></row>
</database>
</rra>
<rra>
<cf>DEVSEASONAL</cf>
<params>
</params>
<cdp_prep>
<ds>
</ds>
<ds>
</ds>
<ds>
</ds>
<ds>
</ds>
<ds>
</ds>
<ds>
</ds>
</cdp_prep>
<database>
</database>
</rra>
<rra>
<cf>DEVPREDICT</cf>
<params>
<dependent_rra_idx>5</dependent_rra_idx>
</params>
<cdp_prep>
<ds>
</ds>
<ds>
</ds>
<ds>
</ds>
<ds>
</ds>
<ds>
</ds>
<ds>
</ds>
</cdp_prep>
<database>
</database>
</rra>
<rra>
<cf>FAILURES</cf>
<params>
<delta_pos>2.0000000000e+00</delta_pos>
<delta_neg>2.0000000000e+00</delta_neg>
<window_len>9</window_len>
<failure_threshold>7</failure_threshold>
</params>
<cdp_prep>
<ds>
<history>000000000</history>
</ds>
<ds>
</ds>
<ds>
</ds>
<ds>
</ds>
<ds>
</ds>
<ds>
</ds>
</cdp_prep>
<database>
</database>
</rra>
</rrd>
Can you go to this folder on the NNA server, get a few of the latest nfcapd files and upload them to the post so we can view the data that the NNA server is capturing?
I don't have any issue with MPLS_pri_Castenaso on port 1050tgriep wrote:Can you go to this folder on the NNA server, get a few of the latest nfcapd files and upload them to the post so we can view the data that the NNA server is capturing?Code: Select all
I have issues with STAB1CS01 on port 1060 for example and many others
here are the nfcapd files from STAB1CS01 https://ufile.io/055uw
here is the file 1060.cap https://ufile.io/h14sr output of tcpdump -i any -s 65535 -w 1060.cap port 1060
Sorry about selecting the wrong source name.
The nfcapd files that you posted are empty and do not have any data which matches what you see in the GUI.
I am having troubles decoding the tcpdump file and it may not be sending valid data which is why the nfcapd files are empty.
Typically, when you do not see any data in the cap files, it could be that the device is not sending flow data, or that is is blocked or in a wrong format.
The inability to decode the tcpdump file kind of points to the wrong format issue.
What is the make and model number of the device that is sending the flow data?
What format of flow data is it configured to send?
Can you post it's configuration settings so we can verify they are configured for the NNA server?
Thanks.
Thanks.
Cisco, model WS-C3850-48XS
I can't provide more details right now
