z
Commercial Support Clients: Clients with support contracts can get escalated support assistance by visiting Nagios Answer Hub. These forums are for community support services. Although we at Nagios try our best to help out on the forums here, we always give priority support to our support clients.
nagios network analyzer and dell Force10 switch monitoring i
Postby SnowranCruzick » Fri Dec 09, 2022 2:05 am
I setup nagios network analyzer and trying to monitor a Dell Force10 switch, i enabled sflow in Force10 side as follows:
DELL-S4048-K13#show sflow
sFlow services are enabled
Egress Management Interface sFlow services are disabled
Global default sampling rate: 256
Global default counter polling interval: 15
Global default extended maximum header size: 256 bytes
Global extended information enabled: switch
2 collectors configured
Collector IP addr: 10.62.73.158, Agent IP addr: 10.62.91.245, UDP port: 6343
VRF: Default
Collector IP addr: 10.32.98.202, Agent IP addr: 10.62.91.245, UDP port: 6343
VRF: Default
0 UDP packets exported
357 UDP packets dropped
0 sFlow samples collected
stack-unit 1 Port set 0
Te 1/1: configured rate 256, actual rate 256
Te 1/2: configured rate 256, actual rate 256
In nagios NA server i'm trying to add a source, in type of sFlow, with IP and port of Dell Force10 enter.
Unluckly no data is collected.
Anyone has success experience in monitor a Dell Force10 switch in Nagios?
Thanks.
SnowranCruzick
Return to Nagios Network Analyzer
Users browsing this forum: No registered users and 2 guests
