The Saleae Logic Analyzer to monitor the signals exchanged.
I have been using the Saelee Logic Analyzer to monitor the signals exchanged among the boards of my embedded network. What is monitoring method do you use? What do you use? I find it really cool, but do you have any other recommendations?
Re: The Saleae Logic Analyzer to monitor the signals exchanged.
That's interesting! I personally haven't used the Saelee Logic Analyzer before, but I have experience with other tools like Wireshark and tcpdump for monitoring network traffic. Depending on your specific needs, these tools might be worth checking out as well. Additionally, there are other logic analyzers on the market, such as Saleae and Digilent, that you may want to consider as alternatives. Ultimately, the best monitoring tool for you will depend on your specific requirements and preferences.
