I have Nagios Core 3.5.1 on Ubuntu and monitoring remote Windows 7.
I installed NSClient++ there, the check_nt plugins work. Currently, I started to play with check_nrpe and I would ask for help.
I declared on remote host in the nsclient.ini:
[/settings/external scripts/alias]
alias_test = CheckDriveSize FilterType=FIXED matching=.*[CD].* ShowAll=long CheckAll $ARG1$ $ARG2$ $ARG3$ $ARG4$
root@ubuntu:/usr/local/nagios/libexec# ./check_nrpe -H xxx.xxx.xx.xxx -c alias_test
OK C:\: Total: 78.702GB - Used: 18.597GB (24%) - Free: 60.105GB (76%), D:\: Total: 81.295GB - Used: 3.49GB (5%) - Free: 77.804GB (95%)|'C:\ used'=18.59669GB;62.96171;70.83193;0;78.70214 'C:\ used %'=24%;80;90;0;100 'D:\ used'=3.49046GB;65.03593;73.16542;0;81.29491 'D:\ used %'=4%;80;90;0;100
I've tried various combinations found (changes in commands.cfg, windows.cfg) on the internet, but the effect is that I always have "Status Information: (Return code of 127 is out of bounds - plugin may be missing)"
I will mention that I also have a problem with the plugin check_nrpe. On the example of check_users, where:
In commands.cfg:
command_name check_nrpe
command_line $USER1$/check_nrpe -H $HOSTADDRESS$ -c $ARG1$
# The following examples use hardcoded command arguments...
host_name StacjaWindows
service_description nrpe_Users
check_command check_nrpe!check_users
On command line:
root@ubuntu:/usr/local/nagios/libexec# ./check_nrpe -H xxx.xxx.xx.xxx -c check_users
Unknown command(s): check_users
Regards
