This is the output of the tcpdump
[root@monitor]# tcpdump -i any port 2001
tcpdump: listening on any, link-type LINUX_SLL (Linux cooked), capture size 262144 bytes
13:05:54.347220 IP (tos 0x0, ttl 64, id 15029, offset 0, flags [DF], proto UDP (17), length 96)
monitor.example.com.45501 > dmp.example.com.wizard: [bad udp cksum 0x30ce -> 0x2955!] UDP, length 68
I tried $, \\, \t, \r and \x. None of it worked. The send string still show up as text. I need to encode the send string as HEX; not standard text.
[root@monitor]# /usr/local/nagios/libexec/check_udp -v -H 10.200.6.195 -p 2001 -w 60 -s "$02$33$34$41$38$20$20$31$32$33$34$35$20$73$30$37$30$30$30$33$30$20$0D" -e "02 31 32 33 34 35 06 0D"
Using service UDP
Port: 2001
flags: 0x6
Send string: -bash2341800123450307000300-bashD
server_expect_count: 1
0: 02 31 32 33 34 35 06 0D
CRITICAL - Socket timeout
[root@monitor]# /usr/local/nagios/libexec/check_udp -H 10.101.6.195 -v -p 2001 -s "\\02\\33\\34\\41\\38\\20\\20\\31\\32\\33\\34\\35\\20\\73\\30\\37\\30\\30\\30\\33\\30\\20\\0d" -e "\\0212345\\06"
Using service UDP
Port: 2001
flags: 0x2
Send string: \02\33\34\41\38\20\20\31\32\33\34\35\20\73\30\37\30\30\30\33\30\20\0d
0: \0212345\06
\t
[root@monitor]# /usr/local/nagios/libexec/check_udp -H 10.101.6.195 -p 2001 -v -s "\t02\t33\t34\t41\t38\t20\t20\t31\t32\t33\t34\t35\t20\t73\t30\t37\t30\t30\t30\t33\t30\t20\t0d" -e "\\0212345\\06"
Using service UDP
Port: 2001
flags: 0x2
Send string: \t02\t33\t34\t41\t38\t20\t20\t31\t32\t33\t34\t35\t20\t73\t30\t37\t30\t30\t30\t33\t30\t20\t0d
0: \0212345\06
\r
[root@monitor]# /usr/local/nagios/libexec/check_udp -H 10.101.6.195 -p 2001 -v -s "\r02\r33\r34\r41\r38\r20\r20\r31\r32\r33\r34\r35\r20\r73\r30\r37\r30\r30\r30\r33\r30\r20\r0d" -e "\\0212345\\06"
Using service UDP
Port: 2001
flags: 0x2
Send string: \r02\r33\r34\r41\r38\r20\r20\r31\r32\r33\r34\r35\r20\r73\r30\r37\r30\r30\r30\r33\r30\r20\r0d
0: \0212345\06
\x
[root@monitorj]# /usr/local/nagios/libexec/check_udp -H 10.101.6.195 -p 2001 -v -s "\x02\x33\x34\x41\x38\x20\x20\x31\x32\x33\x34\x35\x20\x73\x30\x37\x30\x30\x30\x33\x30\x20\x0d" -e "\\0212345\\06"
Using service UDP
Port: 2001
flags: 0x2
Send string: \x02\x33\x34\x41\x38\x20\x20\x31\x32\x33\x34\x35\x20\x73\x30\x37\x30\x30\x30\x33\x30\x20\x0d
0: \0212345\06
Anyone know of a way to encode the send string as HEX using check_udp? The way I tried sending hex from the monitoring system which is recognized by the destination is
echo '023730353820203132333435207330373030303033200d' | xxd -r -p |nc -u -v -w 15 10.101.6.195 2001
[root@monitor]# tcpdump -vv -i any port 2001
13:30:07.073763 IP (tos 0x0, ttl 64, id 35790, offset 0, flags [DF], proto UDP (17), length 51)
monitor.example.com.55030 > dmp.example.com.wizard: [bad udp cksum 0x303e -> 0x0e8a!] UDP, length 23
13:30:07.214791 IP (tos 0x0, ttl 126, id 10081, offset 0, flags [none], proto UDP (17), length 36)
dmp.example.com.wizard > monitor.example.com.55030: [udp sum ok] UDP, length 8
Thank you.
