Hi expert
I like to know if there is the way to log in into Nagios application using Active Directory
Does it exist a way to make this integration whit nagios core ?
Emilio
Nagios 4.2.1 - and Active Directory Integration
Re: Nagios 4.2.1 - and Active Directory Integration
This is more of an Apache question since Nagios Core piggy-backs off Apache for it's authentication. To which the answer is yes, you can have Apache use AD for it's basic authentication:
https://httpd.apache.org/docs/trunk/mod ... _ldap.html
