Hi
We have a requirement, we need to set up monitoring asm disk.
asm_pmon_+ASM is the Oracle ASM Instance
We got the below link.
https://exchange.nagios.org/directory/P ... sm/details
We downloaded check_asm plugin
we tried at command prompt.
[root@host1]# ./check_asm --asm_home=/oracle/gridhome --action=diskstatus
sh: /oracle/gridhome/bin/sqlplus: No such file or directory
[OK] Disk status:
I logged in as oracle user and tried to find out the path of ASM_HOME but noting is getting displayed.
[root@host1]# su - oracle
Last login: Fri Dec 27 19:38:25 NZDT 2019 on pts/0
[oracle@host1]
$ echo $ASM_HOME
[oracle@host1]
What is the correct parameters I need to pass.
Where I am doing mistake.
Regards,
Pratapa
How to monitor asm disk
Re: How to monitor asm disk
This would generally be a question for your oracle admins to answer, we don't know about your system or what it should be (or have ever used asm). Send us the full output of this:
That should hopefully list where sqlplus is, if there are more than one you'll need to reach out to your oracle admins/oracle support/development team to determine the proper ones.
Then you'd do:
Are you using this one (with perfdata support added or the one you posted)?
https://github.com/maciejkorzen/misc-pe ... /check_asm
find / -name sqlplus
Then you'd do:
./check_asm --asm_home=/full/path/to/sqlplus/minus/bin/dir --action=diskstatus
Thank you, we could able to implement ASM instance montoring.
Following is the one which I used.
command[check_asm_instance]=sudo -u oracle /usr/local/nagios/libexec/check_asm --asm_home=$ORACLE_ASM --action=status
[root@host1 ~]# sudo -u oracle /usr/local/nagios/libexec/check_asm --asm_home=$ORACLE_HOME --action=status
[OK] ASM instance is up
Excellent, I'm glad you were able to get this working! Thank you for posting the solution back here! Closing thread.
