How to set up monitoring of the URL
We have a requirement. We need to set up monitoring of the URL
https://fs.anz.com/adls/ls/idpinitiatedsignon.aspx?
Please suggest how to set up monitoring of this URL. We are using Nagios core.
We tried a few options.
./check_http -H host1 -u https://fs.anz.com/adls/ls/idpinitiatedsignon.aspx? -S
CRITICAL - Cannot make SSL connection.
./check_http -H host1 -u fs.anz.com/adls/ls/idpinitiatedsignon.aspx? -S
Following is the check_http version.
[root@nagiosserver libexec]# ./check_http -V
check_http v2.2.1 (nagios-plugins 2.2.1)
Re: How to set up monitoring of the URL
The -u flag is supposed to be a URI, not a full URL
How about this?
How about this?
./check_http -H fs.anz.com -u "/adls/ls/idpinitiatedsignon.aspx?" -S
We tried this, but we are getting below error.
#./check_http -H fs.anz.com -u "/adls/ls/idpinitiatedsignon.aspx?" -S
We tried some other options but we are getting error.
# ./check_http -H 10.211.50.12 -S
#./check_http -H host1 -S
HTTP WARNING: HTTP/1.1 404 Not Found - 492 bytes in 0.062 second response time |time=0.061986s;;;0.000000 size=492B;;;0
HTTP WARNING: HTTP/1.1 404 Not Found - 492 bytes in 0.007 second response time |time=0.006633s;;;0.000000 size=492B;;;0
10.211.50.12 is the IP address of the host1.
host1 is the windows server.
Can you show the output of the following
curl "https://fs.anz.com/adls/ls/idpinitiatedsignon.aspx?" -vvv
We are not supposed to share client's data here.
I asked user, what is the web server you are using and on which port it is running.
User replied that web server is HTTP.sys and the port no. is 443
That's understandable but can you curl the URL like above?Pratapa wrote:We are not supposed to share client's data here.
Yes we can curl the URLscottwilkerson wrote:That's understandable but can you curl the URL like above?Pratapa wrote:We are not supposed to share client's data here.
Following are the few lines from the output.
Connected to fs.anz.com (10.211.50.12) port 443
HTTP/1.1 200 OK
Connection #0 to host fs.anz.com left intact
Ok, can you reach the root with check_http?
./check_http -H fs.anz.com -S
No.
Following is the output.
#./check_http -H fs.anz.com -S
