Hello ,
I Need Help To Know How Can I Total price: Add ESSA Line Below nagios AO, I need to set up hum que service run this command :
./nsca_wrapper -H "nomedohost" -N "servidornagios" -S "check_internet_speed" -C "./check_speedtest-cli.sh 10 7 15 10 e 14
When i run manually works , however, when trying to enter configuration on the remote server I have no success.
I'm trying to use NSCA because passive monitoring
Tks,
Fabricio
NSCA - nsca_wrapper
Re: NSCA - nsca_wrapper
Does it work if you use the full path, rather then a ./ reference?
Thank you for your answer , one Line Up Work When perform any terminal. I Do not Know How To Make Adicionar THIS TO nagios Line Files for what works automatically .
tks
tks
If you want this command to run automatically every so often, you can set it up to run as a cron job.
