The plugins that come with nagiosxi (manual installation) appear to be outdated.
example:
# /usr/local/nagios/libexec/check_http -V
check_http v2.0.3 (nagios-plugins 2.0.3)
Can I download the latest plugins from https://www.nagios.org/downloads/nagios-plugins/ and install them on top of my existing nagiosxi installation?
Latest Nagios plugins with Nagios XI
Re: Latest Nagios plugins with Nagios XI
Yep -- should work without a problem after you compile them. Let us know if you run into any issues!
To add on, I saw you have a ticket open and I posted more details there. Since a ticket is open and we generally try to keep to one venue per issue, do you mind if I close this out?
Go ahead and close. I installed with no issues. Thanks!
