NRPE: Unable to read output
This forum is intended for the discussion of Nagios plugin development. Feature requests, patches, bug fixes, and all types of development-related discussions are welcome!
NOTE: The SourceForge.net nagiosplug-devel mailing list has been deprecated in favor of this forum in order to expedite support and provide additional features not available on the old mailing list.
Postby natalia.fitsyk » Wed Oct 05, 2016 2:37 am
I have a problem with my custom plugin.
I use nagios plugin jmeter.pl
[root@client_nrpe ~]# /usr/local/nagios/libexec/check_nrpe -H localhost -c check_jmeter
output from more /etc/nagios/nrpe.cfg
command[check_jmeter]=/usr/bin/sudo /usr/local/nagios/libexec/check_site.sh -w 1 -c 1
this is my script for jmeter:
more /usr/local/nagios/libexec/check_site.sh
#!/bin/bash
sudo -u nrpe sudo /home/nagios/apache-jmeter-3.0/bin/jmeter.pl -j /home/nagios/apache-jmeter-3.0/ -p /home/nagios/apache-jmeter-3.0/bin/dermsl01_buono.jmx
[root@client_nrpe ~]# grep nrpe /etc/sudoers
nrpe          ALL=(ALL)NOPASSWD: /usr/local/nagios/libexec/check_jmeter, /usr/local/nagios/libexec/check_nrpe, /usr/local/nagios/libexec/check_site.sh, /usr/local/nagios/libexec/script_jmeter.sh, /home/nagios/apache-jmeter-3.0/bin/jmeter, /root/apache-jmeter-3.0/bin/jmeter.pl, /home/nagios/apache-jmeter-3.0/bin/jmeter.pl
[root@client_nrpe ~]# ll /usr/local/nagios/libexec/check_site.sh
-rwxrwxrwx 1 nrpe nagios 570 Oct  3 18:14 /usr/local/nagios/libexec/check_site.sh
This is the output when I execute the script for check_site.sh:
[root@client_nrpe ~]# /usr/local/nagios/libexec/check_site.sh
OK : sum:15730 : 15.73 seconds to complete.
This is the output from check_users
[root@client_nrpe ~]# /usr/local/nagios/libexec/check_nrpe -H localhost -c check_users
USERS OK - 2 users currently logged in |users=2;5;10;0
Iptables and Selinux are off.
Can you help me please?
Thanks.
Natalia
jmeter.pl
(5.45 KiB) Downloaded 45 times
Reason: marking with green check mark
natalia.fitsyk
Re: NRPE: Unable to read output
Postby lgroschen » Wed Oct 05, 2016 2:02 pm
Hello!
This is a common mistake when creating your own plugin. All you should have to do to fix this would be to follow the developer guidelines on how generate nagios style output like this:
'label'=value[UOM];[warn];[crit];[min];[max]
Here is the resource. I'm sure there is a lot of stuff in this document that will help you make more plugins: https://nagios-plugins.org/doc/guidelines.html#AEN200
Let us know how this turns out! Would be happy to help
/Luke
lgroschen
Postby natalia.fitsyk » Fri Oct 07, 2016 8:00 am
I edit the /etc/nagios/nrpe.cfg and change form value to "ARG"
from
to
command[check_jmeter]=/usr/bin/sudo /usr/local/nagios/libexec/check_site.sh -w $ARG1$ -c $ARG2$
restart nrpe but the output don't change:
What is wrong?
Thank.
Natalia
natalia.fitsyk
Postby lgroschen » Fri Oct 07, 2016 11:20 am
Try running through this doc, it might be a simple permission issue: https://assets.nagios.com/downloads/nagiosxi/docs/NRPE-Troubleshooting-and-Common-Solutions.pdf
/Luke
lgroschen
Postby natalia.fitsyk » Tue Oct 11, 2016 7:12 am
I have checked every suggestion about my check_custom but I don't find errors.
Can anyone help me please?
Thanks.
Natalia
natalia.fitsyk
Postby rkennedy » Tue Oct 11, 2016 11:04 am
When you run the check_nrpe from the command line on the Nagios machine, please run tail -f /var/log/messages on your client machine. (might vary depending on your OS)
This will show us why the check is failing.
Postby natalia.fitsyk » Wed Oct 12, 2016 2:22 am
I don't have any output on /var/log/messages when I run check_nrpe -H localhost -c check_jmeter :(
Thank.
Natalia
Reason: editing code blocks
natalia.fitsyk
Postby lmiltchev » Wed Oct 12, 2016 3:33 pm
If you changed your command to:
then you need to test it by running:
./check_nrpe -H localhost -c check_jmeter -a 1 1
Note: "-a" is used to pass arguments. In this case, you are passing '1' for $ARG1$, and '1' for $ARG2$.
You have some entries in sudoers for the "nrpe" user. Do you actually have an "nrpe" user on this system? Can you test the command logged in as "nrpe" user?
su nrpe
QA Manager
Postby natalia.fitsyk » Thu Oct 13, 2016 4:08 am
This is the output :
[root@client_nrpe ~]# su nrpe
bash-4.1$ sudo /home/nagios/apache-jmeter-3.0/bin/jmeter.pl -j /home/nagios/apache-jmeter-3.0/ -p /home/nagios/apache-jmeter-3.0/bin/dermsl01_buono.jmx
OK : sum:4806 : 4.806 seconds to complete.
bash-4.1$ sudo /usr/local/nagios/libexec/check_site.sh -w 1 -c 1
OK : sum:2131 : 2.131 seconds to complete.
bash-4.1$ ./check_nrpe -H localhost -c check_jmeter -a 1 1
bash: ./check_nrpe: Permission denied
bash-4.1$ sudo ./check_nrpe -H localhost -c check_jmeter -a 1 1
[sudo] password for nrpe:
sudo: ./check_nrpe: command not found
bash-4.1$ pwd
When I run from login with nrpe user :
-bash-4.1$ pwd
/var/run/nrpe
-bash-4.1$ ./check_nrpe -H localhost -c check_jmeter
-bash: ./check_nrpe: No such file or directory
-bash-4.1$ ./check_nrpe -H localhost -c check_jmeter -a 1 1
-bash-4.1$ sudo /home/nagios/apache-jmeter-3.0/bin/jmeter.pl -j /home/nagios/apache-jmeter-3.0/ -p /home/nagios/apache-jmeter-3.0/bin/dermsl01_buono.jmx
OK : sum:2427 : 2.427 seconds to complete.
-bash-4.1$ sudo /usr/local/nagios/libexec/check_site.sh -w 1 -c 1
OK : sum:2309 : 2.309 seconds to complete.
-bash-4.1$ sudo ./check_nrpe -H localhost -c check_jmeter -a 1 1
Thanks a lot.
Natalia
Reason: code blocks FTW
natalia.fitsyk
Postby dwhitfield » Thu Oct 13, 2016 10:16 am
rkennedy wrote:(might vary depending on your OS)
What OS and version are you running? If CentOS, you can get your version from rpm --query centos-release.
Use Perforce? Check out our Nagios integration: https://swarm.workshop.perforce.com/pro ... -p4nagios/
Next
Return to Nagios Plugin Development
Users browsing this forum: No registered users and 2 guests
