nrpe 3.1.0 libc issue
This forum is intended for the discussion of Nagios plugin development. Feature requests, patches, bug fixes, and all types of development-related discussions are welcome!
NOTE: The SourceForge.net nagiosplug-devel mailing list has been deprecated in favor of this forum in order to expedite support and provide additional features not available on the old mailing list.
Postby emjga » Mon Jun 26, 2017 5:30 am
Folks
Was upgrading from NRPE 2.12 to 3.1.0
Most of the plugins seem to work fine however one kept on dying on the following
kernel: nrpe[19674] general protection ip:382a847946 sp:7ffc6da7d960 error:0 in libc-2.12.so[382a800000+18a000]
check_linux_stats.pl
If I run check_linux_stats on the machine it self , it worked fine but using nrpe the plugin would die with the above error.
Reverting back to NRPE 2.12 the above plugin works fine.
OS redHat 6.8
Any idea's
emjga
Re: nrpe 3.1.0 libc issue
Postby ssax » Mon Jun 26, 2017 12:48 pm
Please attach your check_linux_stats.pl plugin so that we can make sure that we have the same plugin to test with, I see a few different versions of that.
Thank you
ssax
Dreams In Code
Postby emjga » Tue Jun 27, 2017 2:11 am
ssax wrote:Please attach your check_linux_stats.pl plugin so that we can make sure that we have the same plugin to test with, I see a few different versions of that.
Thank you
Attached is version 1.5
It only seemed to fail on the CPU check.
However if I ran the plugin directly on the remote machine , it worked fine.
Matt
(19.28 KiB) Downloaded 47 times
emjga
Postby tgriep » Tue Jun 27, 2017 1:45 pm
I did a test with the NRPE Agent but a newer version 3.1.1 and running the command worked without any errors.
What version of the check_nrpe plugin were you using in the Nagios server to test the command?
Can you post how the command was setup in the nrpe.cfg file?
How was the NRPE Agent installed on the remote system, was it compiled or an RPM was used?
Postby emjga » Wed Jun 28, 2017 8:33 am
Indeed I see a newer version 3.2.0
Changelog does not say anything about LibC issues but after installing it the issue goes away.
Matt
emjga
Postby tmcdonald » Wed Jun 28, 2017 10:30 am
Good to hear! Are we okay to close this up?
Support Lead / Operations Engineer
Postby emjga » Wed Jun 28, 2017 10:33 am
tmcdonald wrote:Good to hear! Are we okay to close this up?
Indeed we are , thanks for the help and point in the right direction.
emjga
Return to Nagios Plugin Development
Users browsing this forum: No registered users and 3 guests
