NLS Inputs
NLS Inputs
It seems that all of my inputs just mysteriously vanished. There were the stock defaults. Is there a way to restore just the inputs? I have everything else.
Re: NLS Inputs
Do you still have all your config snapshots? That'd be the easiest way:
This won't restore *just* the inputs, but it is the easiest way.
Re: NLS Inputs
I resolved this seconds after the post. We copied the inputs from the DEV server.
Thx
Thx
