Collect logs from Fortigate... help!
nathanplatt
Post by nathanplatt »
Hi Guys,
I have a fortigate 100d in a datacentre and have my nagioslogserver at the office behind a public IP with NAT. How can i get the Fortigate to pass the logs to the logserver (pref encrypted), i tried adding it as syslog but Nagioslogserver says it needs a port number but I can't add that in the fortigate.
Any ideas?
Nathan
tacolover101
Re: Collect logs from Fortigate... help!
Post by tacolover101 »
check your foritgate guide as it's probably forwarding to port 514 by default. to get NLS to listen properly follow this guide - https://assets.nagios.com/downloads/nag ... Server.pdf
nathanplatt
Thanks for that, that document showed me how to change it so i can add the ports, but where do you add the ports?
Post by dwhitfield »
I may be misunderstanding your question, but it seems like the answer to your question is on page 1 of https://assets.nagios.com/downloads/nag ... Inputs.pdf
Please let us know if that is not what you mean.
