NLS Unable to log in
mquibell
Post by mquibell »
I've just installed an 60-day eval of NLS. It was not easy. After fixing several fullinstall errors, I got it to finally succeed in installing. Now I can't log in. I see the users I create with
curl -XPOST 'http://localhost:9200/nagioslogserver/user/' -d '{"username":"someuser","password":"c678bcf3b5138b9263a95c44d28097f22c2e02877193d2c25313478821d45c19","auth_type":"admin","email":"user@example.com","language":"default","apiaccess":"1","apikey":"1396e08757545557073844695e5b64caa0bd3ad3","created":"2015-01-23 10:00:00","created_by":0,"default_dashboard":"/dashboard/elasticsearch/default"}'
in the database, but it always tells me invalid password. Help meh!
TIA!
Re: NLS Unable to log in
What OS and version are you installing on, and is it a fresh OS install? We officially support CentOS and RedHat versions 6 and 7 for the latest Nagios Log Server. Any other OS in unsupported at this time, and previous modifications to the system can cause issues, typically if a security team locks down sudoers or configured selinux too tightly.
mquibell
Post by mquibell »
Hello sir,
The server is CentOS, release 6.3 (Final). It is not locked down to sudoer use only, for example. Thanks!
Also, when I went into the web gui and "Finished installation" by creating a username and all that, it said "Please wait..." for about 30 mins, so I restarted the host.
mquibell
Post by mquibell »
FYI, it recognizes the username I create, just not the password.
mquibell
Post by mquibell »
# curl -XGET 'http://localhost:9200/nagioslogserver/_ ... ser&pretty'
"took" : 8,
"timed_out" : false,
"_shards" : {
"total" : 1,
"successful" : 1,
"failed" : 0
"hits" : {
"total" : 2,
"max_score" : 1.0,
"hits" : [ {
"_index" : "nagioslogserver",
"_type" : "user",
"_id" : "2",
"_score" : 1.0,
"_source":{"username":"nagiosadmin","anotherpassword":"c678bcf3b5138b9263a95c44d28097f22c2e02877193d2c25313478821d45c19","auth_type":"admin","email":"user@mail.com","language":"default","apiaccess":"1","apikey":"1396e08757545557073844695e5b64caa0bd3ad3","created":"2018-01-18 10:00:00","created_by":0,"default_dashboard":"/dashboard/elasticsearch/default","forgotten_password_code":"651720020f1c4cd1b09f807df2a83b455431a872f1cd6ebcb1414d816463f2d9","forgotten_password_time":1516302198}
"_type" : "user",
"_id" : "AWEKqVUrbh02-23pPlHM",
"_score" : 1.0,
"_source":{"username":"someuser","passwordhere":"c678bcf3b5138b9263a95c44d28097f22c2e02877193d2c25313478821d45c19","auth_type":"admin","email":"user@example.com","language":"default","apiaccess":"1","apikey":"1396e08757545557073844695e5b64caa0bd3ad3","created":"2015-01-23 10:00:00","created_by":0,"default_dashboard":"/dashboard/elasticsearch/default"}
npolovenko
Post by npolovenko »
@mquibell, Your command is going to work if you insert 2 after /user/. Like this:
curl -XPOST 'http://localhost:9200/nagioslogserver/user/2' -d '{"username":"someuser","password":"c678bcf3b5138b9263a95c44d28097f22c2e02877193d2c25313478821d45c19","auth_type":"admin","email":"user@example.com","language":"default","apiaccess":"1","apikey":"1396e08757545557073844695e5b64caa0bd3ad3","created":"2015-01-23 10:00:00","created_by":0,"default_dashboard":"/dashboard/elasticsearch/default"}'
mquibell
Post by mquibell »
Thanks, but I did that with the nagiosadmin account. You can see where ID=2. I tried creating another user, with .../user/1 and it recognizes the name, but not the password.
mquibell
Post by mquibell »
I went back to creating the nagiosadmin account and then reset the password via the script. Works! Thanks!
npolovenko
@mquibell, Great! Do you have other questions for us or is it ok to lock this thread as resolved?
