fullinstall failur
mayank
fullinstall failur
Post by mayank »
Installing sourceguardian...
./libinstall.sh: line 342: php-config: command not found
INSTALLATION ERROR!
in your communications with Nagios Enterprises technical support.
The step that failed was: 'sourceguardian'
cdienger
Re: fullinstall failur
Post by cdienger »
It requires php-devel:
yum install php-devel -y
Which can require a optional channel:
https://support.nagios.com/kb/article.php?id=155
