This is probably going to be a really easy thing to fix, but I can't work out how to reactivate a pinned query once I've clicked its button and deactivated it! Once deactivated, the coloured button disappears and there doesn't seem to be anywhere on the pinned query's highlighted box or anywhere else on a dashboard to reactivate it.
What am I missing?
We're on NLS 2.0.1.
J.
How to reactivate a pinned query.
Re: How to reactivate a pinned query.
Once deactivated the colored button will become an outline and if you click it again it will activate and become a solid color. See screenshot of a deactivated pinned query. Once clicked again, it will activate and the circle will become a solid blue color to indicate it is active.
I assumed it would be something like that, but that's not how my queries are appearing. In the screen shot below, the right-hand query has been deactivated and there's no empty circle to click in order to reactivate it.
I tested on 2.0.1 and was able to reproduce. Upgrading to 2.0.4 should resolve it:
https://assets.nagios.com/downloads/nag ... Server.pdf
Thanks - I'll see if an upgrade can be planned.
Sounds good. We'll be here if anything further is needed.
Good news - we've upgraded (which was very easy) and this defect has gone away.
Thanks again.
Thanks again.
Glad to hear
