Hello Support,
Need to export from Nagios Log Server logstash files to local hard drive
would you suggest how we can do it please
export logstash files to separate local hard drive
Re: export logstash files to separate local hard drive
Are you referring to the Logstash config files?
nope
i am referring index logstash file which use to create daily
Logstash just takes the incoming messages through inputs and converts them into a format that can be put into an elasticsearch index.
If you want to make backups of these elasticsearch indexes this is built in using the Admin -> Snapshots and Maintenance
https://assets.nagios.com/downloads/nag ... enance.pdf
Alternately, if you wanted to setup a separate text output, you can do that in the logstash configuration you can add one by going to
Configure -> Global Config
Click Show Output
Add Output
and then setup your new output based on the available outputs such as
https://www.elastic.co/guide/en/logstas ... -file.html
Click Show Output
Add Output
Hi Support, Please understand my requirement /question
I need day wise log file which i need to export the entire logstashfile, please see the attached document
This can be done following this doc
