Import archived logs
Hi
I want to import archived logs, (a couple of years old or a few months old) to nls. Those logs included a "Date & Time" field. Once I imported the data, I want to draw some graphs. How can I use "Date & Time" filed as the X-axis data?
Can you please share a guide for the same ?
Thank you
Luke.
Thank you
Luke.
Re: Import archived logs
The default "Events Over Time" graph on the dashboard will use the date and time as the x-axis so that part is easy.
For importing the logs you can use the shipper script. Details on using the script can be found in the NLS web interface under http://nls_ip/nagioslogserver/configure/source/import.
Parsing the data may be a bit trickier. For that we would need sample logs to create a filter, but I would strongly encourage anyone to try setting up the filters themselves after reviewing https://support.nagios.com/kb/article/n ... ew-98.html. The "Logstash Example Configuration" section specifically steps through setting up custom filters.
Hi
Can you please help me to insert this type of data to nls;
Param1 : Value1_Text
Date & Time: 2017-09-24 08:57:23.376
Param2: Integer
Param3: Value3_text
Param4: Value4_text
How can I write an input filter? Once inserted data, I should be able to get the Date & Time for the x-axis.
Thank you
Luke.
Param2: Integer
Param3: Value3_text
Param4: Value4_text
Thank you
Luke.
The shipper script and instructions use the default input "Import Files - JSON (Default)". Make sure that this is enabled under Configure > Global (All Instances) > Global Config > Inputs. The config looks like:
The next part is parsing the data. The KB linked to in the previous post goes through configuring a custom filter. It's a good exercise to go through and try to set this up, but if you need assistance with configuring a filter, then we would need a copy of the actual log to be imported.
tcp {
type => 'import_json'
tags => 'import_json'
port => 2057
codec => json
Hi
I have found articles and questions in the forum that some of the users have tried to inject txt based logs to nls. However, I don't need to pass my logs to syslog. I need a separate pipe to send them to nls.
https://support.nagios.com/kb/article/n ... g-727.html
https://support.nagios.com/forum/viewto ... 1532419112
what is the best way to input them to nls?
I am sorry I am unable to share the log over the forum, so I have PM the logs to you directly.
Thank you
Luke.
Thank you
Luke.
The logs can be imported using the tcp input and the multiline codec. Using one of the sample logs for example:
Another similar input would need to be configured for the other logs that do not follow this pattern. Logs can be imported using a telnet command:
cat alert.txt | nc nls_ip 2056
tcp {
type => 'import_raw'
tags => 'import_raw'
port => 2056
codec => multiline {
pattern => "^SETTLEMENT"
negate => "true"
what => "previous"
Hi
I tried to follow your instructions but still, I couldn't import the logs correctly. I can see logs are been imported. In the dashboard - each having a separate row.
I will give a sample of log data that I want to import to nls;
For example;
CompanyName: XYZ Pvt Ltd
Date & Time: 2018-09-28 00:03:47.312
Some value: xxx
Some text: abcd
So on, it has multiple lines
END:
CompanyName: ABC Pvt Ltd
Date & Time: 2018-09-28 00:02:20.312
Some value: xxx
Some text: abcdddd
END:
As per the example --> starting point will be "CompanyName:" and the end point is "END:".
Cant, we make such a start and end point to import a block of data to nls?
As I understood, if the block of data properly imported, filtering is quite flexible. Can you please help me?
Thank you
Luke.
For example;
Some value: xxx
Some text: abcd
END:
Some value: xxx
Some text: abcdddd
END:
Thank you
Luke.
Further to the previous question;
Once imported the logs to nls, how can I get the "Date & Time:" field to the x-axis? Based on the "Date & Time: I wanna draw the rest of the graphs.
Luke
Luke
My previous post had a typo. To import try:
This along with an input that looks like:
should allow you to import these events.
For your follow up question, the graphs will display the date and time an event came in on the x-axis already. Are you trying to replace @timestamp with 2018-09-28 00:03:47.312 from your example? If so, I'll need to look into that one.
tcp {
port => 2056
pattern => "^CompanyName"
negate => "true"
what => "previous"
Thank you so much. It helped me to import data to nls correctly.
Now I can filter as I wish by selecting the fields in the block of data. As I stated, I need to get the "Date & Time" to X-Axis to draw some graphs. (Bar charts/Pie Charts/ and take a count of no.of occurrences of some events)
For example:-
Date & Time: 2017-10-11 06:06:27.189
I need only this part --> 2017-10-11 (YYYY-MM-DD) as the X-Axis date. How can it be done? Do we need to write GROCK filter or something like that?
Regards
Luke
For example:-
Regards
Luke
